[Geomoose-users] getting started, running the demos question
Brent Fraser
bfraser at geoanalytic.com
Tue Jan 5 13:44:07 EST 2010
I didn't edit the config.php. All of the GM required PHP dlls are loaded via
the php.ini file, except for php_dbase.dll. And since I don't have that one on
my test system, I'm confused why the print.php didn't crash and burn. I only
tested the print.php which doesn't actually use php_dbase.dll; perhaps the dl()
function is tolerant of files not being available (until a function is used).
Brent
John Callahan wrote:
> That's good to hear. Thanks Brent. Did you also edit the config.php
> to get rid of the dl() calls? or the php_dbase.dll dependence (which I
> couldn't find in the ms4w 3.0 beta distribution)?
> - John
> On Tue, Jan 5, 2010 at 1:12 PM, Brent Fraser <bfraser at geoanalytic.com
> <mailto:bfraser at geoanalytic.com>> wrote:
> GM 2.2 (from SVN) running on MS4W 3.0 beta works ok after I edited the
> mapbook.xml (for things we need to change anyway for the 2.2 Beta
> release).
> Creation of PDF,HTML, and jpg documents for Printing using PHP seems
> to work ok too.
> Brent
> Brent Fraser wrote:
> > I just installed MS4W on a clean XP virtual machine. Apache would
> not start; I
> > had to install the VC++ 2008 redist package
> (http://www.microsoft.com/downloads/details.aspx?familyid=9B2DA534-3E03-4391-8A4D-074B9F2BC1BF&displaylang=en
> <http://www.microsoft.com/downloads/details.aspx?familyid=9B2DA534-3E03-4391-8A4D-074B9F2BC1BF&displaylang=en>)
> > Then it started and PHP reported:
> > MapScript
> > MapServer Version MapServer version 5.4.2 OUTPUT=GIF OUTPUT=PNG
> OUTPUT=JPEG
> > OUTPUT=WBMP OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ
> SUPPORTS=AGG
> > SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER
> > SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
> SUPPORTS=WCS_SERVER
> > SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS
> > SUPPORTS=RGBA_PNG INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL
> INPUT=SHAPEFILE
> > PHP MapScript Version ($Revision: 9099 $ $Date: 2009-06-09
> 00:39:18 -0300 (Tue,
> > 09 Jun 2009) $)
> > so I'm encouraged. I'll try GM next...
> > Brent
> > Brian Fischer wrote:
> > > I really haven’t tested MS4W 3.0 beta 7 with GM yet. I tried when it
> > > was in beta 2 and ran into some of these same problems.
> > > I would suggest if there are specific things we need added to MS4W to
> > > make things work with GM 2.2 we submit a bug. Kind of like the
> > > Mapbender project did in this bug
> > > http://bugzilla.maptools.org/show_bug.cgi?id=2086. Then if it is
> not to
> > > hard for them to add they will do it.
> > > Is the dbase .dll the only thing? I think when GM 2.2 comes out
> we need
> > > to explain the quirks of the dl() function.
> > > *Brian Fischer,* CFM GIS Project Manager
> > > *Houston Engineering, Inc.*
> > > Phone: W: 763.493.4522 / M: 763.229.2734
> > > *From:* Dan Little [mailto:danlittle at yahoo.com
> <mailto:danlittle at yahoo.com>]
> > > *Sent:* Monday, January 04, 2010 10:05 AM
> > > *To:* John Callahan
> > > *Cc:* GeoMOOSE Users List
> > > *Subject:* Re: [Geomoose-users] getting started, running the
> demos question
> > > We will probably not delay 2.2 in order to be PHP 5.3 ready. I would
> > > expect that if we're going to focus on PHP 5.3/MS4W 3.0 then
> we're going
> > > to need to rollout a 2.2.(1/2/5) that subsumes it as a "bug fix."
> > > *From:* John Callahan <john.callahan at udel.edu
> <mailto:john.callahan at udel.edu>>
> > > *To:* Brent Fraser <bfraser at geoanalytic.com
> > > *Cc:* Dan Little <danlittle at yahoo.com
> <mailto:danlittle at yahoo.com>>;
> > > geomoose-users at lists.sourceforge.net
> <mailto:geomoose-users at lists.sourceforge.net>
> > > *Sent:* Mon, January 4, 2010 10:01:07 AM
> demos
> > > question
> > > Thanks Dan/Brent.
> > > Would you say that GeoMoose 2.2 would be tested/modified to work
> > > with MapServer 5.4.x and PHP 5.3 (and therefore MS4W 3.0 from a
> > > Windows perspective)? Actually, GM 2.2 could probably work
> for all
> > > MapServer 5.x versions....
> > > And that GeoMoose 2.0.x works with MapServer 5.2.x and PHP
> 5.2 (and
> > > therefore MS4W 2.3.x)?
