[Geomoose-users] Need label opacity independent of vector layer
Jim Dahl
jim.dahl at mail.co.douglas.mn.us
Tue Jul 13 15:01:57 EDT 2010
Dan, if you remove it from the mapbook, then it doesn't show up and you
can set separate values for each layer. I understand there is no way of
toggling on and off two layers in 1.x, correct?
jim
-----Original Message-----
Sent: Tuesday, July 13, 2010 2:02 PM
To: Bob Basques; Brent Fraser; Jim Dahl
Cc: geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] Need label opacity independent of
vector layer
Those will still show up in the GeoMOOSE 1.X TOC.
To: Brent Fraser <bfraser at geoanalytic.com>; Jim Dahl
<jim.dahl at mail.co.douglas.mn.us>
Sent: Tue, July 13, 2010 1:48:33 PM
Just remove or comment out, the NAME value from the
mapfile for those layers you do not want to see in the legend.
bobb
>>> "Jim Dahl" <jim.dahl at mail.co.douglas.mn.us> wrote:
>From the responses, I see that it cannot be done
without hacking or GM2.
Brent, your suggestion with the two opacities still will
show two layers
in the TOC.
From: Brent Fraser [mailto:bfraser at geoanalytic.com]
Sent: Tuesday, July 13, 2010 1:13 PM
To: Jim Dahl
layer
Jim,
You could use mapserver's OPACITY setting in the map
file. Have two
layers
in the map file (with the same name, or set STATUS
DEFAULT so they're
both
always on), one for the geometry (OPACITY 20) and one
for the labels
(OPACITY
100). Of course GM's fade/unfade controls would have no
knowledge of
this, so
that may be confusing to the end users...
Brent
Dan Little wrote:
> This is/was a limitation in GeoMOOSE 1.X that we
addressed in 2.X.
> There is nothing in the standard code base that
supports what you'd
> like to do. Brian/Len/Brent may have a hack they did
to make it work.
> *From:* Jim Dahl <jim.dahl at mail.co.douglas.mn.us>
> *To:* geomoose-users at lists.sourceforge.net
> *Sent:* Tue, July 13, 2010 10:47:56 AM
> *Subject:* [Geomoose-users] Need label opacity
independent of
vector
> layer
> I have a polygon layer in GM 1.x that has opacity
of 20 but I want
> opacity of labels 100. I can create this effect
with separating
> into two layers but I do not want to see the anno
layer in the
> layers tab. Can anyone guide me as to the
solution. If anno is
> separate layer, can the mapbook code be -
visibility="false" ?
> Jim Dahl, GISP
> GIS Coordinator
> Douglas County Public Works
> 526 Willow Dr
> PO Box 398
> Alexandria MN 56308
> V 320-762-2933
> 320-762-2999
> F 320-762-2998
> This SF.net email is sponsored by Sprint
> What will you do first with EVO, the first 4G phone?
> Visit sprint.com/first --
http://p.sf.net/sfu/sprint-com-first
> Geomoose-users mailing list
Geomoose-users at lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100713/d66b801b/attachment.html
More information about the Geomoose-users
