[Geomoose-users] Curved labels and libgd or gd.
FRANZ OKYERE franzzoa at hotmail.com
Tue Nov 24 14:12:12 EST 2009
The labels display horizontally. Thanks for the info on the dlls too.
> Date: Tue, 24 Nov 2009 09:11:16 -0700
> From: bfraser at geoanalytic.com
> To: franzzoa at hotmail.com
> CC: geomoose-users at lists.sourceforge.net
> Subject: Re: [Geomoose-users] Curved labels and libgd or gd.
> Did the labels appear at all? Were they only horizontal?  I'm not sure what you
> mean by "like it should".  The ANGLE FOLLOW setting was originally intended for
> labeling along road segments; it currently does a poor job of labeling streams
> with lots of twists and turns.  And there are a few issues filed against it in
> Maperver's Trac.
> As for the loading of DLLs by mapserv.exe, a good tool to use is ProcessMonitor
> (http://technet.microsoft.com/en-us/sysinternals/bb896645.aspx).  Run it on the
> server when you do a pan or zoom to see which DLLs mapserv.exe is try to load.
> Best regards,
> Brent Fraser
> FRANZ OKYERE wrote:
> > Its  worked alright, the op system didn't show any errors and angle
> > follow does not curve my labels like it should. But I suspect there's
> > something wrong with my windows installation such that certain dlls
> > can't be accessed on the expected path? I may be wrong but I wish
> > it  were working, seriously.  Franz Okyere. GIS specialist
> >> Date: Tue, 24 Nov 2009 07:45:39 -0700
> >> You left out the "-o". The command should be:
> >> Brent
> >> FRANZ OKYERE wrote:
> >>  > Hi all,
> >>  > Its it a behaviour for the shp2img to produce some weird characters a@
> >>  > command prompt when I type
> >>  > or is there a problem with my syntax? Cheers
> >>  > Franz Okyere
> >>  > GIS Specialist
> >>  >> Date: Mon, 23 Nov 2009 18:01:48 -0700
> >>  >> Try copying shp2img into the cgi-bin dir and run it from the command
> > line
> >>  >> > When I try to run shp2img an error message which says libmap.dll is
> >>  >> > missing shows up, but thats not true- libmap.dll exists in
> >>  > apache/cgi-bin.
> >>  >> > I guess may need to reinstall? Cheers.
> >>  >> >> Date: Mon, 23 Nov 2009 14:20:02 -0700
> >>  >> >> Yikes! That usually means mapserver crashed. Try using the
> > mapserver's
> >>  >> >> shp2img.exe on the command line with your map file to see if the
> >>  >> >> operating
> >>  >> >> system gives any more information (like missing DLLs).
> >>  >> >> > I've managed to check both error reports but the message in them is
> >>  >> >> not
> >>  >> >> > specific. Eg- from the mozilla tools, internal server error,
> > and from
> >>  >> >> use
> >>  >> >> > error log, premature end of script headers (not sure what this
> > means
> >>  >> >> > though). Any ideas why my label will not follow the line direction?
> >>  >> >> > Thanks.
> >>  >> >> > Date: Mon, 23 Nov 2009 08:37:57 -0800
> >>  >> >> > From: danlittle at yahoo.com
> >>  >> >> > To: franzzoa at hotmail.com; geomoose-users at lists.sourceforge.net
> >>  >> >> > I find using Firefox's "Tools" -> "page Info" menu then looking
> >>  > in the
> >>  >> >> > media tab to be the easiest way to go.
> >>  >> >> > You'll scroll down the list until you see the URL that refers
> > to the
> >>  >> >> image
> >>  >> >> > (which should be in italics to indicate it is "broken"), then
> >>  > copy the
> >>  >> >> url
> >>  >> >> > and open it up in a new tab/window.
> >>  >> >> > From: FRANZ OKYERE <franzzoa at hotmail.com>
> >>  >> >> > To: geomoose-users at lists.sourceforge.net
> >>  >> >> > Sent: Mon, November 23, 2009 7:07:46 AM
> >>  >> >> > I'll try that and see how it goes. Thanks.
> >>  >> >> >> Date: Sun, 22 Nov 2009 20:43:50 -0700
> >>  >> >> >> That means Mapserver is not sending back an image (but is likely
> >>  >> >> sending
> >>  >> >> >> back an error message). You could turn set DEBUG 5 in the
> > LAYER (and
> >>  >> >> >> you'll likely need to set the MAP's CONFIG MS_ERRORFILE
> >>  >> >> >> "\ms4w\tmp\mserror.txt") to see if it reports a error. Or you
> > could
> >>  >> >> use
> >>  >> >> >> an HTTP sniffer like smartsniff to view the conversation between
> >>  >> >> >> Geomoose
> >>  >> >> >> and mapserver.
