[Geomoose-users] GM2: Where to put customized JS-code to
	survive revision upgrades
    Dan Little
    danlittle at yahoo.com
    Mon Aug 31 11:19:07 EDT 2009
I'll roll these into trunk, under ticket #11, it will be rolled into GM2.0.1.
-Duck
----- Original Message ----
> From: Nils Zierath | Center for Development Research Bonn (ZEF) <nils.zierath at uni-bonn.de>
> To: Dan Little <danlittle at yahoo.com>
> Cc: Len Kne <lkne at houstoneng.com>; GeoMoose Mailing list <geomoose-users at lists.sourceforge.net>; "geomoose-developers at lists.sourceforge.net" <geomoose-developers at lists.sourceforge.net>
> Sent: Monday, August 31, 2009 10:10:04 AM
> Subject: Re: [Geomoose-users] GM2: Where to put customized JS-code to survive revision upgrades
> Dan,
> thanks to help from Len I modified htdocs/compiled.js and my mapbook as put in
> the attached textfile.
> The result works great so far: http://www.cofis.info/atlas_beta
> Cheers,
> Nils
> Dan Little schrieb:
> > Well, I'd be interested in the patches to see what is applicable to roll into
> trunk. :-)
> > Right now, there is not a lot of architecture for doing this.  Really,
> compiled.js shouldn't get modified.  The actual source script in htdocs/geomoose
> should be edited and compiled.js should be rebuilt using compileGeomoose.py in
> the tools directory.
> > I was in the process of writing a development guide on this and then realized
> that I really need to code an user-extensions architecture. :-|
> >> From: CoFIS Web
> >> To: GeoMoose Mailing list ;
> >> Sent: Monday, August 31, 2009 9:35:26 AM
> >> Subject: [Geomoose-users] GM2: Where to put customized JS-code to survive
> revision upgrades
> >> Dear all,
> >> is there an easy way to maintain custom changes to JavaScript code, across
> revision upgrades?
> >> I did change a few lines in htdocs/compiled.js to modify my reference map.
> >> - How would I put that into a seperate script so that the changes override
> the defaults in htdocs/compiled.js?
> >> - Would I have to modify any files exept for geomoose.html to include the new
> js-file?
> >> Thank you,
> >> Nils
> >> -- Center for Development Research
> >> Department of Ecology and Resource Management
> >> Walter-Flex-Strasse 3
> >> 53113 Bonn (Germany)
> >> Tel.:   +49 (0) 228 - 73-1793
> >> FAX:    +49 (0) 228 - 73-1889
> >> E-Mail: coffee at uni-bonn.de
> >> Web:    http://www.cofis.info/atlas
> >>          http://www.coffee.uni-bonn.de
> >> Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
> trial. Simplify your report design, integration and deployment - and focus on
> what you do best, core application coding. Discover what's new with Crystal
> Reports now.  http://p.sf.net/sfu/bobj-july
> >> _______________________________________________
> >> Geomoose-users mailing list
> >> Geomoose-users at lists.sourceforge.net
> >> https://lists.sourceforge.net/lists/listinfo/geomoose-users
> -- Nils Zierath
> E-Mail: nils.zierath at uni-bonn.de
> Web:    http://www.coffee.uni-bonn.de
>         http://www.zef.de
More information about the Geomoose-users
