[Geomoose-users] getting started, running the demos question
Brent Fraser
bfraser at geoanalytic.com
Mon Jan 4 11:30:26 EST 2010
John,
I'd say:
1. GeoMoose 2.0.x works with MS4W 2.3.1 (which includes PHP 5.2.6 and Mapserver
5.2.1)
2. GeoMoose 2.2 will work with MS4W 2.3.1 (that's what I've been testing)
3. GeoMoose 2.2 MAY work (we need to test) with MS4W 3.0 (which includes PHP
5.3.0, Mapserver 5.4.2)
This last point really depends on
- when is MS4W 3.0 out of beta?
- when will GM 2.2 be ready for beta (we still have some work to do)
- how extensive are the changes to GM 2.2 to work with MS4W 3.0?
I'd really like GM 2.2 to be compatible with MS4W 3.0 (so we could avoid a point
release). But not if it delays GM 2.2 too much.
Brent
John Callahan wrote:
> Thanks Dan/Brent.
> Would you say that GeoMoose 2.2 would be tested/modified to work with
> MapServer 5.4.x and PHP 5.3 (and therefore MS4W 3.0 from a Windows
> perspective)? Actually, GM 2.2 could probably work for all MapServer
> 5.x versions....
> And that GeoMoose 2.0.x works with MapServer 5.2.x and PHP 5.2 (and
> therefore MS4W 2.3.x)?
> I wouldn't mind using GM 2.2 with PHP 5.2 (at least temporarily) if I
> can find a php_mapscript dll based on PHP 5.2 that works with MapServer
> 5.4.2.
> - John
> On Mon, Jan 4, 2010 at 10:39 AM, Brent Fraser <bfraser at geoanalytic.com
> <mailto:bfraser at geoanalytic.com>> wrote:
> Dan, John,
> I agree; we need to test GM 2.2 with MS4W 3.0. I'll have a look at
> the beta.
> I see that PHP's dl() is deprecated (due to security and threading
> issues), but the doc doesn't say what the replacement is (use the
> PHP.ini?). I think our plan would be to modify config.php to test
> if a module is loaded (as it does now) and just give a message if it
> isn't:
> if(!extension_loaded('gd') && !extension_loaded('gd2')) {
> printf( 'Please ensure the following extension is loaded
> using php.ini:'.'php_gd2.'.PHP_SHLIB_SUFFIX);
> Unless there's a better way?
> As for the php.dbase.dll, we could ask the MS4W people to include it...
> Best Regards,
> Brent Fraser
> Dan Little wrote:
> I think we simply need to do more testing on the more bleeding
> edge software. In some regard, we have enough issues keeping up
> with browser changes. Moving past developer excuses, I'm
> running OS/X 10.5.something and a few variants of debian and I
> believe they all have PHP 5.2, which is why there is probably
> some quirks when moving t o PHP 5.3.
> Brian/Len/Brent, any help on your versions? I just really don't
> use Windows for anything but running IE...
> *From:* John Callahan <john.callahan at udel.edu
> <mailto:john.callahan at udel.edu>>
> *To:* geomoose-users at lists.sourceforge.net
> <mailto:geomoose-users at lists.sourceforge.net>
> *Sent:* Sun, January 3, 2010 8:31:42 AM
> < b>Subject: [Geomoose-users] getting started, running the demos
> question
> I'm trying to setup GeoMoose but ran into a problem that I'm not
> sure how to fix. After several hours of modifying my
> environment,
> here's where I'm at now:
> Windows OS
> Apache 2.2.11
> PHP 5.3.1 (VC6 x86 Thread Safe (2009-Nov-19 10:20:08) from
> http://windows.php.net/download/)
> MapServer 5.4.2 with PHP_MapScript from ms4w_3.0_beta7 2009-09-01
> (http://www.maptools.org/ms4w/index.phtml?page=README_INSTALL_3.0.html)
> GeoMoose from moose2-trunk as downloaded from the tarball as
> of Jan
> 1. ( I choose this over the 2.0.1 release because I liked
> some of
> the changes in 2.2.)
> Apparently, the php dl() function is now deprecated as of PHP
> 5.3. Even with the enable_dl set to 'On' in php.ini, it still
> throws an
> error when trying to run the demo. GeoMoose uses this
> function. How can I get around that?
> Also, I see GeoMoose uses php_dbase extension. That dll is
> not in
> the PHP or MS4W distributions I downloaded. I did see a
> php_ogr dll
> in MW4W though. How can I get around this?
> Lastly, I tried using php 5.2.8 and I WAS able to get the
> GeoMoose
> demo mostly working. However, some problems were occurring,
> likely
> because I didn't have php_mapscript, or maybe a wrong version. I
> switched to php 5.3 because I couldn't find a php_mapscript for
> MapServer 5.4.2 for p hp 5.2.x and because it was what MS4W
> currently supports.
> Thanks for any help or thoughts.
> - John
> John Callahan, Geospatial Application Developer
> Delaware Geological Survey, University of Delaware
> URL: http://www.dgs.udel.edu
> This SF.Net email is sponsored by the Verizon Developer Community
> Take advantage of Verizon's best-in-class app development support
> A streamlined, 14 day to market process makes app distribution
> fast and easy
> Join now and get one step closer to millions of Verizon customers
> http://p.sf.net/sfu/verizon-dev2dev
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> <mailto:Geomoose-users at lists.sourceforge.net>
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users