> >>  >> >> >> Brent
> >>  >> >> >> > Yes I use vera_sans which happens to be in the fontset.list but
> >>  >> >> then
> >>  >> >> >> the
> >>  >> >> >> > background goes pinkish, you know.
> >>  >> >> >> >> Date: Sun, 22 Nov 2009 14:44:27 -0700
> >>  >> >> > >> Subject: RE: [Geomoose-users] Curved labels and libgd or gd.
> >>  >> >> >> >> Sounds like the problem is with TrueType fonts. What do you
> >>  >> >> specify
> >>  >> >> >> for
> >>  >> >> >> >> the font name? Is it in the fonts\fontset.list? What is
> > your MAP
> >>  >> >> >> >> FONTSET pointing to?
> >>  >> >> >> >> > Yes Brent Here is portion of my map file that is supposed
> > to do
> >>  >> >> the
> >>  >> >> >> >> lines
> >>  >> >> >> >> > and the labels. The shapefile is of a line type.
> >>  >> >> >> >> > LAYER
> >>  >> >> >> >> > NAME 'demoroads2'
> >>  >> >> >> >> > TYPE LINE
> >>  >> >> >> >> > DATA
> >>  >> >> >> 'C:\ms4w\apps\geomoose2\maps\demo\countydata\demoroads.shp'
> >>  >> >> >> >> > METADATA
> >>  >> >> >> >> > 'wms_title' 'demoroads'
> >>  >> >> >> >> > END
> >>  >> >> > >> > STATUS DEFAULT
> >>  >> >> >> >> > TRANSPARENCY 100
> >>  >> >> >> >> > PROJECTION
> >>  >> >> >> >> > 'proj=longlat'
> >>  >> >> >> >> > 'ellps=WGS84'
> >>  >> >> >> >> > 'datum=WGS84'
> >>  >> >> >> >> > 'no_defs'
> >>  >> >> >> >> > END
> >>  >> >> >> >> > CLASS
> >>  >> >> >> >> > EXPRESSION ('[ROADCLASS]' eq 'C')
> >>  >> >> >> >> > STYLE
> >>  >> >> >> >> > COLOR 255 0 0
> >>  >> >> >> >> > SYMBOL 'plainline'
> >>  >> >> >> >> > SIZE 2
> >>  >> >> >> >> > MINSIZE 1
> >>  >> >> >> >> > MAXSIZE 4
> >>  >> >> >> >> > END
> >>  >> >> >> >> > END
> >>  >> >> >> >> > END
> >>  >> >> >> >> > #and then I use an annotation layer to add the labels
> >>  >> >> >> >> > LAYER # Road layer
> >>  >> >> > NAME road_labels
> >>  >> >> >> >> > DATA
> >>  >> >> >> >> > STATUS ON
> >>  >> >> >> >> > TYPE annotation
> >>  >> >> >> >> > MAXSCALEDENOM 2834
> >>  >> >> >> >> > MINSCALEDENOM 1400
> >>  >> >> >> >> > LABELITEM 'ROAD_NAME'
> >>  >> >> >> >> > LABELCACHE ON
> >>  >> >> >> >> > CLASS
> >>  >> >> >> >> > LABEL
> >>  >> >> >> >> > COLOR 144 250 0
> >>  >> >> >> >> > BUFFER 4
> >>  >> >> >> >> > ANGLE AUTO
> >>  >> >> >> >> > END
> >>  >> >> >> >> > END
> >>  >> >> >> >> > END # End of Road layer
> >>  >> >> >> >> > Now,
> >>  >> >> >> >> > the above works fine and shows the lines and labels but
> > once I
> >>  >> >> add
> >>  >> >> >> >> > ANGLE FOLLOW
> >>  >> >> > and/or TYPE TRUETYPE everything disappears. So what can I
> >>  >> >> >> >> > do to see the labels whowing and following the line
> > direction?
> >>  >> >> >> >> > Cheers.
> >>  >> >> >> >> > Franz Okyere.
> >>  >> >> >> >> > GIS Specialist
> >>  >> >> >> >> >> Date: Sun, 22 Nov 2009 11:36:55 -0700
> >>  >> >> >> >> >> libgd is not important to ANGLE FOLLOW (at least not
> > that I'm
> >>  >> >> >> aware
> >>  >> >> >> >> of).
