[Geomoose-users] Geomoose resolution.
Brent Fraser
bfraser at geoanalytic.com
Sat Sep 12 16:02:55 EDT 2009
If you mean the map portion looks too blocky or pixelated compared to the
source imagery, you may want to use PNG or JPG as a MapServer
OUTPUTFORMAT.
Brent Fraser
> My geomoose looks too course. Pls anyone can tell me which parameter to
> use to make it finer? Thanks. Franz. GIS
> Lecturer.
>> Date: Fri, 11 Sep 2009 16:47:14 -0600
>> From: bfraser at geoanalytic.com
>> To: piernotd at uwplatt.edu
>> CC: geomoose-users at lists.sourceforge.net
>> Subject: Re: [Geomoose-users] geomoose2 for IIS
>> The configuration looks ok. What's not working?
>> > Hey everyone,
>> > I'm trying (unsuccessfully) to migrate my geomoose 2.0 application
>> from
>> > my pc to a microsoft virtual dedicated server through go-daddy.
>> > http://www.geomoose.org/moose/docs/install_ms4w.html
>> > http://mapserver.org/installation/iis.html
>> > These two links provide some guidance, but are they slightly out of
>> date?
>> > Here are my current application specs:
>> > ms4w_2.3.1
>> > geomoose-2.0-MS4W
>> > ...and server:
>> > OS: Widows Server 2003
>> > with IIS 6.0
>> > I'm familiar with mapfiles and the cartographic side of mapserver
>> > applications, but my website skills are seriously lacking. Right now
>> > I'm using esri shapefile data for all mapfiles and I've only
>> implemented
>> > basic query functionality. I've applied the Wisconsin Transverse
>> > Mercator projection for everything
>> > http://www.spatialreference.org/ref/epsg/3071/ but I doubt that
>> matters
>> > much here.
>> > p.s. is it even worth it? i.e. should I try to cancel this and go
>> with
>> > a linux virtual dedicated server instead?
>> > Thank you in advance for any help.
>> > Devon Piernot
>> > GIS / Web Developer
>> > Southwestern Wisconsin Regional Planning Commission
>> > (608) 342-6065
>> > www.swwrpc.org
>> > Let Crystal Reports handle the reporting - Free Crystal Reports 2008
>> > 30-Day
>> > trial. Simplify your report design, integration and deployment - and
>> focus
>> > on
>> > what you do best, core application coding. Discover what's new with
>> > Crystal Reports now. http://p.sf.net/sfu/bobj-july
>> > _______________________________________________
>> > Geomoose-users mailing list
>> > Geomoose-users at lists.sourceforge.net
>> > https://lists.sourceforge.net/lists/listinfo/geomoose-users
>> 30-Day
>> focus on
> _________________________________________________________________
> Learn how to add other email accounts to Hotmail in 3 easy steps.
> http://clk.atdmt.com/UKM/go/167688463/direct/01/
> 30-Day
> trial. Simplify your report design, integration and deployment - and focus
> on
More information about the Geomoose-users
