[Geomoose-users] Parcel Report
Len Kne lkne at houstoneng.com
Fri Sep 4 12:37:00 EDT 2009
Check geomoose2/conf/feature_report/parcel.xml.  There are two references to PIN that need to be changed to your attribute name.
Len
From: Matthew D. Syvertson [mailto:msyvertson at co.richland.nd.us]
Sent: Friday, September 04, 2009 11:19 AM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] Parcel Report
Any idea what might be causing the following error that I am receiving when trying to print a parcel report?:
Warning: [MapServer Error]: msDBFGetItemIndex(): Item 'PIN' not found. in C:\ms4w\apps\geomoose2\htdocs\php\feature_report.php on line 64 Warning: [MapServer Error]: msDrawMap(): Failed to draw layer named 'parcels'. in C:\ms4w\apps\geomoose2\htdocs\php\feature_report.php on line 96 Warning: [MapServer Error]: msDBFGetItemIndex(): Item 'PIN' not found. in C:\ms4w\apps\geomoose2\htdocs\php\feature_report.php on line 96 Warning: [MapServer Error]: msDBFGetItemIndex(): Item 'PIN' not found. in C:\ms4w\apps\geomoose2\htdocs\php\feature_report.php on line 96 Fatal error: Call to a member function saveImage() on a non-object in C:\ms4w\apps\geomoose2\htdocs\php\feature_report.php on line 101
Thanks in advance.
Matt Syvertson
Richland County GIS Coordinator
418 2nd Ave N
Wahpeton, ND 58075
msyvertson at co.richland.nd.us<mailto:matthews at co.richland.nd.us>
Voice: 701-642-7860  Fax: 701-642-7746
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20090904/0997b934/attachment.html
More information about the Geomoose-users mailing list
