[Geomoose-users] Curved labels and libgd or gd.
Brent Fraser
bfraser at geoanalytic.com
Tue Nov 24 09:45:39 EST 2009
You left out the "-o". The command should be:
Brent
FRANZ OKYERE wrote:
> Hi all,
> Its it a behaviour for the shp2img to produce some weird characters a@
> command prompt when I type
> or is there a problem with my syntax? Cheers
> Franz Okyere
> GIS Specialist
>> Date: Mon, 23 Nov 2009 18:01:48 -0700
>> Subject: Re: [Geomoose-users] Curved labels and libgd or gd.
>> From: bfraser at geoanalytic.com
>> To: franzzoa at hotmail.com
>> CC: geomoose-users at lists.sourceforge.net
>> Try copying shp2img into the cgi-bin dir and run it from the command line
>> > When I try to run shp2img an error message which says libmap.dll is
>> > missing shows up, but thats not true- libmap.dll exists in
> apache/cgi-bin.
>> > I guess may need to reinstall? Cheers.
>> >> Date: Mon, 23 Nov 2009 14:20:02 -0700
>> >> Yikes! That usually means mapserver crashed. Try using the mapserver's
>> >> shp2img.exe on the command line with your map file to see if the
>> >> operating
>> >> system gives any more information (like missing DLLs).
>> >> > I've managed to check both error reports but the message in them is
>> >> not
>> >> > specific. Eg- from the mozilla tools, internal server error, and from
>> >> use
>> >> > error log, premature end of script headers (not sure what this means
>> >> > though). Any ideas why my label will not follow the line direction?
>> >> > Thanks.
>> >> > Date: Mon, 23 Nov 2009 08:37:57 -0800
>> >> > From: danlittle at yahoo.com
>> >> > To: franzzoa at hotmail.com; geomoose-users at lists.sourceforge.net
>> >> > I find using Firefox's "Tools" -> "page Info" menu then looking
> in the
>> >> > media tab to be the easiest way to go.
>> >> > You'll scroll down the list until you see the URL that refers to the
>> >> image
>> >> > (which should be in italics to indicate it is "broken"), then
> copy the
>> >> url
>> >> > and open it up in a new tab/window.
>> >> > From: FRANZ OKYERE <franzzoa at hotmail.com>
>> >> > To: geomoose-users at lists.sourceforge.net
>> >> > Sent: Mon, November 23, 2009 7:07:46 AM
>> >> > I'll try that and see how it goes. Thanks.
>> >> >> Date: Sun, 22 Nov 2009 20:43:50 -0700
>> >> >> That means Mapserver is not sending back an image (but is likely
>> >> sending
>> >> >> back an error message). You could turn set DEBUG 5 in the LAYER (and
>> >> >> you'll likely need to set the MAP's CONFIG MS_ERRORFILE
>> >> >> "\ms4w\tmp\mserror.txt") to see if it reports a error. Or you could
>> >> use
>> >> >> an HTTP sniffer like smartsniff to view the conversation between
>> >> >> Geomoose
>> >> >> and mapserver.
>> >> >> Brent
>> >> >> > Yes I use vera_sans which happens to be in the fontset.list but
>> >> then
>> >> >> the
>> >> >> > background goes pinkish, you know.
>> >> >> >> Date: Sun, 22 Nov 2009 14:44:27 -0700
>> >> > >> Subject: RE: [Geomoose-users] Curved labels and libgd or gd.
>> >> >> >> Sounds like the problem is with TrueType fonts. What do you
>> >> specify
>> >> >> for
>> >> >> >> the font name? Is it in the fonts\fontset.list? What is your MAP
>> >> >> >> FONTSET pointing to?
>> >> >> >> > Yes Brent Here is portion of my map file that is supposed to do
>> >> the
>> >> >> >> lines
>> >> >> >> > and the labels. The shapefile is of a line type.
