[Geomoose-users] Search issue - no results
Dan Little
danlittle at yahoo.com
Mon Dec 21 09:23:22 EST 2009
Do you have the EXTENT set at the LAYER and/or MAP level in your Mapfile?
----- Original Message ----
> From: CoFIS Web <coffee at uni-bonn.de>
> To: Dan Little <danlittle at yahoo.com>
> Cc: GeoMoose Mailing list <geomoose-users at lists.sourceforge.net>
> Sent: Thu, December 17, 2009 6:57:56 AM
> Subject: Re: [Geomoose-users] Search issue - no results
> My last post referred to a search for items in "region". My service looks like:
> php/query.php
> Wereda
> Region
> service="search_admin_new" selectable="false"/>
> Thanks,
> Nils
> Dan Little schrieb:
> > Can you send the new service entry for query.php?
> >> From: CoFIS Web
> >> To: Len Kne
> >> Sent: Thu, December 17, 2009 5:41:52 AM
> >> This is what I get if I comment out error reporting in query.php:
> >> I searched for "Oromia" & it returns:
> >> Warning: [MapServer Error]: msQueryByRect(): No matching record(s) found. in
> /srv/www/geomoose/2.0.1/htdocs/php/query.php on line 317
> >> Warning: [MapServer Error]: msEvalExpression: Failed to parse expression:
> ("Oromia" =~ /.*(o|O)(r|R)(o|O)(m|M)(i|I)(a|A).*/) in
> >> Warning: [MapServer Error]: msyyparse(): syntax error in
> >> GM parses through the table but for some reason does not recognise the
> entries with "Oromia" as such. ...
> >> Any suggestions?
> >> Nils
> >> Len Kne schrieb:
> >>> In query.php or itemquery.php, try commenting out the error suppression,
> like
> >> this:
> >>> #error_reporting(E_ERROR | E_PARSE);
> >>> That might give some further information. Also in Firebug, check the param
> >> values being sent to make sure they look right. Maybe the extent is wrong? -
> speaking from frustrating experience here.
> >>> Len
> >>> -----Original Message-----
> >>> From: CoFIS Web [mailto:coffee at uni-bonn.de] Sent: Wednesday, December 16,
> 2009 9:06 AM
> >>> To: Len Kne
> >>> alright, so how can I start tracking down the issue in my app?
> >>> Nils
> >>> Len Kne schrieb:
> >>>> I can confirm that using query.php with 2.0.1 works just fine, we have
> >> several sites with this combination.
> >>>> Len
> >>>> From: Dan Little [mailto:danlittle at yahoo.com] Sent: Wednesday, December 16,
> 2009 8:44 AM
> >>>> To: coffee at uni-bonn.de; GeoMoose Mailing list
> >>>> Cc: Len Kne
> >>>> Actually, Len and Brian are running query.php with 2.0.1 installations.
> >> There's just no "package" to download. We're currently trying to put the
> trunk code, "through the paces." In my opinion, there are MANY fixed bugs with
> the current trunk and very few new ones.
> >>>>> From: CoFIS Web To: GeoMoose Mailing list Cc: Dan Little ; Len Kne Sent:
> Wed, December 16, 2009 8:37:59 AM
> >>>>> Dan Little schrieb:
> >>>>>> Getting the new query service will require pulling from SVN/trunk as it
> is
> >>>>> technically a 2.2 feature.
> >>>>> Too bad, I rather stick with 2.0.1 for the official version.
> >>>>> Anyway, no luck using the patterns in the demo from the downladable
> packages
> >> for
> >>>>> GM 2.0.1. The query still does not return any results.
> >>>>> One thing that I find strange is, that if I mess up the php/itemquery.php
> to something like php/nothing.php, GM does not return an error but the "No
> results found for your query!". So I
> >> think
> >>>>> it doesn´t even call the service (Yes, I cleared the cache and reloaded
> FF).
> >>>>> Nils
> >>>>> My mapbook service now looks like
> >>>>> php/itemquery.php
> >>>>> Wereda
> >>>>> Region
> >>>>> All the rest is still the same:
> >>>>> service="search_admin" selectable="false"/>
> >>>>> In my mapfile in
> >>>>> METADATA
> >>>>> 'identify_record' 'tool_identify/wereda_identify.html'
> >>>>> 'itemquery' 'tool_select/admin_04_wereda_itemquery.html'
> >>>>> #'itemquery-filteritem' 'region'
> >>>>> 'itemquery-filter' '/.*[qstring].*/i'
> >>>>> 'qstring_validation_pattern' '.'
> >>>>> END #METADATA
> >>>>> admin_04_wereda_itemquery.html says
> >>>>> [wereda]
> >>>>> [region]
> >>>>> src="images/toolbar/zoomto.png" border="0" title="Click here to zoom
> >>>>> selected wereda">
> >> -- Center for Development Research
> >> Department of Ecology and Resource Management
> >> Walter-Flex-Strasse 3
> >> 53113 Bonn (Germany)
> >> Tel.: +49 (0) 228 - 73-1793
> >> FAX: +49 (0) 228 - 73-1889
> >> E-Mail: coffee at uni-bonn.de
> >> Web: http://www.cofis.info/atlas
> >> http://www.coffee.uni-bonn.de
> >> This SF.Net email is sponsored by the Verizon Developer Community
> >> Take advantage of Verizon's best-in-class app development support
> >> A streamlined, 14 day to market process makes app distribution fast and easy
> >> Join now and get one step closer to millions of Verizon customers
> >> http://p.sf.net/sfu/verizon-dev2dev
> >> Geomoose-users mailing list
> >> Geomoose-users at lists.sourceforge.net
> >> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users
