[Geomoose-users] Legend for raster layers
Bob Basques
Bob.Basques at ci.stpaul.mn.us
Wed Sep 16 11:22:42 EDT 2009
Vojko,
I don't believe that Raster layers have a Legend output option from MapServer, designated by the TYPE RASTER line in the mapfile. You can however make a dummy layer explicitly for generating a Legend entry. This dummy layer can be of some other type besides RASTER for example.
The next issue would be how to insert the legend graphic that you have predefined into the legend request. Since GEOMoose uses the mode=<something> parameter to request thing from mapserver, the typical legend is requested via the mode=legend process. This only works with the legend being defined in the same mapfile as the one that is used to generate the map image for the same layer.
I do see in the doc for MapServer CGI http://mapserver.org/cgi/controls.html, ( http://mapserver.org/cgi/controls.html, ) that there is a LEGENDICON value option for the MODE parameter, but I don't think this is being used by GeoMoose currently. But it might be a good approach to follow moving forward on this. I've never used this myself.
There is no way that I know of currently to specify a predefined image in the LEGEND block in the mapfile. I did find a KEYIMAGE option in the CLASS help docs on the mapserver site. http://mapserver.org/mapfile/class.html?highlight=icon ( http://mapserver.org/mapfile/class.html?highlight=icon ) This might be a way forward too. But I don't know that it will get around the TYPE RASTER thing for sure either.
bobb
>>> "Vojko Daneu" <vojko.daneu at mail.telepac.pt> wrote:
Hallo,
showing the legend of vector layers works without any problems in GeoMoose 1.6.
In my application I have a raster layer for which I want also to show a legend in the side panel. To do so I have created a html-template with a legend image and some legend text. How do I show the template in the side panel?
Here is my map-file, but it does not show the template ...
MAP
NAME 'mn_wind'
SIZE 800 650
STATUS ON
EXTENT 391510 5935905 391710 5936205
UNITS METERS
IMAGETYPE PNG
TRANSPARENT TRUE
LEGEND
STATUS ON
END
LAYER
NAME 'Wind Velocity'
DATA '00008_wind.png'
TYPE RASTER
STATUS DEFAULT
CLASS
TEMPLATE 'test.html'
END
END
END
Thanks,
Vojko
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20090916/22141c56/attachment.html
More information about the Geomoose-users
