[Geomoose-users] Mouseover map area to show pop up or link
FRANZ OKYERE
franzzoa at hotmail.com
Thu Jun 10 04:03:15 EDT 2010
Hi Len,I stuck your code the following function definition but even thought the popup shows up it does not contain any information.
this.onLoadedMapbook = function(mapbookXML) {#your hover code
I changed the line setting the url to the identify.php like this to suite my local settings. var url = 'http://localhost/moosecache2/php/identify.php?';
I am not sure if there is something else I need to do to. I have seen it work on your site so it should work on my I suppose.
Franz
> From: lkne at houstoneng.com
> To: bfraser at geoanalytic.com
> Date: Thu, 3 Jun 2010 15:40:50 +0000
> CC: geomoose-users at lists.sourceforge.net
> Subject: Re: [Geomoose-users] Mouseover map area to show pop up or link
> Performance seems ok, you can try it at http://dev.houstoneng.net/geomoose.html. Hover over a parcel for 1 second and you should get a popup. It's different than passing over a marker in OL because the handler is triggered after a pause in mouse movement vs. going over the marker. The downside is there will be a lot of calls back to the server (could be an issue on a high use app) and in the case of parcels, the number of popups could get annoying to the person looking at the map. Might work better with point data.
> Len
> -----Original Message-----
> From: Brent Fraser [mailto:bfraser at geoanalytic.com]
> Sent: Thursday, June 03, 2010 10:05 AM
> To: Len Kne
> Cc: Geomooselist
> Len,
> That's impressive! How's the performance?
> Brent
> Len Kne wrote:
> > One way would be to use OL Hover handler - see
> > http://openlayers.org/dev/examples/hover-handler.html. Basically it
> > is going to make an ajax call to the identify service when the cursor
> > hovers over a spot for a set time. The script below works in my
> > testing environment... it could be enabled as a tool or in onLoadedMapbook().
> > Len
> > // Hover support on WMS and MapServr layers
> > var popup;
> > OpenLayers.Control.Hover =
> > OpenLayers.Class(OpenLayers.Control, {
> > defaultHandlerOptions: {
> > 'delay': 500,
> > 'pixelTolerance': 20,
> > 'stopMove': false
> > initialize: function(options) {
> > this.handlerOptions = OpenLayers.Util.extend(
> > {}, this.defaultHandlerOptions
> > OpenLayers.Control.prototype.initialize.apply(
> > this, arguments
> > this.handler = new OpenLayers.Handler.Hover(
> > this,
> > {'pause': this.onPause, 'move': this.onMove},
> > this.handlerOptions
> > onPause: function(evt) {
> > var feature =
> > Map.getLonLatFromPixel(evt.xy);
> > var url =
> > '/php/identify.php?';
> > var layersArray =
> > GeoMOOSE.getVisibleLayers();
> > layers =
> > layersArray.join(':');
> > var requestOptions =
> > OpenLayers.Request.GET({
> > url:
> > url,
> > params:
> > {'shape': 'POINT(' + feature.lon + ' ' + feature.lat + ')',
> > 'layers': layers,
> > '_moosetime': (new Date()).getTime() },
> > async:
> > false
> > if(requestOptions.responseText) {
> > popup
> > = new OpenLayers.Popup.FramedCloud("wms",
> > Map.getLonLatFromPixel(evt.xy),
> > null,
> > requestOptions.responseText,
> > null, false);
> > Map.addPopup(popup);
> > onMove: function(evt) {
> > if (popup != null) {
> > popup.destroy();
> > popup = null;
> > // if this control sent an Ajax request (e.g.
> > GetFeatureInfo) when
> > // the mouse pauses the onMove callback could be
> > used to abort that
> > // request.
> > hover = new OpenLayers.Control.Hover();
> > Map.addControl(hover);
> > hover.activate();
> > *From:* FRANZ OKYERE [mailto:franzzoa at hotmail.com]
> > *Sent:* Wednesday, June 02, 2010 4:28 PM
> > *To:* Geomooselist
> > *Subject:* Re: [Geomoose-users] Mouseover map area to show pop up or
> > link
> > Thanks,
> > But is geomoose not based on open layers? If it is then what we can do
> > in open layers should be possible in geomoose, right? I really need to
> > do this so if you can point me in the right direction and show me
> > which of the javascript files I should be editing that would be nice.
> > Franz
> > Date: Wed, 2 Jun 2010 14:29:24 -0500
> > From: Bob.Basques at ci.stpaul.mn.us <mailto:Bob.Basques at ci.stpaul.mn.us>
> > To: bfraser at geoanalytic.com <mailto:bfraser at geoanalytic.com>;
> > franzzoa at hotmail.com <mailto:franzzoa at hotmail.com>
> > <mailto:geomoose-users at lists.sourceforge.net>
> > link
> > All,
> > Not on the feature(s), but the layer name/metadata icon in the side menu.
> > bobb
> >> >> Brent Fraser <bfraser at geoanalytic.com
> > <mailto:bfraser at geoanalytic.com>> wrote:
> > You mean by simply moving the cursor over the feature but not clicking it?
> > Geomoose no (as far as I know). OpenLayers has a hover handler so we
> > might be able to use that...
> > Brent Fraser
> > FRANZ OKYERE wrote:
> >> Hello all,
> >> I am using geomoose 2.2 and wish to do what google maps or bing maps
> >> are able to do- i.e. mouseover a location on the map and then get
> >> the popup showing up. Any ideas? Is such a thing possible at all in geomoose?
> >> Cheers.
> >> Franz
> >> GIS Specialist, Ghana.
> >> --- Get a free e-mail account with Hotmail. Sign-up now.
> >> _______________________________________________
> >> Geomoose-users mailing list
> >> Geomoose-users at lists.sourceforge.net
> > <mailto:Geomoose-users at lists.sourceforge.net>
> >> https://lists.sourceforge.net/lists/listinfo/geomoose-users
> > -------- ThinkGeek and WIRED's GeekDad team up for the Ultimate
> > GeekDad Father's Day Giveaway. ONE MASSIVE PRIZE to the lucky parental
> > unit. See the prize list and enter to win:
> > http://p.sf.net/sfu/thinkgeek-promo
> > Get a new e-mail account with Hotmail - Free. Sign-up now.
> > <http://clk.atdmt.com/UKM/go/197222280/direct/01/>
> lucky parental unit. See the prize list and enter to win:
_________________________________________________________________
Do you have a story that started on Hotmail? Tell us now
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100610/11837ea1/attachment.html
More information about the Geomoose-users
