[Geomoose-users] IE will not display identify results
Brent Fraser
bfraser at geoanalytic.com
Tue Nov 24 12:20:52 EST 2009
Hmm. I get the same error generated on my site with IE8, but GeoMoose still
shows my Identify results. Perhaps there's more than one problem on your site.
Geomoose may be getting the results, but IE8/7 is not rendering the HTML?
Brent
Edward E. Boesenberg, III wrote:
> I tested it with another client machine running IE7 and got the same
> result, nothing happened.
> *From:* Dan Little [mailto:danlittle at yahoo.com]
> *Sent:* Tuesday, November 24, 2009 11:36 AM
> *To:* Edward E. Boesenberg, III; Geomoose Support
> *Subject:* Re: [Geomoose-users] IE will not display identify results
> I will need to be writing a patch and setting up a testing environment.
> :-) I don't think any of my VM's are currently running IE8...
> *From:* "Edward E. Boesenberg, III" <eboesenberg at niraengineers.com>
> *To:* Dan Little <danlittle at yahoo.com>; Geomoose Support
> <geomoose-users at lists.sourceforge.net>
> *Sent:* Tue, November 24, 2009 10:35:13 AM
> *Subject:* RE: [Geomoose-users] IE will not display identify results
> Sorry,
> IE8 and GM 2.0
> *Sent:* Tuesday, November 24, 2009 11:26 AM
> IE8? 2.0, 2.0.1, SVN-Trunk?
> *To:* Geomoose Support <geomoose-users at lists.sourceforge.net>
> *Sent:* Tue, November 24, 2009 10:26:34 AM
> *Subject:* [Geomoose-users] IE will not display identify results
> When I use the identify function in IE nothing happens but it
> works fine if FF. When I double click the yellow error sign I
> get the error box with a message below. It displays the map
> fine. Anyboby know how to fix this error?
> Webpage error details
> User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1;
> Trident/4.0; .NET CLR 1.1.4322; .NET CLR 2.0.50727; .NET CLR
> 3.0.04506.30; .NET CLR 3.0.04506.648; .NET CLR 3.5.21022; .NET
> CLR 3.0.4506.2152; .NET CLR 3.5.30729; MS-RTC LM 8)
> Timestamp: Tue, 24 Nov 2009 16:24:46 UTC
> Message: Can't move focus to the control because it is
> invisible, not enabled, or of a type that does not accept the focus.
> Line: 3496
> Char: 5
> Code: 0
> URI: http://nira-server/geomoose2/compiled.js
> Thanks,
> CADD / GIS Manager
> Nira Consulting Engineers, Inc.
> 950 Fifth Avenue
> Coraopolis, PA 15108
> www.niraengineers.com <http://www.niraengineers.com>
> T: 412-262-3970
> F: 412-262-1938
> Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
> trial. Simplify your report design, integration and deployment - and focus on
> what you do best, core application coding. Discover what's new with
> Crystal Reports now. http://p.sf.net/sfu/bobj-july
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users
