[Geomoose-users] GM1.6: pop-up does not work anymore with new
	Firefox Version
    Dan Little
    danlittle at yahoo.com
    Sun Jul  4 08:04:04 EDT 2010
That looks like an IE hack that Firefox is now honoring.
Try...
if(window.XSLTProcessor && navigator.userAgent.toLowerCase().indexOf("msie") > 0) { ... }
And see if that helps.
----- Original Message ----
> From: Vojko Daneu <vojko.daneu at mail.telepac.pt>
> To: geomoose-users at lists.sourceforge.net.
> Sent: Fri, July 2, 2010 11:11:00 AM
> Subject: [Geomoose-users] GM1.6: pop-up does not work anymore with new Firefox Version
> Hallo,
with the new versions of Firefox the pop-up function in GeoMoose 1.6
does not work anymore. I found this 2 errors in the error panel of
> Firefox:
Firefox error: xml is null
This error relates to the
> following line in "GeoMOOSE.js":
this.populateMenuBar=function(xml){var
> root=document.createElement('ul');root.className='menubar';root.hideAll=rootHideAll;root.setAttribute('id',MenuId);var
> menus=xml.getElementsByTagName('menu');for(var m=0; m<menus.length; m++){var
> menu=document.createElement('li');root.appendChild(menu);menu.className='menu';var
> menuLink=document.createElement('a');menu.appendChild(menuLink);menuLink.appendChild(document.createTextNode(menus[m].getAttribute('title')));if(menus[m].getAttribute('href')){menuLink.href=menus[m].getAttribute('href');}
> else {menuLink.href='#';}
Firefox error: setting a property that
> only has a getter
This error relates to the following line in
> "GeoMOOSE.js":
if(window.XSLTProcessor){xslDoc.readyState=4;xslDoc.addEventListener('load',
> xslDoc.onreadystatechange, false);}
Any suggestions what to
> change?
Greetings,
> Vojko
This
> SF.net email is sponsored by
> Sprint
What will you do first with EVO, the first 4G phone?
Visit
> target="_blank" href="http://sprint.com/first">sprint.com/first --
> http://p.sf.net/sfu/sprint-com-first
Geomoose-users
> mailing list
> href="mailto:Geomoose-users at lists.sourceforge.net">Geomoose-users at lists.sourceforge.net
> href="https://lists.sourceforge.net/lists/listinfo/geomoose-users" target=_blank
More information about the Geomoose-users
