[Geomoose-users] Help with querybyAttribute function! Help
FRANZ OKYERE franzzoa at hotmail.com
Sun Sep 20 01:03:24 EDT 2009
Sorry about that. Its like this. ...some code... $querystring="(($field1=$userv1) or ($field2=$userv2))";      $queryLayer->querybyattributes($ques, $querystring,MS_MULTIPLE);  $ques is one of my attributes and field and userv in the expression are replaced with the attribute and a user supplied string. When will the method, why the errors? I hope it helps. Cheers Brent.
> Date: Sat, 19 Sep 2009 19:47:16 -0600
> Subject: Re: [Geomoose-users] Help with querybyAttribute function! Help
> From: bfraser at geoanalytic.com
> To: franzzoa at hotmail.com
> CC: geomoose-users at lists.sourceforge.net
> Franz,
>   Did attach your sample?
> Brent
> > Dear all,
> > I have done comprehensive search and reading on how to use the
> > querybyAttributes php mapscript function to evaluate a logical expression.
> > It looks to me no one seems to find a solution to the errors that  come
> > up. The problem is that there are so many suggestions on the syntax.
> > Please, please, can someone do all of us a favour and explain to us what
> > exactly is the right and working way to use the querybyAttribute (I am
> > using GM 2- does it matter). Here is a sample of how I am using it and I
> > have tried a thousand different combinations of code. Please what is wrong
> > so we (the geomoose users) can move on.
> > Thanks a million.
> > Franz Okyere
> > Lecturer/GIS Specialist
> > _________________________________________________________________
> > Get the best of MSN on your mobile
> > http://clk.atdmt.com/UKM/go/147991039/direct/01/
> > Come build with us! The BlackBerry® Developer Conference in SF, CA
> > is the only developer event you need to attend this year. Jumpstart your
> > developing skills, take BlackBerry mobile applications to market and stay
> > ahead of the curve. Join us from November 9-12, 2009. Register
> > now!
> > http://p.sf.net/sfu/devconf
> > Geomoose-users mailing list
> > Geomoose-users at lists.sourceforge.net
> > https://lists.sourceforge.net/lists/listinfo/geomoose-users
With Windows Live, you can organise, edit, and share your photos.
http://clk.atdmt.com/UKM/go/134665338/direct/01/
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20090920/77b82804/attachment.html
More information about the Geomoose-users mailing list
