[Geomoose-users] getting started with gm2
Dan Little danlittle at yahoo.com
Wed Dec 16 11:48:02 EST 2009
Hey Jim,
Sorry I didn't back to you when you wrote the earlier email.  I've been meaning to do so.
Here's how the various files work:
* settings.ini - This tells all the services where stuff is, which mapbook to use, etc.
* config.php - This isn't really used any more like it was in 1.X, most everything is dedicately stored in settings.ini
* mapbook.xml is actually served by getmapbook.php based on the setting in settings.ini.  This has been established as the ground work for future enhancements to the application.  Specifically, the ability to create user names/accounts, and have different mapbooks served based on the account pliverages.
>From: Jim Hagedorn <jhagedorn at bannerassociates.com>
>To: "geomoose-users at lists.sourceforge.net" <geomoose-users at lists.sourceforge.net>
>Sent: Wed, December 16, 2009 10:43:57 AM
>Subject: [Geomoose-users] getting started with gm2
>Can someone tell me the order of files that are called when
>the html is called.  The html file should call a file that calls the files
>that do the configurations and set up.  So from geomoose.html, what file
>is called in that html to get to settings.ini and config.php and mapbook.xml?
>Just trying to get started in gm2.
>thanks
>Jim
>Hagedorn
>GIS
>Specialist
>Banner Associates, Inc.
>409 22nd
>Avenue South· PO Box 298· Brookings, South Dakota 57006
>(605)
>692-6342 ·  Fax(605) 692-5714
>www.bannerassociates.com
Skipped content of type multipart/related
More information about the Geomoose-users mailing list
