[Geomoose-users] Search - pink layer when clicking on link to
zoom to result
CoFIS Web
coffee at uni-bonn.de
Tue Dec 22 09:45:58 EST 2009
I do use it:
<map-source name="demis-01" type="wms" tiled="false"
projection="EPSG:4326" reference="true">
<url>http://www2.demis.nl/WMS/wms.asp?WMS=WorldMap</url>
<layer name="Coastlines" reference="true"/>
<layer name="Hillshading" reference="true"/>
<layer name="Spot elevations"/>
<param name="format" value="image/png"/>
</map-source>
<layer title="Hillshading (default)"
src="demis-01/Coastlines:demis-01/Hillshading:demis-01/Spot elevations"
status="on" tip="More information:
http://www.demis.nl/home/pages/wms/docs/OpenGISWMS.htm" minscale="50000"/>
and don´t really understand why it´s not accepting the
projection="EPSG:4326" tag. It looks like the error appears only in the
overview map. The WMS shows up fine in the main map window.
However, what does that have to do with the search issue?
Nils
Len Kne schrieb:
> Looking at Firebug, it's trying to load a layer from Demis in the wrong projection:
> http://www2.demis.nl/WMS/wms.asp?WMS=WorldMap&TRANSPARENT=true&FORMAT=image%2Fpng&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&LAYERS=Coastlines&SRS=EPSG%3A32637&BBOX=-294801.5625,830496.10505,1467698.4375,1955496.10505&WIDTH=352&HEIGHT=225
> It doesn't look like you are using this layer, but is it still configured as a layer in one of your map files?
> Len
> -----Original Message-----
> From: CoFIS Web [mailto:coffee at uni-bonn.de]
> Sent: Tuesday, December 22, 2009 8:05 AM
> To: GeoMoose Mailing list
> Subject: [Geomoose-users] Search - pink layer when clicking on link to zoom to result
> Using itemquery.php I got the search running.
> If I get a unique result, GM automatically zooms to the right place and
> highlights the polygon - all fine.
> Ambiguous results are displayed in the sidebar. Once clicking the link
> to zoom to one of them results in zooming to the item (visible due to
> the change in the overview map) but shows a pink (error) layer on top of
> all other layers in the main map window.
> What shall I post to track the issue down?
> Thanks,
> Nils
> You can try at http://www.cofis.info/atlas using "Ya" and "Yayu" as
> search strings.
> itemqueury.php reads
> <service name="search_admin">
> <url>php/itemquery.php</url>
> <step type="input">
> <input type="select" name="qitem" title="Search by:">
> <option value="wereda">Wereda</option>
> <option value="region">Region</option>
> </input>
> <input type="user" name="qstring" title=""/>
> <input type="hidden" name="layer" value="administration/all"/>
> <input type="hidden" name="zoom_to_first" value="false"/>
> <input type="hidden" name="highlight" value="true"/>
> </step>
> </service>
Center for Development Research
Department of Ecology and Resource Management
Walter-Flex-Strasse 3
53113 Bonn (Germany)
Tel.: +49 (0) 228 - 73-1793
FAX: +49 (0) 228 - 73-1889
E-Mail: coffee at uni-bonn.de
Web: http://www.cofis.info/atlas
http://www.coffee.uni-bonn.de
More information about the Geomoose-users
