[Geomoose-users] toolbar getting covered or not showing at all
Dan Little
danlittle at yahoo.com
Mon Jan 18 07:52:19 EST 2010
IIRC, Nils had an error during the loading of his page and so it prevented the layout manager from ever starting. Does this fail entirely under IE?
>From: "Moore, Richard J" <richard.moore at mnsu.edu>
>To: "geomoose-users at lists.sourceforge.net" <geomoose-users at lists.sourceforge.net>
>Sent: Thu, January 14, 2010 10:55:11 AM
>Subject: [Geomoose-users] toolbar getting covered or not showing at all
>Hi all,
>Does anyone have a fix for the following? When my website loads
>(gm2.0), my toolbar either does not show up or it gets partially hidden behind
>the map. If I turn off a toolbar in firefox, then the page reloads and it
>shows up fine. It usually only occurs the first time that the page is opened
>and when firefox or ie is loaded as well. It is as if the order in which the
>loading is done causes the map to get loaded before the toolbar. I am sending
>a screenshot along as an example.
>I believe this question was asked once before by Nils in Germany
>but I never did see a response as to how it was fixed.
>Thanks,
>Rick
>From:FRANZ OKYERE
>[mailto:franzzoa at hotmail.com]
>Sent: Thursday, January 14, 2010 9:53 AM
>To: geomoose-users at lists.sourceforge.net
>Subject: Re: [Geomoose-users] Uploading GM2 on remote server
>Ok Brian, I've been setting the file paths
>and a few other things. I'll start uploading tomorrow I'll get back to you when
>I get stuck. Thanks mate. Appreciate that. Franz.
>From: bfischer at houstoneng.com
>>To: franzzoa at hotmail.com
>>CC: geomoose-users at lists.sourceforge.net; ms4w-users at lists.maptools.org
>>Date: Wed, 13 Jan 2010 22:04:29 -0600
>>Subject: RE: [Geomoose-users] Uploading GM2 on remote server
>Franz,
>I think we would need more details on your hosting environment
>to help you out. Setting MS4W and GeoMOOSE up on a ISP can vary depending
>on what level of permission they give you and the type of hosting plan you
>get. On some ISP’s you may find it is not even possible to install
>these type of web apps.
>It looks like you are on the right track though. Another
>thing you will need to know for GeoMOOSE is whether they will let you install
>PHP that comes with MS4W. This is important if you are using any of the
>GeoMOOSE services.
>-Brian
>From:FRANZ OKYERE [mailto:franzzoa at hotmail.com]
>Sent: Tuesday, January 12, 2010 2:24 AM
>Cc: ms4w-users at lists.maptools.org
>Subject: [Geomoose-users] Uploading GM2 on remote server
>Hi all thanks to your contributions, I'm
>about to take my application online. One query though, is there any guidelines
>on how to restructure the directory on a remote host? I have been given
>home/ghanas/public_html/ to be web-accessible- i suppose that will replace,
>htdocs? And the mapserver cgi location, as bla../mapserv. Any pointers how to
>get the site up and running? Thanks. Franz
>Okye.
>Do
>you have a story that started on Hotmail? Tell us
>now
>Not
>got a Hotmail account? Sign-up
>now - Free
Skipped content of type multipart/related
More information about the Geomoose-users
