[Geomoose-users] feature editing - able to add polygons, not able to delete or edit..
Dan Little danlittle at yahoo.com
Mon Nov 16 09:21:38 EST 2009
Yes, that should be map-source.  I've send corrections ot the user who originally queried about this and it has prompted the need to update that code for the 2.2 release.
>From: Mark Volz <MarkVolz at co.lyon.mn.us>
>To: geomoose-users at lists.sourceforge.net
>Sent: Mon, November 16, 2009 8:15:23 AM
>Subject: [Geomoose-users] feature editing - able to add polygons, not able to delete or edit..
>Hello,
>I was working withthefeatureeditor.  I am able to add polygons, however I am not able to delete or edit any.  If I recall correctly for the edit and delete service reported a messagesimilarto“no feature id was found”.   Has anyone come across this issue, or know how to take care of it?
>I also noticed that some of the instructions inhttp://www.geomoose.org/moose/docs/feature_editor.htmlmay be incorrect or outdated.  Please check
>1.      Should this be map-source?
><map-service path="editor" type="mapserver">
>        <file>/var/www/geomoose2/maps/test_polygon/test_polygon.map</file>
>        <layer name="polygons"/>
></map-service>
>2.     Part of the modification to /css/user_tools.css has already been completed.
>Thanks
>Mark Volz
>GIS Specialist
>Lyon County, MN
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20091116/3896fc82/attachment.html
More information about the Geomoose-users mailing list
