[Geomoose-users] Limit Identify Result
Brent Fraser
bfraser at geoanalytic.com
Thu Aug 6 15:58:12 EDT 2009
Jessica,
For a work-around, you could use Mapserver's TOLERANCE to limit the search to
a small distance (unless you are adamant about the 5 results).
Brent
Jessica Fendos wrote:
> Dan:
> It will be of value to entities dealing with "licensed" data. Actually,
> I was going to use GeoMoose to display green career opportunities at the
> coming State Fair Green Career booth organized by the Department of
> Employment and Economic Development -- showing "green" educational
> programs and industries. If it is not too much trouble, would you
> consider? However, the deadline is August 14th. If you are busy at this
> time, we can always use GeoMoose next time when appropriate. Thank you
> either way.
> Best,
> Jessica
>> >> Dan Little <danlittle at yahoo.com> 8/6/2009 2:40 PM >>>
> This the first request for the feature that I've heard, so no, it's not
> implemented. It wouldn't be a difficult add-on to either GM1.6.X or
> GM2.0 ... shall I consider the option officially requested?
> *From:* Jessica Fendos <Jessica.Fendos at state.mn.us>
> *To:* Brent Fraser <bfraser at geoanalytic.com>; Dan Little
> *Cc:* geomoose-users at lists.sourceforge.net
> *Sent:* Thursday, August 6, 2009 2:33:21 PM
> *Subject:* Re: [Geomoose-users] Limit Identify Result
> Thanks Dan for the quick response. I know GeoMoose 2.0 is built on
> MapServer and OpenLayers. Will 2.0 take care of identify limit at
> this time? Appreciate your time!
> Jessica
> > >> Dan Little <danlittle at yahoo.com> 8/6/2009 2:27 PM >>>
> That add-on is something chameleon implemented. For identify
> functionality GeoMOOSE 1.6.X uses MapServer directly, so if it's not
> a native-MapServer supported function it will not work with GeoMOOSE
> 1.6.X
> *Sent:* Thursday, August 6, 2009 2:23:20 PM
> Thanks Brent:
> I was able to limit the identify result using this metadata tag
> in Chameleon (another add-on to MapServer) so was hoping I can
> do the same in GeoMoose.... Suggestions anyone?
> Jessica
> > >> Brent Fraser <bfraser at geoanalytic.com> 8/6/2009 2:10 PM >>>
> Jessica,
> I don't think "query_limit" has been implemented in Mapserver
> yet
> (http://trac.osgeo.org/mapserver/ticket/2424). The only option
> I can think of
> is to do some PHP (or other scripting language) programming,
> similar to GM's
> select.php and limit the returned results there.
> But you might want to ask the question on the Mapserver-users
> email list.
> Best Regards,
> Brent Fraser
> > Hi list:
> > I am using GeoMoose 1.6.1. I have several point layers
> (employers by
> > industry) that I would like to display in the mapping
> interface. Due to
> > InfoUSA data restriction, I would like to limit the display of
> records
> > resulting from the "Identify" tool to 5.
> > I added the following
> > *METADATA
> > "query_limit" "5"
> > END*
> > to this layer in identify.map (under maps_statedemo) and
> employer.map
> > (under maps_statedemo/employer) but it does not seem to have
> any effect.
> > Is there a way for me to do this without setting the maxscaledemo
> > parameter? I would like to view these employer locations from the
> > overview but identify less than 5 at a time.
> > Thanks!
> > Jessica
> > Let Crystal Reports handle the reporting - Free Crystal
> Reports 2008 30-Day
> > trial. Simplify your report design, integration and deployment
> - and focus on
> > what you do best, core application coding. Discover what's new
> with
> > Crystal Reports now. http://p.sf.net/sfu/bobj-july
> > Geomoose-users mailing list
> > Geomoose-users at lists.sourceforge.net
> > https://lists.sourceforge.net/lists/listinfo/geomoose-users
> Let Crystal Reports handle the reporting - Free Crystal Reports
> 2008 30-Day
> trial. Simplify your report design, integration and deployment -
> and focus on
> what you do best, core application coding. Discover what's new with
More information about the Geomoose-users
