[Geomoose-users] [Geomoose-developers] Buffer Problems
Jay Kapalczynski
jkapalczynski at ci.maple-grove.mn.us
Fri May 22 10:45:03 EDT 2009
I don't think that it can be the 1.6 version as I have been using that for some time...with select/buffer success...although it very well might be
I cant think of anything else that I changed...as I said I haven't worked on this in a few months...the last I know it has been working
That and I haven't done anything with the Select tools...
As a simple test I created a new Select...Still not working...
Is there some code that I am missing to set up a new select? I think this is all that has to be written for the select to work
Could one of the .js files be corrupt?
Thanks
Maplegrove_demo.xml
<service title="Select Feature Poly" default="true" locked="true" cursor="url(cursors/select.cur), auto" shape="measurearea" type="inspect-search" icon="shared/images/toolbar/MapleGrove_Buttons/Select.jpg" highlight="shared/images/toolbar/MapleGrove_Buttons/Select.jpg">
<url>php/select.php</url>
<input type="multipoint" name="coords"/>
<input type="hidden" name="shape" value="poly"/>
<input type="hidden" name="map" value="/ms4w/apps/GeoMOOSE/Maple_Grove_GeoMoose/select.map"/>
<input type="hidden" name="select" value="/ms4w/apps/GeoMOOSE/Maple_Grove_GeoMoose/select.map"/>
<input type="select" name="layer" title="Layer to Select:">
<option value="Parcels:PID">Parcels</option>
<option value="Plats:PLAT_ID">Plats</option>
<option value="Parcel_Points:PID_NO">Parcel Points</option>
</input>
<input type="hidden" name="output" value="html"/>
</service>
Select.map file
LAYER # Parcels Polygon Layer
NAME 'Parcels'
DATA 'parcels/parcels.shp'
STATUS ON
TYPE POLYGON
FILTERITEM 'PID'
FILTER /^%id%/
METADATA
qstring_validation_pattern '.'
END
HEADER 'parcels/select_header.html'
TEMPLATE 'parcels/select_parcel.html'
FOOTER 'parcels/select_footer.html'
TOLERANCE 0
CLASS
SYMBOL 'plainline'
SIZE 3
COLOR -1 -1 -1
OUTLINECOLOR 255 255 0
END
END
Select_parcel.html file
<tr>
<td><b>PID:</b></td>
<td>[PID]</td>
</tr>
<tr>
<td colspan="2"><hr/></td>
</tr>
Sent: Friday, May 22, 2009 9:15 AM
To: Jay Kapalczynski; geomoose-users at lists.sourceforge.net; geomoose-developers at lists.sourceforge.net
Subject: RE: [Geomoose-developers] Buffer Problems
There are intermittent issues with GM 1.6 is you are using that. I don't know if they would be related to this, but I'd highly recommend porting your work to GM 2 and give that a shot.
From: Jay Kapalczynski [mailto:jkapalczynski at ci.maple-grove.mn.us]
Sent: Friday, May 22, 2009 10:10 AM
To: geomoose-users at lists.sourceforge.net; geomoose-developers at lists.sourceforge.net
Subject: [Geomoose-developers] Buffer Problems
I have had this app running for some time now. I haven't touched anything in a few months.
I went back in and tried to do a buffer by line and am getting errors...I tried this on the other select buttons and the same error.
Nothing changed in my:
* Maple Grove_demo.xml
* Select.map
* Buffer_select.map
Why all of a sudden does the query not find the parcels?
Any thoughts?
FIREFOX:
<br />
<b>Warning</b>: [MapServer Error]: msQueryByShape(): No matching record(s) found.
in <b>C:\ms4w\apps\GeoMOOSE\htdocs\php\buffer_select.php</b> on line <b>139</b><br />
<html><head><title>Mailing Label Service Error</title></head><body><h3>Service Message</h3><b style='color
:red'>Query Failed to return any results!</b></body></html>
LINE 139:
# Perform the Query.
$queryResultCheck = $queryMap->queryByShape($shape);
if($queryResultCheck == MS_FAILURE) { # If the query fails, error out.
# Check to see if the Map has any pointers to an empty file
$empty = $queryMap->web->empty;
# If it's set then show that HTML instead. :D
if(isset($empty) and $empty != '') {
readfile($empty);
exit(0);
} else {
appError('Query Failed to return any results!');
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20090522/8692935f/attachment.html
More information about the Geomoose-users