> >>  >> >> >> >> >> Are your labels using a
> >>  >> >> > TrueType font (not bitmapped)? When you say
> >>  >> >> >> >> >> they
> >>  >> >> >> >> >> don't align, does that mean they are only horizontal?
> > Are the
> >>  >> >> >> layers
> >>  >> >> >> >> >> you
> >>  >> >> >> >> >> are trying to label TYPE LINE?
> >>  >> >> >> >> >> Best Regards,
> >>  >> >> >> >> >> Brent Fraser
> >>  >> >> >> >> >> > Hi All, I need to find out whether I have libgd with my
> >>  >> >> >> mapserver
> >>  >> >> >> >> >> > installation- I'm using gm2 on ms2.3.1. as my labels don't
> >>  >> >> align
> >>  >> >> >> >> with
> >>  >> >> >> >> >> my
> >>  >> >> >> >> >> > line feature even after I have used angle follow in my
> >>  >> >> mapfile.
> >>  >> >> >> >> I've
> >>  >> >> >> >> >> > downloaded the gd-2.0.33-1 binaries but honestly i'm not
> >>  > sure
> >>  >> >> >> what
> >>  >> >> >> >> i'm
> >>  >> >> >> >> >> > doing with them. Can anyone help! Thanks. Franz Okyere.
> >>  >> >> > GIS
> >>  >> >> >> >> >> SPECIALIST.
> >>  > _________________________________________________________________
> >>  >> >> >> >> >> > Got more than one Hotmail account? Save time by
> > linking them
> >>  >> >> >> >> together
> >>  >> >> >> >> >> > http://clk.atdmt.com/UKM/go/186394591/direct/01/
> >>  >> >> >> >> >> > Let Crystal Reports handle the reporting - Free Crystal
> >>  >> >> Reports
> >>  >> >> >> >> 2008
> >>  >> >> >> >> >> > 30-Day
> >>  >> >> >> >> >> > trial. Simplify your report design, integration and
> >>  >> >> deployment -
> >>  >> >> >> >> and
> >>  >> >> >> >> >> focus
> >>  >> >> >> >> >> > on
> >>  >> >> >> >> >> > what you do best, core
> >>  >> >> > application coding. Discover what's new with
> >>  >> >> >> >> >> > Crystal Reports now. http://p.sf.net/sfu/bobj-july
> >>  >> >> >> >> >> > Geomoose-users mailing list
> >>  >> >> >> >> >> > Geomoose-users at lists.sourceforge.net
> > https://lists.sourceforge.net/lists/listinfo/geomoose-users
> >>  >> >> >> >> > Use Hotmail to send and receive mail from your different
> > email
> >>  >> >> >> >> accounts
> >>  >> >> >> >> > http://clk.atdmt.com/UKM/go/186394592/direct/01/
> >>  >> >> >> > Got more than one Hotmail account? Save time by linking them
> >>  >> >> together
> >>  >> >> >> > Let Crystal Reports handle the reporting - Free Crystal Reports
> >>  >> >> 2008
> >>  >> >> >> > 30-Day
> >>  >> >> >> > trial. Simplify your report design, integration and deployment -
> >>  >> >> and
> >>  >> >> >> focus
> >>  >> >> >> > on
> >>  >> >> >> > what you do best, core application coding. Discover what's new
> >>  > with
> >>  >> >> > View your other email accounts from your Hotmail inbox. Add
> > them now.
> >>  >> >> > Use Hotmail to send and receive mail from your different email
> >>  >> >> accounts
> > 2008
> >>  >> >> > 30-Day
> > - and
> >>  >> >> focus
> >>  >> >> > on
> >>  >> >> > what you do best, core application coding. Discover what's new with
> >>  >> > Have more than one Hotmail account? Link them together to easily
> > access
> >>  >> > both
> >>  >> > Let Crystal Reports handle the reporting - Free Crystal Reports 2008
> >>  >> > 30-Day
> >>  >> > trial. Simplify your report design, integration and deployment - and
> >>  > focus
> >>  >> > on
> >>  > New! Receive and respond to mail from other email accounts from within
> >>  > Hotmail Find out how. <http://clk.atdmt.com/UKM/go/186394593/direct/01/ >
> > View your other email accounts from your Hotmail inbox. Add them now.
> > <http://clk.atdmt.com/UKM/go/186394592/direct/01/>
> > Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
> > trial. Simplify your report design, integration and deployment - and focus on
Use Hotmail to send and receive mail from your different email accounts
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20091124/968e3819/attachment.html
More information about the Geomoose-users mailing list
