[Geomoose-users] FW: GM2: Popup question (Matthew D. Syvertson)
Mike Hamby
mhamby at crawford-county.org
Wed Jan 13 17:39:01 EST 2010
One way that seems to work to make identify always available and not
have to check the layer on is add an additional map title section in the
xml file for a "hidden" layer setting default="false" and
invisible="true" to keep it turned on and not in the toc, then in the
map file for that layer set MAXSCALE to a very low number.
Mike Hamby
GIS Specialist
Crawford County Assessor's Office
www.crawford-county.org
(479) 471-3203
-----Original Message-----
Sent: Wednesday, January 13, 2010 4:27 PM
To: geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] GM2: Popup question (Matthew D. Syvertson)
Matt,
I do know that this is possible, however it might be a lot of work (and
it
might not be the best way)
On a map that I have I have 3 identify functions:
the layer popup -popups from clicking on the layer in the toc.
the standard identify, where information shows up on the right side.
popup identify (with help from Len at Houston Engineering), where all
the
information from identify is displayed on the map.
I have separated the code between popup identify and standard identify
so it
is possible to have a different layers information show up in the popup
identify.
So it could be possible,
The problem is dealing with a hidden layer. Maybe someone else can help
out
with a better way, however if all else fails it could be possible to
piggyback the layer with another layer that does not turn off such as an
air
photo.
Mark Volz
GIS Specialist
Lyon County, MN
From: geomoose-users-request at lists.sourceforge.net
[mailto:geomoose-users-request at lists.sourceforge.net]
Sent: Wednesday, January 13, 2010 4:15 PM
Subject: Geomoose-users Digest, Vol 28, Issue 22
Send Geomoose-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
https://lists.sourceforge.net/lists/listinfo/geomoose-users
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
geomoose-users-owner at lists.sourceforge.net
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Geomoose-users digest..."
Today's Topics:
1. Re: GM2: Popup question (Matthew D. Syvertson)
Message: 1
Date: Wed, 13 Jan 2010 16:13:46 -0600
From: "Matthew D. Syvertson" <msyvertson at co.richland.nd.us>
To: <geomoose-users at lists.sourceforge.net>
Message-ID:
<9016EBD923E046409692B00D9D4C3FA7F229F6 at co39dc1.co.richland.nd.us>
Content-Type: text/plain; charset="us-ascii"
Mike had an interesting idea based on functions in GM 1.6, not sure if
there is any carryover to GM2. Could it would to rig an identify tool
to always point to one layer that is not even in the catalog? If so,
could I still have the other identify tool function as it does now?
Matt Syvertson
Richland County GIS Coordinator
418 2nd Ave N
Wahpeton, ND 58075
msyvertson at co.richland.nd.us <mailto:matthews at co.richland.nd.us>
Voice: 701-642-7860 Fax: 701-642-7746
From: Mike Hamby [mailto:mhamby at crawford-county.org]
Sent: Wednesday, January 13, 2010 4:11 PM
To: Matthew D. Syvertson
Subject: RE: [Geomoose-users] GM2: Popup question
I'm not familiar with GM2 yet, but I suspect you could.
Mike Hamby
GIS Specialist
(479) 471-3203
From: Matthew D. Syvertson [mailto:msyvertson at co.richland.nd.us]
Sent: Wednesday, January 13, 2010 4:08 PM
To: Mike Hamby
Do you know if you could have two identify tools? One doing for
identifying only the feature I was referring to and the other for the
normal identify functions?
Matt Syvertson
701-642-7860
Sent: Wednesday, January 13, 2010 4:06 PM
Matt,
I'm using 1.6 and have rigged it up so I can use the identify tool to
pull up information for layers that are not checked on. If something
like this would work, I'll go into more detail on how I did it. See the
screen dump below:
Mike Hamby
GIS Specialist
(479) 471-3203
Sent: Wednesday, January 13, 2010 3:41 PM
Subject: [Geomoose-users] GM2: Popup question
I hope I can describe what I want correctly. If not, please feel free
to ask me for more details.
I would like to have a layer that is in the map that can not be seen in
the catalog, but I want for users to be able to turn on popups for that
layer to extract information about it. I have no idea what this would
look like exactly, maybe a service, or a checkbox somewhere to turn on
this ability. My boss feels like for the function, it is not intuitive
enough for a person to have to find the layer, check the check box,
enable popups, then click on the map. He would prefer on obvious place
to turn on the function and then one click on the map.
Please let me know if you have ideas on how this could happen.
Matt Syvertson
418 2nd Ave N
Wahpeton, ND 58075
Name: not available
Type: image/jpeg
Desc: image001.jpg
Throughout its 18-year history, RSA Conference consistently attracts the
world's best and brightest in the field, creating opportunities for
Conference
attendees to learn about information security's most important issues
through
interactions with peers, luminaries and emerging and established
companies.
http://p.sf.net/sfu/rsaconf-dev2dev
Geomoose-users at lists.sourceforge.net
End of Geomoose-users Digest, Vol 28, Issue 22
Conference
through
companies.
More information about the Geomoose-users
