[Geomoose-users] Multiple Geomoose sites
Dan Little
danlittle at yahoo.com
Wed Aug 19 11:13:10 EDT 2009
Yes, you can install both GeoMOOSE 1.6.1 and GeoMOOSE 2 on the same system.
You can also rock and roll all night and party every day.
Really... I just just not post when I'm this exhausted.
----- Original Message ----
> From: "Moore, Richard J" <richard.moore at mnsu.edu>
> To: Brian Fischer <bfischer at houstoneng.com>; "coffee at uni-bonn.de" <coffee at uni-bonn.de>
> Cc: "geomoose-users at lists.sourceforge.net" <geomoose-users at lists.sourceforge.net>
> Sent: Wednesday, August 19, 2009 9:57:09 AM
> Subject: Re: [Geomoose-users] Multiple Geomoose sites
> Can I install GeoMoose 2 and continue to use GeoMoose 1.6.1. I would like to
> transfer my applications from 1.6.1 to 2 but need to do it over time. If I
> install GM2, will it overwrite anything I have in 1.6.1
> Thanks,
> Rick
> -----Original Message-----
> From: Brian Fischer [mailto:bfischer at houstoneng.com]
> Sent: Wednesday, August 19, 2009 8:56 AM
> To: 'coffee at uni-bonn.de'; Moore, Richard J
> Cc: geomoose-users at lists.sourceforge.net
> Subject: RE: [Geomoose-users] Multiple Geomoose sites
> I think in general that provides the least amount of maintenance plus you gain
> the advantage of a situation where you want to upgrade one app to a new version
> but not the other.
> If you don't want to duplicate your data, you can always point your mapefiles to
> a data folder outside of GM2 folders. The mapefiles can reference data anywhere
> on your network.
> -Brian
> From: CoFIS Web [mailto:coffee at uni-bonn.de]
> Sent: Wednesday, August 19, 2009 8:35 AM
> To: richard.moore at mnsu.edu
> Richard,
> Copying the entire directory of GM2, as Mark suggested, works fine for
> me (and has been working fine in GM 1.6.x).
> Nils
> Mark Volz schrieb:
> > Rick,
> > I think the call up order is:
> > Htdocs\geomoose.html
> > Htdocs\compiled.js
> > Htdocs\php\getmapbook.php
> > Htdocs\php\config.php
> > Conf\settings.ini
> > Conf\mapbook_demo.html
> > You have two choices:
> > 1) You could modify those files to create a second gm2 site however, most of
> > the functions in the php directory link to index.php. You would end up
> > having to modify all of those functions if your site uses different data.
> > 2) It might be easier to copy the entire geomoose2 directory to a new
> > directory. You will need to set up a virtual directory by making a copy of
> > \ms4w\httpd.d\httpd_geomoose2_ms4w.conf.
> > * I think all of the directories are relative in GM2 so you won't have to
> > search for ms4w\apps\geomoose2 in every file then change it to
> > ms4w\apps\mysecondgeomoose
> > * You would have to repeat your work for any updates to geomoose
> > Mark Volz
> > GIS Specialist
> > Lyon County, MN
> > (507) 532-8218
> > Message: 2
> > Date: Thu, 13 Aug 2009 11:54:13 -0500
> > Subject: [Geomoose-users] Multiple Sites in GM 2.0
> > To: "'geomoose-users at lists.sourceforge.net'"
> > Message-ID:
> > <0821406D702C1442A50855B521808F380126BB889F1F at EX2.Campus.mnsu.edu>
> > Content-Type: text/plain; charset="us-ascii"
> > In GM 2.0, which files need to be copied to make multiple sites within
> > GeoMoose? I've noticed a few but want to double check with the experts.
> > It seems like it should be:
> > Mapbook.xml in the CONF folder
> > Possible Settings.ini in CONF folder
> > Possibly compiled.js in htdocs folder
> > GeoMoose.html in htdocs folder
> > A lot of those seem similar to the GM 1.6.1, but was unsure of the path that
> > GeoMoose takes when it is launched.
> > I assume it is Geomoose.html then compiled.js and then references to the
> > other two along the way
> > If you could shed some light on exactly which files we need to change if we
> > are making a simple application, as well as which files need to be
> > duplicated/copied for multiple applications.
> > Thanks,
> > Rick Moore
> > GIS Research Analyst
> > Water Resources Center
> > 184 Trafton Science Center South
> > Minnesota State University, Mankato
> > Mankato, MN 56001
> > (507) 389-3267
> > http://mavdisk.mnsu.edu/moorer2/
> > Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
> > trial. Simplify your report design, integration and deployment - and focus on
> > what you do best, core application coding. Discover what's new with
> > Crystal Reports now. http://p.sf.net/sfu/bobj-july
> > Geomoose-users mailing list
> > Geomoose-users at lists.sourceforge.net
> > https://lists.sourceforge.net/lists/listinfo/geomoose-users
> Center for Development Research
> Department of Ecology and Resource Management
> Walter-Flex-Strasse 3
> 53113 Bonn (Germany)
> Tel.: +49 (0) 228 - 73-1793
> FAX: +49 (0) 228 - 73-1889
> E-Mail: coffee at uni-bonn.de
> Web: http://www.cofis.info/atlas
> http://www.coffee.uni-bonn.de
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
More information about the Geomoose-users
