[Geomoose-users] Need label opacity independent of vector layer
Brent Fraser
bfraser at geoanalytic.com
Tue Jul 13 14:54:22 EDT 2010
I don't think so...
One entry in the mapbook (so only one GM "layer" with a checkbox):
<map title="Parcels" default="true">
<file>./Parcels.map</file>
</map
but two LAYERs in the Parcels.map file, one with no NAME entry in the CLASS so
its no included in the mapserver-generated legend.
Brent
Jim Dahl wrote:
>>From the responses, I see that it cannot be done without hacking or GM2.
> Brent, your suggestion with the two opacities still will show two layers
> in the TOC.
> -----Original Message-----
> From: Brent Fraser [mailto:bfraser at geoanalytic.com]
> Sent: Tuesday, July 13, 2010 1:13 PM
> To: Jim Dahl
> Cc: geomoose-users at lists.sourceforge.net
> Subject: Re: [Geomoose-users] Need label opacity independent of vector
> layer
> Jim,
> You could use mapserver's OPACITY setting in the map file. Have two
> layers
> in the map file (with the same name, or set STATUS DEFAULT so they're
> both
> always on), one for the geometry (OPACITY 20) and one for the labels
> (OPACITY
> 100). Of course GM's fade/unfade controls would have no knowledge of
> this, so
> that may be confusing to the end users...
> Brent
> Dan Little wrote:
>> This is/was a limitation in GeoMOOSE 1.X that we addressed in 2.X.
>> There is nothing in the standard code base that supports what you'd
>> like to do. Brian/Len/Brent may have a hack they did to make it work.
>> *From:* Jim Dahl <jim.dahl at mail.co.douglas.mn.us>
>> *To:* geomoose-users at lists.sourceforge.net
>> *Sent:* Tue, July 13, 2010 10:47:56 AM
>> *Subject:* [Geomoose-users] Need label opacity independent of
> vector
>> layer
>> I have a polygon layer in GM 1.x that has opacity of 20 but I want
>> opacity of labels 100. I can create this effect with separating
>> into two layers but I do not want to see the anno layer in the
>> layers tab. Can anyone guide me as to the solution. If anno is
>> separate layer, can the mapbook code be - visibility="false" ?
>> Jim Dahl, GISP
>> GIS Coordinator
>> Douglas County Public Works
>> 526 Willow Dr
>> PO Box 398
>> Alexandria MN 56308
>> V 320-762-2933
>> 320-762-2999
>> F 320-762-2998
>> This SF.net email is sponsored by Sprint
>> What will you do first with EVO, the first 4G phone?
>> Visit sprint.com/first -- http://p.sf.net/sfu/sprint-com-first
>> Geomoose-users mailing list Geomoose-users at lists.sourceforge.net
>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users
