[Geomoose-users] display the results and zoom.
FRANZ OKYERE
franzzoa at hotmail.com
Tue Sep 29 12:27:19 EDT 2009
Thanks Brent. Your test was positive. The map showed up and stayed this time. All I had to do was to put the correct the layer name. There was a small typo there. Once again, thanks. phew! Franz. GIS Specialist.
> Date: Tue, 29 Sep 2009 08:54:21 -0600
> From: bfraser at geoanalytic.com
> To: lkne at houstoneng.com
> CC: franzzoa at hotmail.com; geomoose-users at lists.sourceforge.net
> Subject: Re: [Geomoose-users] display the results and zoom.
> Ok, now the parcels highlight on zoom-to and there's no pink screen!
> Excellent!
> Len Kne wrote:
> > Search Parcel on the demo should now be working. There was a configuration typo in the parcels_itemquery.html - the layer read "parcels/all", but needs to be "parcels/parcels" to point to the proper layer.
> > Len
> > -----Original Message-----
> > From: Brent Fraser [mailto:bfraser at geoanalytic.com]
> > Sent: Tuesday, September 29, 2009 9:16 AM
> > To: FRANZ OKYERE
> > Cc: geomoose-users at lists.sourceforge.net
> > Ahh, GM v2; I don't think I can be of much help (I's still on v1.6.1).
> > So you've confirmed that the $shpminx,$shpminy,$shpmaxx,$shpmaxy coordinates
> > values are correct for a particular test feature? How about commenting-out the
> > highlight code below and seeing if the link zooms to the feature on it's layer
> > with just a GeoMOOSE.zoomToExtent($shpminx,$shpminy,$shpmaxx,$shpmaxy)?
> > I tried the v2 demo at Houston Eng
> > (http://geomoose.houstoneng.com/gm2demo/geomoose.html) and it seems to have
> > problems when doing a "Search Parcels" item query. I typed in "Smith " for an
> > owner name and clicked ok. It highlighted all parcels with an owner=Smith (Woo
> > hoo!), and I clicked the first link in the results list and it zoomed to the
> > extent of that parcel (but no more highlight, bummer). So far so good. but
> > when I clicked the second link it zoomed to the next parcel, show the results
> > for a split second, then the map went pink! All further clicking on links
> > (including the first) gave the same result with the pink map.
> > I'm not sure which layer OpenLayers is having problems with? Possibly the
> > highlight layer?
> > Best Regards,
> > Brent Fraser
> > FRANZ OKYERE wrote:
> >> Yes Brent,
> >> I have pasted below the basic elements of the link as shown in IE. The
> >> appropriate PIN and the correct extents gets passed ($mapin[$m]) to the
> >> url.
> >> I hope this helps.
> >> changeLayerUrl('highlight','php/itemquerysq.php');
> >> GeoMOOSE.updateLayerParameters('highlight', {'qitem' : 'PIN', 'qstring'
> >> : $mapin[$m], 'layer' : 'buildings/all'})
> >> GeoMOOSE.turnLayerOn('highlight/all');
> >> Thanks a lot.
> >> Franz
> >> GIS Specialist
> >>> Date: Mon, 28 Sep 2009 20:36:29 -0600
> >>> To: franzzoa at hotmail.com
> >>> CC: geomoose-users at lists.sourceforge.net
> >>> Likely the link is setting the extents to somewhere invalid, do you have
> >>> an example of the link URL? And the coordinates of the feature?
> >>> > I mean when I click on one of the displayed results I expected the
> >> map to
> >>> > zoom to the particular feature, but that does not happen instead the map
> >>> > comes on for 2-3 secs and disappears. Cheers Brent.
> >>> >> Date: Mon, 28 Sep 2009 15:23:24 -0600
> >>> >> Franz,
> >>> >> What do you mean by "the layer does not persist"?
> >>> >> Brent Fraser
> >>> >> > Hi all, I quit on using processquerytemplate and processtemplate
> >>> >> methods.
> >>> >> > Its just not helpful. I spent too much time on it. I'm rather using
> >>> >> mysql
> >>> >> > to display the results- its perfect. However the layer does not
> >>> >> persist
> >>> >> > when i click on one of the result to zoom to it. Anyone with similar
> >>> >> > experience or suggestion? Thanks very much. Franz. GIS
> >>> >> > Specilist. SIT.
> >>> > _________________________________________________________________
> >>> > MSN straight to your mobile - news, entertainment, videos and more.
> >>> > http://clk.atdmt.com/UKM/go/147991039/direct/01/
> >>> > Come build with us! The BlackBerry® Developer Conference in SF, CA
> >>> > is the only developer event you need to attend this year. Jumpstart your
> >>> > developing skills, take BlackBerry mobile applications to market and
> >> stay
> >>> > ahead of the curve. Join us from November 9-12, 2009. Register
> >>> > now!
> >>> > http://p.sf.net/sfu/devconf
> >>> > Geomoose-users mailing list
> >>> > Geomoose-users at lists.sourceforge.net
> >>> > https://lists.sourceforge.net/lists/listinfo/geomoose-users
> >> View your Twitter and Flickr updates from one place - Learn more!
> >> <http://clk.atdmt.com/UKM/go/137984870/direct/01/>
> >> developing skills, take BlackBerry mobile applications to market and stay
> >> ahead of the curve. Join us from November 9-12, 2009. Register now!
Get the best of MSN on your mobile
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20090929/d81f11c3/attachment.html
More information about the Geomoose-users
