[Geomoose-users] GM2 - direct call to WMS without mapfile
CoFIS Web
coffee at uni-bonn.de
Tue May 19 10:50:58 EDT 2009
Great, it works.
Nils
Dan Little schrieb:
> I have the WMS layer reprojection working in SVN.
> And I even wrote some documentation...
> http://www.geomoose.org/geomoose2/docs/howto/wms_project.html
> I've tested going from UTM-15 to EPSG:4326 (using the nasa world mosaic you posted earlier).
> ----- Original Message ----
>> From: Dan Little <danlittle at yahoo.com>
>> To: coffee at uni-bonn.de
>> Cc: GeoMoose Mailing list <geomoose-users at lists.sourceforge.net>
>> Sent: Tuesday, May 12, 2009 7:12:39 AM
>> Subject: Re: [Geomoose-users] GM2 - direct call to WMS without mapfile
>> The error is with the reprojection. I will research what it will take to get
>> this to work today and see if I can get a solution.
>>> From: CoFIS Web
>>> To: Dan Little
>>> Sent: Tuesday, May 12, 2009 7:09:28 AM
>>> Hi Dan,
>>> my output projection for GM is EPSG:32637 as defined in the mapbook defaults.
>>> Nils
>>> Dan Little schrieb:
>>>> Hi Nils,
>>>> What is your map projection?
>>>>> From: CoFIS Web
>>>>> To: GeoMoose Mailing list
>>>>> Sent: Tuesday, May 12, 2009 6:38:29 AM
>>>>> Subject: [Geomoose-users] GM2 - direct call to WMS without mapfile
>>>>> Dear all,
>>>>> do I understand correctly, that in GM2 I can include WMS into my
>> application
>>> without having to us a local mapfile?
>>>>> I try to include the Blue Marble Global Mosaic tiled WMS
>>> (http://onearth.jpl.nasa.gov/wms.cgi?request=GetTileService) using the
>> following
>>> lines in my mapbook:
>>>>> src="background-wms/global_mosaic"/>
>>>>> When loading the layer, GM (according to the status bar in Firefox) loads
>>> data. However, the only thing displayed are red tiles - no satellite images.
>>>>> Could someone please point me in the right direction what to change?
>>>>> Thanks,
>>>>> Nils
>>>>> -- Center for Development Research
>>>>> Department of Ecology and Resource Management
>>>>> Walter-Flex-Strasse 3
>>>>> 53113 Bonn (Germany)
>>>>> Tel.: +49 (0) 228 - 73-1793
>>>>> FAX: +49 (0) 228 - 73-1889
>>>>> E-Mail: coffee at uni-bonn.de
>>>>> Web: http://www.cofis.info/atlas
>>>>> http://www.coffee.uni-bonn.de
>>>>> The NEW KODAK i700 Series Scanners deliver under ANY circumstances! Your
>>>>> production scanning environment may not be a perfect world - but thanks to
>>>>> Kodak, there's a perfect scanner to get the job done! With the NEW KODAK
>> i700
>>>>> Series Scanner you'll get full speed at 300 dpi even with all image
>>> processing features enabled. http://p.sf.net/sfu/kodak-com
>>>>> _______________________________________________
>>>>> Geomoose-users mailing list
>>>>> Geomoose-users at lists.sourceforge.net
>>>>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
>> i700
>> processing
>> Kodak, there's a perfect scanner to get the job done! With the NEW KODAK i700
More information about the Geomoose-users
