[Geomoose-users] getting started with gm2
Dan Little
danlittle at yahoo.com
Wed Dec 16 12:33:40 EST 2009
It's never called from the HTML.
Geomoose.html calls getmapbook.php... getmapbook.php reads the settings.ini to determine which mapbook to return... getmapbook.php then returns the mapbook where the rest of the settings are stored.
>From: Jim Hagedorn <jhagedorn at bannerassociates.com>
>To: Dan Little <danlittle at yahoo.com>; "geomoose-users at lists.sourceforge.net" <geomoose-users at lists.sourceforge.net>
>Sent: Wed, December 16, 2009 11:31:32 AM
>Subject: RE: [Geomoose-users] getting started with gm2
>Dan
>So at what point in the
>geomoose.html is the setting.ini called? Just trying to get in my mind the
>sequence of calls and what calls what.
>Thanks
>jim
>From:Dan Little
>[mailto:danlittle at yahoo.com]
>Sent: Wednesday, December 16, 2009 10:48 AM
>To: Jim Hagedorn; geomoose-users at lists.sourceforge.net
>Subject: Re: [Geomoose-users] getting started with gm2
>Hey
>Jim,
>>Sorry I didn't back to you when you wrote the earlier email. I've been
>meaning to do so.
>>Here's how the various files work:
>>* settings.ini - This tells all the services where stuff is, which mapbook to
>use, etc.
>>* config.php - This isn't really used any more like it was in 1.X, most
>everything is dedicately stored in settings.ini
>>* mapbook.xml is actually served by getmapbook.php based on the setting in
>settings.ini. This has been established as the ground work for future
>enhancements to the application. Specifically, the ability to create user
>names/accounts, and have different mapbooks served based on the account
>pliverages.
>>From:Jim Hagedorn
>>To: "geomoose-users at lists.sourceforge.net"
>>Sent: Wed, December 16, 2009 10:43:57 AM
>>Subject: [Geomoose-users] getting started with gm2
>>Can someone tell me the order of files that are called when
>>the html is called. The html file should call a file that calls the files
>>that do the configurations and set up. So from geomoose.html, what file
>>is called in that html to get to settings.ini and config.php and
>>mapbook.xml?
>>Just trying to get started in gm2.
>>thanks
>>Jim
>>Hagedorn
>>GIS
>>Specialist
>>Banner Associates, Inc.
>>409 22nd Avenue South· PO Box 298>>· Brookings, South Dakota 57006
>>(605) 692-6342 · Fax(605) 692-5714
>>www.bannerassociates.com
Skipped content of type multipart/related
More information about the Geomoose-users
