[Geomoose-users] data link for download
Len Kne
lkne at houstoneng.com
Mon Jun 14 11:45:55 EDT 2010
The documentation left out needing the attribute "metadata" to read the tag. Metadata was added in ver. 2.2. The documentation will update tonight, but it should look something like this:
<layer title="Parcels" src="parcels/parcels" metadata="true" status="on" legend="true" show-legend="true" fade="true" unfade="true" >
<metadata>http://www.foo.com/bar.html</metadata>
</layer>
The metadata icon is called showmetadata.png. The simplest way to change this icon is to replace the PNG file with something that look like you want it to. You then need to run the sprite update from http://geomoose.org/docs/sprite.html. The sprite is being selected is determined by the name of the service or function being called - the PNG file name must match the name of the service or function.
Len
From: Dieter Lehmann [mailto:dieter.lehmann at hfwu.de]
Sent: Monday, June 14, 2010 10:06 AM
To: Len Kne
Subject: Re: [Geomoose-users] data link for download
Len, is the metadata link really working? - I tried it before, but with no success.
Which icon should be addressed? - in the sprite.css there is no metadata reference available.
I had an earlier topic in the list, and got a response from Dan, but I didn't get the metadata link running.
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100614/e8779411/attachment.html
More information about the Geomoose-users
