[Geomoose-users] getmapbook.php and Avoiding PHP
Dan Little
danlittle at yahoo.com
Fri May 8 20:10:07 EDT 2009
Your text has been added to the docs.
----- Original Message ----
> From: Brent Fraser <bfraser at geoanalytic.com>
> To: Dan Little <danlittle at yahoo.com>
> Cc: GeoMOOSE Users List <geomoose-users at lists.sourceforge.net>
> Sent: Friday, May 8, 2009 11:24:51 AM
> Subject: Re: [Geomoose-users] getmapbook.php and Avoiding PHP
> Dan,
> Many thanks for the over-ride and the doc. And since I'm the Devil's advocate
> in this case, here's a proposed edit for the doc:
> Why It's Okay
> Here are a couple of reasons to override the mapbook setting:
> o If you are having difficulty getting PHP working on your server and want to
> experiment with GeoMoose o You want to use a different server-side scripting
> language (such as Python or ASP) and are not interested in using the other
> GeoMoose PHP services.
> Thanks again!
> Brent
> Dan Little wrote:
> > I've added some code to SVN this morning that addresses the concerns about
> getmapbook.php.
> > Also, the latest SVN features the latest red-lining tools... they're slick as
> banana peels.
> > Please read the docs on the implementation of this over-ride and let me know
> if it makes sense:
> > http://www.geomoose.org/geomoose2/docs/howto/getmapbook.html
> > -Duck
> > The NEW KODAK i700 Series Scanners deliver under ANY circumstances! Your
> > production scanning environment may not be a perfect world - but thanks to
> > Kodak, there's a perfect scanner to get the job done! With the NEW KODAK i700
> > Series Scanner you'll get full speed at 300 dpi even with all image processing
> features enabled. http://p.sf.net/sfu/kodak-com
> > Geomoose-users mailing list
> > Geomoose-users at lists.sourceforge.net
> > https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users