>> >> >> >> > LAYER
>> >> >> >> > NAME 'demoroads2'
>> >> >> >> > TYPE LINE
>> >> >> >> > DATA
>> >> >> 'C:\ms4w\apps\geomoose2\maps\demo\countydata\demoroads.shp'
>> >> >> >> > METADATA
>> >> >> >> > 'wms_title' 'demoroads'
>> >> >> >> > END
>> >> > >> > STATUS DEFAULT
>> >> >> >> > TRANSPARENCY 100
>> >> >> >> > PROJECTION
>> >> >> >> > 'proj=longlat'
>> >> >> >> > 'ellps=WGS84'
>> >> >> >> > 'datum=WGS84'
>> >> >> >> > 'no_defs'
>> >> >> >> > END
>> >> >> >> > CLASS
>> >> >> >> > EXPRESSION ('[ROADCLASS]' eq 'C')
>> >> >> >> > STYLE
>> >> >> >> > COLOR 255 0 0
>> >> >> >> > SYMBOL 'plainline'
>> >> >> >> > SIZE 2
>> >> >> >> > MINSIZE 1
>> >> >> >> > MAXSIZE 4
>> >> >> >> > END
>> >> >> >> > END
>> >> >> >> > END
>> >> >> >> > #and then I use an annotation layer to add the labels
>> >> >> >> > LAYER # Road layer
>> >> > NAME road_labels
>> >> >> >> > DATA
>> >> >> >> > STATUS ON
>> >> >> >> > TYPE annotation
>> >> >> >> > MAXSCALEDENOM 2834
>> >> >> >> > MINSCALEDENOM 1400
>> >> >> >> > LABELITEM 'ROAD_NAME'
>> >> >> >> > LABELCACHE ON
>> >> >> >> > CLASS
>> >> >> >> > LABEL
>> >> >> >> > COLOR 144 250 0
>> >> >> >> > BUFFER 4
>> >> >> >> > ANGLE AUTO
>> >> >> >> > END
>> >> >> >> > END
>> >> >> >> > END # End of Road layer
>> >> >> >> > Now,
>> >> >> >> > the above works fine and shows the lines and labels but once I
>> >> add
>> >> >> >> > ANGLE FOLLOW
>> >> > and/or TYPE TRUETYPE everything disappears. So what can I
>> >> >> >> > do to see the labels whowing and following the line direction?
>> >> >> >> > Cheers.
>> >> >> >> > Franz Okyere.
>> >> >> >> > GIS Specialist
>> >> >> >> >> Date: Sun, 22 Nov 2009 11:36:55 -0700
>> >> >> >> >> libgd is not important to ANGLE FOLLOW (at least not that I'm
>> >> >> aware
>> >> >> >> of).
>> >> >> >> >> Are your labels using a
>> >> > TrueType font (not bitmapped)? When you say
>> >> >> >> >> they
>> >> >> >> >> don't align, does that mean they are only horizontal? Are the
>> >> >> layers
>> >> >> >> >> you
>> >> >> >> >> are trying to label TYPE LINE?
>> >> >> >> >> Best Regards,
>> >> >> >> >> Brent Fraser
>> >> >> >> >> > Hi All, I need to find out whether I have libgd with my
>> >> >> mapserver
>> >> >> >> >> > installation- I'm using gm2 on ms2.3.1. as my labels don't
>> >> align
>> >> >> >> with
>> >> >> >> >> my
>> >> >> >> >> > line feature even after I have used angle follow in my
>> >> mapfile.
>> >> >> >> I've
>> >> >> >> >> > downloaded the gd-2.0.33-1 binaries but honestly i'm not
> sure
>> >> >> what
>> >> >> >> i'm
>> >> >> >> >> > doing with them. Can anyone help! Thanks. Franz Okyere.
>> >> > GIS
>> >> >> >> >> SPECIALIST.
> _________________________________________________________________
>> >> >> >> >> > Got more than one Hotmail account? Save time by linking them
>> >> >> >> together
>> >> >> >> >> > http://clk.atdmt.com/UKM/go/186394591/direct/01/
>> >> >> >> >> > Let Crystal Reports handle the reporting - Free Crystal
>> >> Reports
>> >> >> >> 2008
>> >> >> >> >> > 30-Day
>> >> >> >> >> > trial. Simplify your report design, integration and
>> >> deployment -
>> >> >> >> and
>> >> >> >> >> focus
>> >> >> >> >> > on
>> >> >> >> >> > what you do best, core
>> >> > application coding. Discover what's new with
>> >> >> >> >> > Crystal Reports now. http://p.sf.net/sfu/bobj-july
>> >> >> >> >> > Geomoose-users mailing list
>> >> >> >> >> > Geomoose-users at lists.sourceforge.net
>> >> >> >> >> > https://lists.sourceforge.net/lists/listinfo/geomoose-users
>> >> >> >> > Use Hotmail to send and receive mail from your different email
>> >> >> >> accounts
>> >> >> >> > http://clk.atdmt.com/UKM/go/186394592/direct/01/
>> >> together
>> >> >> > Let Crystal Reports handle the reporting - Free Crystal Reports
>> >> 2008
>> >> >> > 30-Day
>> >> >> > trial. Simplify your report design, integration and deployment -
>> >> and
>> >> >> focus
>> >> >> > on
>> >> >> > what you do best, core application coding. Discover what's new
> with
>> >> > View your other email accounts from your Hotmail inbox. Add them now.
>> >> accounts
>> >> > Let Crystal Reports handle the reporting - Free Crystal Reports 2008
>> >> > 30-Day
>> >> > trial. Simplify your report design, integration and deployment - and
>> >> focus
>> >> > on
>> >> > what you do best, core application coding. Discover what's new with
>> > Have more than one Hotmail account? Link them together to easily access
>> > both
>> > 30-Day
> focus
>> > on
> New! Receive and respond to mail from other email accounts from within
> Hotmail Find out how. <http://clk.atdmt.com/UKM/go/186394593/direct/01/ >
More information about the Geomoose-users
