[Geomoose-users] Search issue - no results
CoFIS Web
coffee at uni-bonn.de
Wed Dec 16 07:45:17 EST 2009
Hello altogether,
I am trying to modify the search function (GM 2.0.1) to fit my data. I
modified the settings in my mapbook, mapfile and itemquery.html (below).
However, the search does not return any results - and it takes only a
split second. So I guess, it does not really search the shapefile at all:
"No results found for your query!"
Where should I look for what?
Thanks,
Nils
<!-- mapbook service -->
<service name="search_admin">
<url>php/itemquery.php</url>
<step type="input">
<input type="select" name="fieldname0" title="Search by:">
<option value="wereda">Wereda</option>
<option value="region">Region</option>
</input>
<input type="hidden" name="comparitor0" value="like-icase"/>
<input type="user" name="value0" title=""/>
<input type="hidden" name="layer0" value="administration/wereda"/>
<input type="hidden" name="template0" value="itemquery"/>
<input type="hidden" name="highlight" value="true"/>
<input type="hidden" name="mode" value="search"/>
</step>
</service>
<!-- mapbook catalog -->
<tool name="search_admin" title="Search" type="service"
service="search_admin" selectable="false"/>
In my mapfile in
METADATA
'identify_record' 'tool_identify/wereda_identify.html'
'itemquery' 'tool_select/admin_04_wereda_itemquery.html'
#'itemquery-filteritem' 'region'
'itemquery-filter' '/.*[qstring].*/i'
'qstring_validation_pattern' '.'
END #METADATA
admin_04_wereda_itemquery.html says
<!-- MapServer Template -->
<tr>
<td>[wereda]</td>
<td>[region]</td>
<td><a href="javascript:Map.itemQueryLayer('Highlight', 'Wereda',
'Region', '[region]',
'/srv/coffeeshop/map/tool_select/admin_04_wereda_itemquery.html');
Map.zoomToViewString(([shpminx]-500)+','+([shpminy]-500)+','+([shpmaxx]+500)+','+([shpmaxy]+500))"><img
src="images/toolbar/zoomto.png" border="0" title="Click here to zoom
selected wereda"></a></td>
</tr>
Center for Development Research
Department of Ecology and Resource Management
Walter-Flex-Strasse 3
53113 Bonn (Germany)
Tel.: +49 (0) 228 - 73-1793
FAX: +49 (0) 228 - 73-1889
E-Mail: coffee at uni-bonn.de
Web: http://www.cofis.info/atlas
http://www.coffee.uni-bonn.de
More information about the Geomoose-users
