[Geomoose-users] Curved labels and libgd or gd.
    Brent Fraser
    bfraser at geoanalytic.com
    Mon Nov 23 20:01:48 EST 2009
Try copying shp2img into the cgi-bin dir and run it from the command line
> When I try to run shp2img an error message which says libmap.dll is
> missing shows up, but thats not true- libmap.dll exists in apache/cgi-bin.
> I guess may need to reinstall? Cheers.
>> Date: Mon, 23 Nov 2009 14:20:02 -0700
>> Subject: Re: [Geomoose-users] Curved labels and libgd or gd.
>> From: bfraser at geoanalytic.com
>> To: franzzoa at hotmail.com
>> CC: geomoose-users at lists.sourceforge.net
>> Yikes! That usually means mapserver crashed.  Try using the mapserver's
>> shp2img.exe on the command line with your map file to see if the
>> operating
>> system gives any more information (like missing DLLs).
>> > I've managed to check both error reports but the message in them is
>> not
>> > specific. Eg- from the mozilla tools, internal server error, and from
>> use
>> > error log, premature end of script headers (not sure what this means
>> > though). Any ideas why my label will not follow the line direction?
>> > Thanks.
>> > Date: Mon, 23 Nov 2009 08:37:57 -0800
>> > From: danlittle at yahoo.com
>> > To: franzzoa at hotmail.com; geomoose-users at lists.sourceforge.net
>> > I find using Firefox's "Tools" -> "page Info" menu then looking in the
>> > media tab to be the easiest way to go.
>> > You'll scroll down the list until you see the URL that refers to the
>> image
>> > (which should be in italics to indicate it is "broken"), then copy the
>> url
>> > and open it up in a new tab/window.
>> > From: FRANZ OKYERE <franzzoa at hotmail.com>
>> > To: geomoose-users at lists.sourceforge.net
>> > Sent: Mon, November 23, 2009 7:07:46 AM
>> > I'll try that and see how it goes.  Thanks.
>> >> Date: Sun, 22 Nov 2009 20:43:50 -0700
>> >> That means Mapserver is not sending back an image (but is likely
>> sending
>> >> back an error message).  You could turn set DEBUG 5 in the LAYER (and
>> >> you'll likely need to set the MAP's CONFIG MS_ERRORFILE
>> >> "\ms4w\tmp\mserror.txt") to see if it reports a error.  Or you could
>> use
>> >> an HTTP sniffer like smartsniff to view the conversation between
>> >> Geomoose
>> >> and mapserver.
>> >> Brent
>> >> > Yes I use vera_sans which happens to be in the fontset.list but
>> then
>> >> the
>> >> > background goes pinkish, you know.
>> >> >> Date: Sun, 22 Nov 2009 14:44:27 -0700
>> >  >> Subject: RE: [Geomoose-users] Curved labels and libgd or gd.
>> >> >> Sounds like the problem is with TrueType fonts.  What do you
>> specify
>> >> for
>> >> >> the font name?  Is it in the fonts\fontset.list?  What is your MAP
>> >> >> FONTSET pointing to?
>> >> >> > Yes Brent Here is portion of my map file that is supposed to do
>> the
>> >> >> lines
>> >> >> > and the labels. The shapefile is of a line type.
