[Geomoose-users] Need label opacity independent of vector layer
Dan Little
danlittle at yahoo.com
Tue Jul 13 15:02:00 EDT 2010
Those will still show up in the GeoMOOSE 1.X TOC.
>From: Bob Basques <Bob.Basques at ci.stpaul.mn.us>
>To: Brent Fraser <bfraser at geoanalytic.com>; Jim Dahl
><jim.dahl at mail.co.douglas.mn.us>
>Cc: geomoose-users at lists.sourceforge.net
>Sent: Tue, July 13, 2010 1:48:33 PM
>Subject: Re: [Geomoose-users] Need label opacity independent of vector layer
>Just remove or comment out, the NAME value from the mapfile for those layers you
>do not want to see in the legend.
>bobb
>>>> "Jim Dahl" <jim.dahl at mail.co.douglas.mn.us> wrote:
>>From the responses, I see that it cannot be done without hacking or GM2.
>Brent, your suggestion with the two opacities still will show two layers
>in the TOC.
>-----Original Message-----
>From: Brent Fraser [mailto:bfraser at geoanalytic.com]
>Sent: Tuesday, July 13, 2010 1:13 PM
>To: Jim Dahl
>layer
>Jim,
> You could use mapserver's OPACITY setting in the map file. Have two
>layers
>in the map file (with the same name, or set STATUS DEFAULT so they're
>both
>always on), one for the geometry (OPACITY 20) and one for the labels
>(OPACITY
>100). Of course GM's fade/unfade controls would have no knowledge of
>this, so
>that may be confusing to the end users...
>Brent
>Dan Little wrote:
>> This is/was a limitation in GeoMOOSE 1.X that we addressed in 2.X.
>> There is nothing in the standard code base that supports what you'd
>> like to do. Brian/Len/Brent may have a hack they did to make it work.
>> *From:* Jim Dahl <jim.dahl at mail.co.douglas.mn.us>
>> *To:* geomoose-users at lists.sourceforge.net
>> *Sent:* Tue, July 13, 2010 10:47:56 AM
>> *Subject:* [Geomoose-users] Need label opacity independent of
>vector
>> layer
>> I have a polygon layer in GM 1.x that has opacity of 20 but I want
>> opacity of labels 100. I can create this effect with separating
>> into two layers but I do not want to see the anno layer in the
>> layers tab. Can anyone guide me as to the solution. If anno is
>> separate layer, can the mapbook code be - visibility="false" ?
>> Jim Dahl, GISP
>> GIS Coordinator
>> Douglas County Public Works
>> 526 Willow Dr
>> PO Box 398
>> Alexandria MN 56308
>> V 320-762-2933
>> 320-762-2999
>> F 320-762-2998
>> This SF.net email is sponsored by Sprint
>> What will you do first with EVO, the first 4G phone?
>> Visit sprint.com/first-- http://p.sf.net/sfu/sprint-com-first
>> Geomoose-users mailing list Geomoose-users at lists.sourceforge.net
>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
>Visit sprint.com/first -- http://p.sf.net/sfu/sprint-com-first
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100713/2e402301/attachment.html
More information about the Geomoose-users
