[Geomoose-users] Printing
Brent Fraser
bfraser at geoanalytic.com
Fri Jul 9 16:19:10 EDT 2010
I've had some success with printing OpenStreetMap tiles. Basically, you need to add
PROCESSING "OVERSAMPLE_RATIO=1"
PROCESSING "LOAD_FULL_RES_IMAGE=NO"
to the layer definition in the map file. So the mapfile would look like:
LAYER
DATA "frmt_wms_openstreetmap_tms.xml"
NAME "frmt_wms_openstreetmap_tms"
PROJECTION
"proj=merc" "a=6378137" "b=6378137" "lat_ts=0.0" "lon_0=0.0" "x_0=0.0"
"y_0=0" "k=1.0" "units=m" "nadgrids=@null" "no_defs"
END
STATUS ON
TYPE RASTER
UNITS METERS
END # LAYER
Best Regards,
Brent Fraser
Brent Fraser wrote:
> Dan (and others),
> While searching for TMS tiling information, I can across:
> http://www.gdal.org/frmt_wms.html
> and created a map file with a layer:
> LAYER
> PROJECTION
> END
> STATUS ON
> TYPE RASTER
> UNITS METERS
> END # LAYER
> It works, but is much slower than delivering tiles to the browser, seems to be
> flakey, and the image produced is poorer due to resampling (the annotation is
> un-readable).
> But it does "work" for printing (unless it times-out).
> Brent
> Dan Little wrote:
>> Printing with tiles is not currently supported.
>> ----- Original Message ----
>>> From: Fik <fik at ifik.eu>
>>> To: geomoose-users at lists.sourceforge.net
>>> Sent: Fri, June 4, 2010 2:13:55 AM
>>> Subject: [Geomoose-users] Printing
>>> Hello,
>> i would like to ask you if is posible to print or export map with
>> openstreetmap base layer ?
>> Thanks
>>> Filip
> This SF.net email is sponsored by Sprint
> What will you do first with EVO, the first 4G phone?
> Visit sprint.com/first -- http://p.sf.net/sfu/sprint-com-first
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users
