[Geomoose-users] Limit Identify Result
    Jessica Fendos
    Jessica.Fendos at state.mn.us
    Thu Aug  6 16:11:21 EDT 2009
Dan:
Sorry if I put you on a hot spot. I was hoping this feature would be
added to GeoMoose. The mapping interface will not be too demanding
except I have to limit query result. It sounds like I am really pushing
it for this time frame. Would you consider adding this feature in 2.0
(or 2.0.1) when it is convenient to you in the near future (does not
have to be before 8/14)? Thank you!
Jessica
>>> Dan Little <danlittle at yahoo.com> 8/6/2009 2:58 PM >>>
Are you saying you would need this feature added to GeoMOOSE by August
14th? Or are you saying you need assistance setting up GeoMOOSE for the
State Fair booth?
It might be a possibility for me to write the feature into GM2.0 by the
14th but probably not GM1.6 (as GM2.0 actually has an identify service
using PHP, so there is more control).
From: Jessica Fendos <Jessica.Fendos at state.mn.us>
To: Brent Fraser <bfraser at geoanalytic.com>; Dan Little
Cc: geomoose-users at lists.sourceforge.net
Sent: Thursday, August 6, 2009 2:52:23 PM
Subject: Re: [Geomoose-users] Limit Identify Result
Dan:
It will be of value to entities dealing with "licensed" data. Actually,
I was going to use GeoMoose to display green career opportunities at the
coming State Fair Green Career booth organized by the Department of
Employment and Economic Development -- showing "green" educational
programs and industries.  If it is not too much trouble, would you
consider? However, the deadline is August 14th. If you are busy at this
time, we can always use GeoMoose next time when appropriate. Thank you
either way.
Best,
Jessica
>>> Dan Little <danlittle at yahoo.com> 8/6/2009 2:40 PM >>>
This the first request for the feature that I've heard, so no, it's not
implemented.  It wouldn't be a difficult add-on to either GM1.6.X or
GM2.0 ... shall I consider the option officially requested?
Sent: Thursday, August 6, 2009 2:33:21 PM
Thanks Dan for the quick response. I know GeoMoose 2.0 is built on
MapServer and OpenLayers. Will 2.0 take care of identify limit at this
time? Appreciate your time!
Jessica
>>> Dan Little <danlittle at yahoo.com> 8/6/2009 2:27 PM >>>
That add-on is something chameleon implemented.  For identify
functionality GeoMOOSE 1.6.X uses MapServer directly, so if it's not a
native-MapServer supported function it will not work with GeoMOOSE
1.6.X
Sent: Thursday, August 6, 2009 2:23:20 PM
Thanks Brent:
I was able to limit the identify result using this metadata tag in
Chameleon (another add-on to MapServer) so was hoping I can do the same
in GeoMoose.... Suggestions anyone?
Jessica
>>> Brent Fraser <bfraser at geoanalytic.com> 8/6/2009 2:10 PM >>>
Jessica,
   I don't think "query_limit" has been implemented in Mapserver yet
(http://trac.osgeo.org/mapserver/ticket/2424).  The only option I can
think of
is to do some PHP (or other scripting language) programming, similar to
GM's
select.php and limit the returned results there.
   But you might want to ask the question on the Mapserver-users email
list.
Best Regards,
Brent Fraser
Jessica Fendos wrote:
> Hi list:
> I am using GeoMoose 1.6.1. I have several point layers (employers by
> industry) that I would like to display in the mapping interface.  Due
to
> InfoUSA data restriction, I would like to limit the display of
records
> resulting from the "Identify" tool to 5.
> I added  the following
>  *METADATA
>    "query_limit" "5"
>   END*
> to this layer in identify.map (under maps_statedemo) and employer.map
> (under maps_statedemo/employer) but it does not seem to have any
effect.
> Is there a way for me to do this without setting the maxscaledemo
> parameter? I would like to view these employer locations from the
> overview but identify less than 5 at a time.
> Thanks!
> Jessica
> Let Crystal Reports handle the reporting - Free Crystal Reports 2008
30-Day
> trial. Simplify your report design, integration and deployment - and
focus on
> what you do best, core application coding. Discover what's new with
> Crystal Reports now.  http://p.sf.net/sfu/bobj-july
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
30-Day
focus on
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20090806/7724c414/attachment.html
More information about the Geomoose-users
