[Geomoose-users] IE will not display identify results
Dan Little
danlittle at yahoo.com
Tue Nov 24 11:35:53 EST 2009
I will need to be writing a patch and setting up a testing environment. :-) I don't think any of my VM's are currently running IE8...
>From: "Edward E. Boesenberg, III" <eboesenberg at niraengineers.com>
>To: Dan Little <danlittle at yahoo.com>; Geomoose Support <geomoose-users at lists.sourceforge.net>
>Sent: Tue, November 24, 2009 10:35:13 AM
>Subject: RE: [Geomoose-users] IE will not display identify results
>Sorry,
>IE8 and GM 2.0
>From:Dan Little
>[mailto:danlittle at yahoo.com]
>Sent: Tuesday, November 24, 2009 11:26 AM
>To: Edward E. Boesenberg, III; Geomoose Support
>Subject: Re: [Geomoose-users] IE will not display identify results
>IE8?
>2.0, 2.0.1, SVN-Trunk?
>>From:"Edward E. Boesenberg, III"
>>To: Geomoose Support <geomoose-users at lists.sourceforge.net>
>>Sent: Tue, November 24, 2009 10:26:34 AM
>>Subject: [Geomoose-users] IE will not display identify results
>>When I use the identify function in IE nothing happens but
>>it works fine if FF. When I double click the yellow error sign I get the
>>error box with a message below. It displays the map fine. Anyboby
>>know how to fix this error?
>>Webpage error details
>>User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT
>>5.1; Trident/4.0; .NET CLR 1.1.4322; .NET CLR 2.0.50727; .NET CLR 3.0.04506.30;
>>.NET CLR 3.0.04506.648; .NET CLR 3.5.21022; .NET CLR 3.0.4506.2152; .NET CLR
>>3.5.30729; MS-RTC LM 8)
>>Timestamp: Tue, 24 Nov 2009 16:24:46 UTC
>>Message: Can't move focus to the control because it is
>>invisible, not enabled, or of a type that does not accept the focus.
>>Line: 3496
>>Char: 5
>>Code: 0
>>URI: http://nira-server/geomoose2/compiled.js
>>Thanks,
>>CADD / GIS Manager
>>Nira Consulting Engineers, Inc.
>>950 Fifth Avenue
>>Coraopolis, PA 15108
>>www.niraengineers.com
>>T: 412-262-3970
>>F: 412-262-1938
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20091124/70563cc6/attachment.html
More information about the Geomoose-users
