[Geomoose-users] GM2: Popup error when using "layer name="all"
CoFIS Web
coffee at uni-bonn.de
Tue Sep 8 05:37:50 EDT 2009
Dear all,
When enabling popups I get an error (see end of post) when using the service
- on a layer that is not set up for popups or
- a layer that is defined using '<layer name="all"/>'
Example:
<map-source name="administration" type="mapserver" reference="true">
<file>./administration.map</file>
<layer name="all" reference="true"/>
</map-source>
gives an error.
Using the same mapfile and specifying layers individually works fine:
<map-source name="administration01" type="mapserver" reference="true">
<layer name="wereda" reference="true"/>
</map-source>
=> gives me nice popups for the "wereda" layer.
Any suggestions how to make popups work using '<layer name="all"/>' instead?
Thanks Nils
Error message:
Warning: [MapServer Error]: msQueryByPoint(): No matching record(s)
found. in /srv/www/geomoose/2.0.dev/htdocs/php/popups.php on line 72
Warning: Cannot modify header information - headers already sent by
(output started at /srv/www/geomoose/2.0.dev/htdocs/php/popups.php:72)
in /srv/www/geomoose/2.0.dev/htdocs/php/popups.php on line 93
Center for Development Research
Department of Ecology and Resource Management
Walter-Flex-Strasse 3
53113 Bonn (Germany)
Tel.: +49 (0) 228 - 73-1793
FAX: +49 (0) 228 - 73-1889
E-Mail: coffee at uni-bonn.de
Web: http://www.cofis.info/atlas
http://www.coffee.uni-bonn.de
More information about the Geomoose-users
