[Geomoose-users] [Geomoose-developers] Bing Maps integration
Bob Basques Bob.Basques at ci.stpaul.mn.us
Tue Sep 22 14:52:25 EDT 2009
Jay,
Here are three different MapFiles for reprojecting the BING map data to
Our coordinate system (Ramsey County [Yes it's a custom projection])
Should give you an idea of how to use MapServer to do the reprojection
on the WMS from the BING server for your own uses.  If you want to use a
generic and BING compatible projection, just run a WMS getCapabilities
against their server to find out what they can export for, on of which
is EPSG:4326, these are from their beta service.
#1  BING Aerial layer
MAP
  NAME 'BINGAERIAL'
  SIZE 800 650
  EXTENT 593133.398829 170094.734526 593893.148973 170712.010326
  STATUS ON
  UNITS FEET
  IMAGETYPE JPEG
  PROJECTION
"init=epsg:200068"
  END
  LAYER
    NAME "BINGAERIAL"
    TYPE RASTER
    STATUS DEFAULT
    CONNECTION "http://integrate.onterrasys.com/BingMapsWMS/? (
http://integrate.onterrasys.com/BingMapsWMS/? )"
    CONNECTIONTYPE WMS
    METADATA
        "wms_srs" "EPSG:4326"
 "wms_name" "BingMap"
        "wms_style" "Aerial"
        "wms_server_version" "1.1.1"
        "wms_format" "image/jpeg"
"ows_title" "Bing Aerials"
"gml_include_items" "all"
    END
    PROJECTION
    "init=epsg:4326"
    END
  END #layer
END
#2 Aerial with Labels.
MAP
  NAME 'BINGAERIALWITHLABELS'
  SIZE 800 650
  STATUS ON
  UNITS FEET
  IMAGETYPE JPEG
  PROJECTION
"init=epsg:200068"
  END
  LAYER
    NAME "BINGAERIALWITHLABELS"
    TYPE RASTER
    STATUS DEFAULT
    CONNECTIONTYPE WMS
    METADATA
        "wms_style" "AerialWithLabels"
"ows_title" "Bing Aerial with Labels"
    END
    PROJECTION
    "init=epsg:4326"
    END
  END #layer
END
#3 Roads
MAP
  NAME 'BINGROAD'
  SIZE 800 650
  STATUS ON
  UNITS FEET
  IMAGETYPE JPEG
  PROJECTION
"init=epsg:200068"
  END
  LAYER
    NAME "BINGROAD"
    TYPE RASTER
    STATUS DEFAULT
    CONNECTIONTYPE WMS
    METADATA
        "wms_style" "Road"
        "wms_format" "image/png"
"ows_title" "Bing Road"
    END
    PROJECTION
    "init=epsg:4326"
    END
    DEBUG on
  END #layer
END
>>> Jay Kapalczynski <jkapalczynski at ci.maple-grove.mn.us> wrote:
Thanks Duck for your thoughts….
I agree that there would be some time investment required to go to Lat
Long….just a batch reprojection of 20 or so layers….minor code change…
But it might better well serve me to invest that little time before I
invest a bunch of time to incorporate all my additional code into 2.0.
That and the learning curve to absorb the new code structure….At least
this way I am up and running….
In their example on the their webpage they have it 4326…what other
projection should I attempt to use? What are my other options if any?
What would recommend…
Have you done this yet…
Will changing from this:
width=1000&height=1000 &bbox=-105,35,-100,40
To this work in this case?
WIDTH=%WIDTH%&HEIGHT=1000&height=%HEIGHT%
&bbox=-%MINX%,%MINY%,%MAXX%,%MAXY%
Thanks Again
                Subject: Re: [Geomoose-developers] Bing Maps integration
Sure it'd be possible but you'd have a helluva lot work to do
reprojecting things.  And I'm not sure that Bing maps REALLY works in
4326, I'm sure they have it reprojected to something reasonable for
viewing.
To: Dan Little <danlittle at yahoo.com>;
"geomoose-developers at lists.sourceforge.net"
<geomoose-developers at lists.sourceforge.net>
Sent: Tuesday, September 22, 2009 11:49:01 AM
Subject: RE: [Geomoose-developers] Bing Maps integration
But I am on the right path correct…..this is possible correct
GM 2.0
So I can do this no sweat in GM2.0
GM 1.6
What if I changed the projection in my 1.6 app to Lat Long would it be
possible then?
THanks
Dan Little [mailto:danlittle at yahoo.com]
Sent: Tuesday, September 22, 2009 11:35 AM
To: Jay Kapalczynski; geomoose-developers at lists.sourceforge.net
Are you trying to do this with GM1.6? If so, you're a bit SOL, 2.0 has
all this capability but for the most part, GM1.6 is intended for single
projection mapping.
To: "geomoose-developers at lists.sourceforge.net"
Sent: Tuesday, September 22, 2009 11:29:05 AM
Subject: [Geomoose-developers] Bing Maps integration
I am trying to consume Bing aerials (not pbliques)…dont know if this is
even possible….but I was told it was…just consume the WMS service
I am trying this…and hitting a wall..,...
I assume the projection is off to begin with…lat long below I think…
http://integrate.onterrasys.com/WMSforWebMaps/
<map title=”TESTING” default=”false” zindex”-1”>
http://integrate.onterrasys.com/onterrawms_latlon?service=WMS&version=1.1.1&request=GetMap%20&layers=OnTerraWMS&styles=Aerial&transparent=FALSE&exception=&format=image/jpeg&srs=EPSG:4326&width=1000&height=1000%20&bbox=-105,35,-100,40
</map>
I tried to replace this:
With this
Still nothing…
Has anyone tried this yet…..if I have to set my GeoMOOSE app to lat long
then I will…..
Thoughts?
THanks
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20090922/d7269a88/attachment.html
More information about the Geomoose-users mailing list
