[Geomoose-users] display the results and zoom.
    Len Kne
    lkne at houstoneng.com
    Tue Sep 29 10:29:54 EDT 2009
Search Parcel on the demo should now be working.  There was a configuration typo in the parcels_itemquery.html - the layer read "parcels/all", but needs to be "parcels/parcels" to point to the proper layer.
Len
-----Original Message-----
From: Brent Fraser [mailto:bfraser at geoanalytic.com]
Sent: Tuesday, September 29, 2009 9:16 AM
To: FRANZ OKYERE
Cc: geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] display the results and zoom.
Ahh, GM v2; I don't think I can be of much help (I's still on v1.6.1).
So you've confirmed that the $shpminx,$shpminy,$shpmaxx,$shpmaxy coordinates
values are correct for a particular test feature?  How about commenting-out the
highlight code below and seeing if the link zooms to the feature on it's layer
with just a GeoMOOSE.zoomToExtent($shpminx,$shpminy,$shpmaxx,$shpmaxy)?
  I tried the v2 demo at Houston Eng
(http://geomoose.houstoneng.com/gm2demo/geomoose.html) and it seems to have
problems when doing a "Search Parcels" item query.  I typed in "Smith " for an
owner name and clicked ok.  It highlighted all parcels with an owner=Smith (Woo
hoo!), and I clicked the first link in the results list and it zoomed to the
extent of that parcel (but no more highlight, bummer).  So far so good.  but
when I clicked the second link it zoomed to the next parcel, show the results
for a split second, then the map went pink!  All further clicking on links
(including the first) gave the same result with the pink map.
I'm not sure which layer OpenLayers is having problems with?  Possibly the
highlight layer?
Best Regards,
Brent Fraser
FRANZ OKYERE wrote:
> Yes Brent,
> I have pasted below the basic elements of the link as shown in IE. The
> appropriate PIN and the correct extents gets passed ($mapin[$m]) to the
> url.
> I hope this helps.
> changeLayerUrl('highlight','php/itemquerysq.php');
> GeoMOOSE.updateLayerParameters('highlight', {'qitem' : 'PIN', 'qstring'
> : $mapin[$m], 'layer' : 'buildings/all'})
> GeoMOOSE.turnLayerOn('highlight/all');
> Thanks a lot.
> Franz
> GIS Specialist
>>  Date: Mon, 28 Sep 2009 20:36:29 -0600
>>  From: bfraser at geoanalytic.com
>>  To: franzzoa at hotmail.com
>>  CC: geomoose-users at lists.sourceforge.net
>>  Likely the link is setting the extents to somewhere invalid, do you have
>>  an example of the link URL? And the coordinates of the feature?
>>  > I mean when I click on one of the displayed results I expected the
> map to
>>  > zoom to the particular feature, but that does not happen instead the map
>>  > comes on for 2-3 secs and disappears. Cheers Brent.
>>  >> Date: Mon, 28 Sep 2009 15:23:24 -0600
>>  >> Franz,
>>  >> What do you mean by "the layer does not persist"?
>>  >> Brent Fraser
>>  >> > Hi all, I quit on using processquerytemplate and processtemplate
>>  >> methods.
>>  >> > Its just not helpful. I spent too much time on it. I'm rather using
>>  >> mysql
>>  >> > to display the results- its perfect. However the layer does not
>>  >> persist
>>  >> > when i click on one of the result to zoom to it. Anyone with similar
>>  >> > experience or suggestion? Thanks very much. Franz. GIS
>>  >> > Specilist. SIT.
>>  > _________________________________________________________________
>>  > MSN straight to your mobile - news, entertainment, videos and more.
>>  > http://clk.atdmt.com/UKM/go/147991039/direct/01/
>>  > Come build with us! The BlackBerry® Developer Conference in SF, CA
>>  > is the only developer event you need to attend this year. Jumpstart your
>>  > developing skills, take BlackBerry mobile applications to market and
> stay
>>  > ahead of the curve. Join us from November 9-12, 2009. Register
>>  > now!
>>  > http://p.sf.net/sfu/devconf
>>  > Geomoose-users mailing list
>>  > Geomoose-users at lists.sourceforge.net
>>  > https://lists.sourceforge.net/lists/listinfo/geomoose-users
> View your Twitter and Flickr updates from one place - Learn more!
> <http://clk.atdmt.com/UKM/go/137984870/direct/01/>
> developing skills, take BlackBerry mobile applications to market and stay
> ahead of the curve. Join us from November 9-12, 2009. Register now!
More information about the Geomoose-users