>> >> >> >   LAYER
>> >> >> >     NAME 'demoroads2'
>> >> >> >     TYPE LINE
>> >> >> >     DATA
>> >> 'C:\ms4w\apps\geomoose2\maps\demo\countydata\demoroads.shp'
>> >> >> >     METADATA
>> >> >> >       'wms_title' 'demoroads'
>> >> >> >     END
>> >  >> >     STATUS DEFAULT
>> >> >> >     TRANSPARENCY 100
>> >> >> >     PROJECTION
>> >> >> >     'proj=longlat'
>> >> >> >     'ellps=WGS84'
>> >> >> >     'datum=WGS84'
>> >> >> >     'no_defs'
>> >> >> >     END
>> >> >> > CLASS
>> >> >> >   EXPRESSION ('[ROADCLASS]' eq 'C')
>> >> >> >   STYLE
>> >> >> >     COLOR 255 0 0
>> >> >> >     SYMBOL 'plainline'
>> >> >> >     SIZE 2
>> >> >> >     MINSIZE 1
>> >> >> >     MAXSIZE 4
>> >> >> >   END
>> >> >> > END
>> >> >> > END
>> >> >> > #and then I use an annotation layer to add the labels
>> >> >> >         LAYER # Road layer
>> >       NAME road_labels
>> >> >> >         DATA
>> >> >> >         STATUS ON
>> >> >> >         TYPE annotation
>> >> >> >         MAXSCALEDENOM 2834
>> >> >> >         MINSCALEDENOM 1400
>> >> >> >         LABELITEM 'ROAD_NAME'
>> >> >> >         LABELCACHE ON
>> >> >> >         CLASS
>> >> >> >         LABEL
>> >> >> >         COLOR 144 250 0
>> >> >> >         BUFFER 4
>> >> >> >         ANGLE AUTO
>> >> >> >        END
>> >> >> >          END
>> >> >> > END  # End of Road layer
>> >> >> > Now,
>> >> >> > the above works fine and shows the lines and labels but once I
>> add
>> >> >> > ANGLE FOLLOW
>> >  and/or TYPE TRUETYPE everything disappears. So what can I
>> >> >> > do to see the labels whowing and following the line direction?
>> >> >> > Cheers.
>> >> >> > Franz Okyere.
>> >> >> >  GIS Specialist
>> >> >> >> Date: Sun, 22 Nov 2009 11:36:55 -0700
>> >> >> >> libgd is not important to ANGLE FOLLOW (at least not that I'm
>> >> aware
>> >> >> of).
>> >> >> >> Are your labels using a
>> >  TrueType font (not bitmapped)?  When you say
>> >> >> >> they
>> >> >> >> don't align, does that mean they are only horizontal?  Are the
>> >> layers
>> >> >> >> you
>> >> >> >> are trying to label TYPE LINE?
>> >> >> >> Best Regards,
>> >> >> >> Brent Fraser
>> >> >> >> > Hi All, I need to find out whether I have libgd with my
>> >> mapserver
>> >> >> >> > installation- I'm using gm2 on ms2.3.1. as my labels don't
>> align
>> >> >> with
>> >> >> >> my
>> >> >> >> > line feature even after I have used angle follow in my
>> mapfile.
>> >> >> I've
>> >> >> >> > downloaded the gd-2.0.33-1 binaries but honestly i'm not sure
>> >> what
>> >> >> i'm
>> >> >> >> > doing with them. Can anyone help! Thanks. Franz Okyere.
>> >  GIS
>> >> >> >> SPECIALIST.
>> >> >> >> > _________________________________________________________________
>> >> >> >> > Got more than one Hotmail account? Save time by linking them
>> >> >> together
>> >> >> >> >  http://clk.atdmt.com/UKM/go/186394591/direct/01/
>> >> >> >> > Let Crystal Reports handle the reporting - Free Crystal
>> Reports
>> >> >> 2008
>> >> >> >> > 30-Day
>> >> >> >> > trial. Simplify your report design, integration and
>> deployment -
>> >> >> and
>> >> >> >> focus
>> >> >> >> > on
>> >> >> >> > what you do best, core
>> >  application coding. Discover what's new with
>> >> >> >> > Crystal Reports now.  http://p.sf.net/sfu/bobj-july
>> >> >> >> > Geomoose-users mailing list
>> >> >> >> > Geomoose-users at lists.sourceforge.net
>> >> >> >> > https://lists.sourceforge.net/lists/listinfo/geomoose-users
>> >> >> > Use Hotmail to send and receive mail from your different email
>> >> >> accounts
>> >> >> > http://clk.atdmt.com/UKM/go/186394592/direct/01/
>> together
>> >> > Let Crystal Reports handle the reporting - Free Crystal Reports
>> 2008
>> >> > 30-Day
>> >> > trial. Simplify your report design, integration and deployment -
>> and
>> >> focus
>> >> > on
>> >> > what you do best, core application coding. Discover what's new with
>> > View your other email accounts from your Hotmail inbox. Add them now.
>> accounts
>> > Let Crystal Reports handle the reporting - Free Crystal Reports 2008
>> > 30-Day
>> > trial. Simplify your report design, integration and deployment - and
>> focus
>> > on
> Have more than one Hotmail account? Link them together to easily access
> both
> 30-Day
> trial. Simplify your report design, integration and deployment - and focus
> on
More information about the Geomoose-users
