[Geomoose-users] mapfile_root in "settings.ini" and mapbook
Dan Little
danlittle at yahoo.com
Thu Aug 20 13:47:37 EDT 2009
settings.ini is used by PHP and the MapBook is used by the web application for configuration settings.
While mapfile_root and mapserver_url are probably redundant there is a speed improvement for some operations if they do not need to parse the XML file. Projection is necessary because it is not gauenteed to be defined in the mapfile. We could change this to be a default/override setup similar to the way the javascript applications settings are handled now.
----- Original Message ----
> From: CoFIS Web <coffee at uni-bonn.de>
> To: GeoMoose Mailing list <geomoose-users at lists.sourceforge.net>
> Sent: Thursday, August 20, 2009 6:28:39 AM
> Subject: [Geomoose-users] mapfile_root in "settings.ini" and mapbook
> Hello altogether,
> I was curious if anyone could tell me why the "mapfile_root",
> "mapserver_url" and "projection" have to be defined in both mapbook and
> settings.ini
> Thanks,
> Nils
> Center for Development Research
> Department of Ecology and Resource Management
> Walter-Flex-Strasse 3
> 53113 Bonn (Germany)
> Tel.: +49 (0) 228 - 73-1793
> FAX: +49 (0) 228 - 73-1889
> E-Mail: coffee at uni-bonn.de
> Web: http://www.cofis.info/atlas
> http://www.coffee.uni-bonn.de
> Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
> trial. Simplify your report design, integration and deployment - and focus on
> what you do best, core application coding. Discover what's new with
> Crystal Reports now. http://p.sf.net/sfu/bobj-july
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
More information about the Geomoose-users
