[Geomoose-users] Curved labels and libgd or gd.
    FRANZ OKYERE
    franzzoa at hotmail.com
    Mon Nov 23 17:00:33 EST 2009
I'm using mapserver 2.3.1 and I see mapserv 5.2.1. Any recommendations?
Date: Mon, 23 Nov 2009 13:01:07 -0800
Subject: Re: [Geomoose-users] Curved labels and libgd or gd.
To: franzzoa at hotmail.com; geomoose-users at lists.sourceforge.net
What versions of MS4W/MapServer are you using?
To: geomoose-users at lists.sourceforge.net
Sent: Mon, November 23, 2009 2:58:33 PM
I've managed to check both error reports but the message in them is not specific. Eg- from the mozilla tools, internal server error, and from use error log, premature end of script headers (not sure what this means though). Any ideas why my label will not follow the line direction? Thanks.
Date: Mon, 23 Nov 2009 08:37:57 -0800
I find using Firefox's "Tools" -> "page Info" menu then looking in the media tab to be the easiest way to go.
You'll scroll down the list until you see the URL that refers to the image (which should be in italics to indicate it is "broken"), then copy the url and open it up in a new tab/window.
Sent: Mon, November 23, 2009 7:07:46 AM
Subject:
I'll try that and see how it goes.  Thanks.
> Date: Sun, 22 Nov 2009 20:43:50 -0700
> From: bfraser at geoanalytic.com
> CC: geomoose-users at lists.sourceforge.net
> That means Mapserver is not sending back an image (but is likely sending
> back an error message).  You could turn set DEBUG 5 in the LAYER (and
> you'll likely need to set the MAP's CONFIG MS_ERRORFILE
> "\ms4w\tmp\mserror.txt") to see if it reports a error.  Or you could use
> an HTTP sniffer like smartsniff to view the conversation between Geomoose
> and mapserver.
> Brent
> > Yes I use vera_sans which happens to be in the fontset.list but then the
> > background goes pinkish, you know.
> >> Date: Sun, 22 Nov 2009 14:44:27 -0700
 >> Subject: RE: [Geomoose-users] Curved labels and libgd or gd.
> >> Sounds like the problem is with TrueType fonts.  What do you specify for
> >> the font name?  Is it in the fonts\fontset.list?  What is your MAP ->
> >> FONTSET pointing to?
> >> > Yes Brent Here is portion of my map file that is supposed to do the
> >> lines
> >> > and the labels. The shapefile is of a line type.
> >> >   LAYER
> >> >     NAME 'demoroads2'
> >> >     TYPE LINE
> >> >     DATA 'C:\ms4w\apps\geomoose2\maps\demo\countydata\demoroads.shp'
> >> >     METADATA
> >> >       'wms_title' 'demoroads'
> >> >     END
 >> >     STATUS DEFAULT
> >> >     TRANSPARENCY 100
> >> >     PROJECTION
> >> >     'proj=longlat'
> >> >     'ellps=WGS84'
> >> >     'datum=WGS84'
> >> >     'no_defs'
> >> >     END
> >> > CLASS
> >> >   EXPRESSION ('[ROADCLASS]' eq 'C')
> >> >   STYLE
> >> >     COLOR 255 0 0
> >> >     SYMBOL 'plainline'
> >> >     SIZE 2
> >> >     MINSIZE 1
> >> >     MAXSIZE 4
> >> >   END
> >> > END
> >> > END
> >> > #and then I use an annotation layer to add the labels
> >> >         LAYER # Road layer
      NAME road_labels
> >> >         DATA
> >> >         STATUS ON
> >> >         TYPE annotation
> >> >         MAXSCALEDENOM 2834
> >> >         MINSCALEDENOM 1400
> >> >         LABELITEM 'ROAD_NAME'
> >> >         LABELCACHE ON
> >> >         CLASS
> >> >         LABEL
> >> >         COLOR 144 250 0
> >> >         BUFFER 4
> >> >         ANGLE AUTO
> >> >        END
> >> >          END
> >> > END  # End of Road layer
> >> > Now,
> >> > the above works fine and shows the lines and labels but once I add
> >> > ANGLE FOLLOW
 and/or TYPE TRUETYPE everything disappears. So what can I
> >> > do to see the labels whowing and following the line direction?
> >> > Cheers.
> >> > Franz Okyere.
> >> >  GIS Specialist
> >> >> Date: Sun, 22 Nov 2009 11:36:55 -0700
> >> >> libgd is not important to ANGLE FOLLOW (at least not that I'm aware
> >> of).
> >> >> Are your labels using a
 TrueType font (not bitmapped)?  When you say
> >> >> they
> >> >> don't align, does that mean they are only horizontal?  Are the layers
> >> >> you
> >> >> are trying to label TYPE LINE?
> >> >> Best Regards,
> >> >> Brent Fraser
> >> >> > Hi All, I need to find out whether I have libgd with my mapserver
> >> >> > installation- I'm using gm2 on ms2.3.1. as my labels don't align
> >> with
> >> >> my
> >> >> > line feature even after I have used angle follow in my mapfile.
> >> I've
> >> >> > downloaded the gd-2.0.33-1 binaries but honestly i'm not sure what
> >> i'm
> >> >> > doing with them. Can anyone help! Thanks. Franz Okyere.
 GIS
> >> >> SPECIALIST.
> >> >> > _________________________________________________________________
> >> >> > Got more than one Hotmail account? Save time by linking them
> >> together
> >> >> >  http://clk.atdmt.com/UKM/go/186394591/direct/01/
> >> >> > Let Crystal Reports handle the reporting - Free Crystal Reports
> >> 2008
> >> >> > 30-Day
> >> >> > trial. Simplify your report design, integration and deployment -
> >> and
> >> >> focus
> >> >> > on
> >> >> > what you do
 best, core
 application coding. Discover what's new with
> >> >> > Crystal Reports now.  http://p.sf.net/sfu/bobj-july
> >> >> > Geomoose-users mailing list
> >> >> > Geomoose-users at lists.sourceforge.net
> >> >> > https://lists.sourceforge.net/lists/listinfo/geomoose-users
> >> > Use Hotmail to send and receive mail from your different email
> >> accounts
> >> > http://clk.atdmt.com/UKM/go/186394592/direct/01/
> > Got more than one Hotmail account? Save time by linking them together
> > Let Crystal Reports handle the reporting - Free Crystal Reports 2008
> > 30-Day
> > trial. Simplify your report design, integration and deployment - and focus
> > on
> > what you do best, core application coding. Discover what's new with
View your other email accounts from your Hotmail inbox. Add them now.
Use Hotmail to send and receive mail from your different email accounts. Find out how.
Have more than one Hotmail account? Link them together to easily access both
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20091123/7c67f53c/attachment.html
More information about the Geomoose-users