> > > I wouldn't mind using GM 2.2 with PHP 5.2 (at least
> temporarily) if
> > > I can find a php_mapscript dll based on PHP 5.2 that works with
> > > MapServer 5.4.2.
> > > - John
> > > On Mon, Jan 4, 2010 at 10:39 AM, Brent Fraser
> > > <bfraser at geoanalytic.com <mailto:bfraser at geoanalytic.com>
> <mailto:bfraser at geoanalytic.com <mailto:bfraser at geoanalytic.com>>>
> wrote:
> > > Dan, John,
> > > I agree; we need to test GM 2.2 with MS4W 3.0. I'll have a
> look at
> > > the beta.
> > > I see that PHP's dl() is deprecated (due to security and
> threading
> > > issues), but the doc doesn't say what the replacement is (use the
> > > PHP.ini?). I think our plan would be to modify config.php to
> test
> > > if a module is loaded (as it does now) and just give a
> message if it
> > > isn't:
> > > if(!extension_loaded('gd') && !extension_loaded('gd2')) {
> > > printf( 'Please ensure the following extension is loaded
> > > using php.ini:'.'php_gd2.'.PHP_SHLIB_SUFFIX);
> > > Unless there's a better way?
> > > As for the php.dbase.dll, we could ask the MS4W people to
> include it...
> > > Best Regards,
> > > Brent Fraser
> > > Dan Little wrote:
> > > I think we simply need to do more testing on the more
> bleeding edge
> > > software. In some regard, we have enough issues keeping up with
> > > browser changes. Moving past developer excuses, I'm running
> OS/X
> > > 10.5.something and a few variants of debian and I believe
> they all
> > > have PHP 5.2, which is why there is probably some quirks when
> moving
> > > t o PHP 5.3.
> > > Brian/Len/Brent, any help on your versions? I just really
> don't use
> > > Windows for anything but running IE...
> > > <mailto:john.callahan at udel.edu <mailto:john.callahan at udel.edu>>>
> > > *To:* geomoose-users at lists.sourceforge.net
> <mailto:geomoose-users at lists.sourceforge.net>>
> > > *Sent:* Sun, January 3, 2010 8:31:42 AM
> > > < b>Subject: [Geomoose-users] getting started, running the
> demos
> > > question
> > > I'm trying to setup GeoMoose but ran into a problem that
> I'm not
> > > sure how to fix. After several hours of modifying my
> environment,
> > > here's where I'm at now:
> > > Windows OS
> > > Apache 2.2.11
> > > PHP 5.3.1 (VC6 x86 Thread Safe (2009-Nov-19 10:20:08) from
> > > http://windows.php.net/download/)
> > > MapServer 5.4.2 with PHP_MapScript from ms4w_3.0_beta7
> 2009-09-01
> (http://www.maptools.org/ms4w/index.phtml?page=README_INSTALL_3.0.html)
> > > GeoMoose from moose2-trunk as downloaded from the tarball
> as of Jan
> > > 1. ( I choose this over the 2.0.1 release because I liked
> some of
> > > the changes in 2.2.)
> > > Apparently, the php dl() function is now deprecated as of PHP
> > > 5.3. Even with the enable_dl set to 'On' in php.ini, it still
> > > throws an
> > > error when trying to run the demo. GeoMoose uses this
> function.
> > > How can I get around that?
> > > Also, I see GeoMoose uses php_dbase extension. That dll
> is not in
> > > the PHP or MS4W distributions I downloaded. I did see a
> php_ogr dll
> > > in MW4W though. How can I get around this?
> > > Lastly, I tried using php 5.2.8 and I WAS able to get the
> GeoMoose
> > > demo mostly working. However, some problems were
> occurring, likely
> > > because I didn't have php_mapscript, or maybe a wrong
> version. I
> > > switched to php 5.3 because I couldn't find a
> php_mapscript for
> > > MapServer 5.4.2 for p hp 5.2.x and because it was what MS4W
> > > currently supports.
> > > Thanks for any help or thoughts.
> > > - John
> > > John Callahan, Geospatial Application Developer
> > > Delaware Geological Survey, University of Delaware
> > > URL: http://www.dgs.udel.edu
> > > This SF.Net email is sponsored by the Verizon Developer Community
> > > Take advantage of Verizon's best-in-class app development support
> > > A streamlined, 14 day to market process makes app
> distribution fast
> > > and easy
> > > Join now and get one step closer to millions of Verizon customers
> > > http://p.sf.net/sfu/verizon-dev2dev
> > > _______________________________________________
> > > Geomoose-users mailing list
> > > Geomoose-users at lists.sourceforge.net
> <mailto:Geomoose-users at lists.sourceforge.net>
> <mailto:Geomoose-users at lists.sourceforge.net>>
> > > https://lists.sourceforge.net/lists/listinfo/geomoose-users
> > > A streamlined, 14 day to market process makes app distribution
> fast and easy
> fast and easy
> A streamlined, 14 day to market process makes app distribution fast
> and easy
More information about the Geomoose-users
