[Geomoose-users] Search issue - no results
Dan Little
danlittle at yahoo.com
Wed Dec 16 08:33:23 EST 2009
Getting the new query service will require pulling from SVN/trunk as it is technically a 2.2 feature.
----- Original Message ----
> From: Len Kne <lkne at houstoneng.com>
> To: "coffee at uni-bonn.de" <coffee at uni-bonn.de>; GeoMoose Mailing list <geomoose-users at lists.sourceforge.net>
> Sent: Wed, December 16, 2009 7:23:59 AM
> Subject: Re: [Geomoose-users] Search issue - no results
> Nils
> The inputs you are using look to fit the new query service (query.php). Try
> changing your URL to that file and it should work better.
> http://www.geomoose.org/moose/services/query.php.html
> Len
> ________________________________________
> From: CoFIS Web [coffee at uni-bonn.de]
> Sent: Wednesday, December 16, 2009 6:45 AM
> To: GeoMoose Mailing list
> Subject: [Geomoose-users] Search issue - no results
> Hello altogether,
> I am trying to modify the search function (GM 2.0.1) to fit my data. I
> modified the settings in my mapbook, mapfile and itemquery.html (below).
> However, the search does not return any results - and it takes only a
> split second. So I guess, it does not really search the shapefile at all:
> "No results found for your query!"
> Where should I look for what?
> Thanks,
> Nils
> php/itemquery.php
> Wereda
> Region
> service="search_admin" selectable="false"/>
> In my mapfile in
> METADATA
> 'identify_record' 'tool_identify/wereda_identify.html'
> 'itemquery' 'tool_select/admin_04_wereda_itemquery.html'
> #'itemquery-filteritem' 'region'
> 'itemquery-filter' '/.*[qstring].*/i'
> 'qstring_validation_pattern' '.'
> END #METADATA
> admin_04_wereda_itemquery.html says
> [wereda]
> [region]
> src="images/toolbar/zoomto.png" border="0" title="Click here to zoom
> selected wereda">
> Center for Development Research
> Department of Ecology and Resource Management
> Walter-Flex-Strasse 3
> 53113 Bonn (Germany)
> Tel.: +49 (0) 228 - 73-1793
> FAX: +49 (0) 228 - 73-1889
> E-Mail: coffee at uni-bonn.de
> Web: http://www.cofis.info/atlas
> http://www.coffee.uni-bonn.de
> This SF.Net email is sponsored by the Verizon Developer Community
> Take advantage of Verizon's best-in-class app development support
> A streamlined, 14 day to market process makes app distribution fast and easy
> Join now and get one step closer to millions of Verizon customers
> http://p.sf.net/sfu/verizon-dev2dev
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users
