[Geomoose-users] query.php configuration confusion
Johan Forsman
Johan.Forsman at LA.GOV
Thu Jun 17 09:03:24 EDT 2010
Ok, I found a solution to the highlight issue.
Adding the 900913 projection block to the MAP section in highlight.map did not by itself change anything. However, if I also added the projection that the data is stored as in the LAYER definition in the highlight.map files it worked.
To summarize, to make the query and select highlighting work, in my case, when the data is stored in a different projection than what is used in the final output, the highlight.map files must look similar to this:
MAP
PROJECTION
"init=epsg:900913"
END
TRANSPARENT true
SYMBOL
NAME 'circle'
TYPE ellipse
POINTS
1 1
END
FILLED true
END
LAYER
PROJECTION
"init=epsg:26915"
END
NAME 'points'
TYPE POINT
STATUS DEFAULT
CLASS
SYMBOL 'circle'
COLOR 0 255 255
SIZE 16
END
END
> -----Original Message-----
> From: Len Kne [mailto:lkne at houstoneng.com]
> Sent: Wednesday, June 16, 2010 3:47 PM
> To: Johan Forsman; geomoose-users at lists.sourceforge.net
> Subject: RE: query.php configuration confusion
> Your parameters look right. How about this - queryitem, query and select
> create a temp shape file with the results and then use a built in map file
> to show the results. Look for highlight.map in htdocs/php/itemquery
> and/or htdocs/php/select. In the MAP object of the file, add the 900913
> projection information. This should re-project the highlight results
> before returning them to GeoMOOSE.
> Len
> From: Johan Forsman [mailto:Johan.Forsman at LA.GOV]
> Sent: Wednesday, June 16, 2010 3:37 PM
> To: Len Kne; geomoose-users at lists.sourceforge.net
> Hi Len, thanks for the response.
> On Issue 1 suspected that was it. I will attempt to craft an expanded
> section for each layer I wish to query.
> On Issue 2:
> Settings.ini contains
> projection=EPSG:900913
> Mapbook contains
> <param name="projection">EPSG:900913</param>
> Mapfiles contain
> PROJECTION
> "init=epsg:900913"
> END
> at the top, and
> PROJECTION
> "init=epsg:26915"
> END
> for each layer.
> Did I miss something?
> Thanks!
> /Johan.
> > Sent: Wednesday, June 16, 2010 3:22 PM
> > Hi Johan
> > Issue 2 - check conf/settings.ini to see what the projection is set to.
> > Server-based services use this value for the projection, while client-
> > based services use the mapbook.
> > For issue 1, I think you are going to need "fieldnameX" for each layer
> > you are querying. As your service is now configured, I would expect
> > it to only query Layer0 using fieldname0 and value0. I do not believe
> > you will be able to query across multiple layers with one value
> > without some custom coding of query.php.
> > Len
> > Sent: Wednesday, June 16, 2010 2:08 PM
> > To: geomoose-users at lists.sourceforge.net
> > Subject: [Geomoose-users] query.php configuration confusion
> > All:
> > Two issues to seek advice on this afternoon.
> > Platform is GM2.2, using webmaps as base with EPSG:900913 in the
> > mapbook and settings.ini files. Source data is in EPSG:26915, being
> > projected on- the-fly by MapServer to EPSG:900913. All layers I have
> > render very nicely in all the right spots.
> > Issue 1:
> > I would like to use the new query.php function to search several
> > tables in my PostGIS from one dialog. I have looked at the examples in
> > the documentation but it appears I am not fully comprehending the
> syntax.
> > I have 5 layers I wish to search, each has its own table in PostGIS.
> > 6 of the layers/tables have 2 identical fieldnames I wish to be able
> > to search on, "pwsid" and "sysname".
> > The remaining table has two fields I wish to be able to search on,
> > "regowner" and "newid" (ignore layer4 for now).
> > I used the "query.php" block from the demo mapbook and added/replaced
> > my own layers.
> > When I test the query layer0 and layer1 are turned on in the map, but
> > results are only returned for layer0.
> > I have a <input type...layer? for each layer.
> > I have a <input type...template? for each layer entry, but they all
> > use value="itemquery" since each layer definition in the referenced
> > mapfiles have unique templates defined there.
> > I am suspecting the problem lies somewhere with the "fieldname0" and
> > "value0" parameters? In fieldname0 I have included all 4 of the
> > fields, from 5 different tables, I wish to be able to specify the search
> from.
> > At the bottom of this message I have placed the query.php block as it
> > looks currently. Please ignore the square footage bit; it's remaining
> > from the demo, and I don't have an immediate need for the boolean
> functions.
> > I have been unable to stitch together a series of input types that
> > covers the bases. Does someone on the list have a query block to share
> > that does this that I may model mine after?
> > Issue 2:
> > All the layers plot where they should, but the highlights from the
> > query results plot in Algeria. To emphasise, ONLY the highlights plot
> > in the wrong place. Clearly a projection error, but where? This also
> > happens with the old itemquery.php since I switched from using
> > EPSG:26915 in my mapbook to EPSG:900913.
> > Thanks for taking the time!
> > And I do apologize for the rudimentary XML skills that are apparently
> > absent in my mapbook.
> > /Johan.
> > <service name="search_facilities">
> > <url>php/query.php</url>
> > <step type="input">
> > <input type="hidden" name="highlight" value="true"/>
> > <input type="hidden" name="mode" value="search"/>
> > <input type="hidden" name="layer0"
> > value="wells/sdwis_wells"/>
> > <input type="hidden" name="layer1"
> > value="surfacewater/intakes"/>
> > <input type="hidden" name="layer2"
> > value="surfacewater/treatmentplants"/>
> > <input type="hidden" name="layer3" value="storage/all"/>
> > <input type="hidden" name="layer4"
> > value="wells/swap_wells"/>
> > <input type="hidden" name="layer5"
> > value="wells/ldotd_all"/>
> > <input type="hidden" name="template0"
> > value="itemquery"/>
> > <input type="hidden" name="template1"
> > value="itemquery"/>
> > <input type="hidden" name="template2"
> > value="itemquery"/>
> > <input type="hidden" name="template3"
> > value="itemquery"/>
> > <input type="hidden" name="template4"
> > value="itemquery"/>
> > <input type="hidden" name="template5"
> > value="itemquery"/>
> > <input type="select" name="fieldname0" title="Search
> By:">
> > <option value="sysname">System Name</option>
> > <option value="pwsid">PWSID</option>
> > <option value="regowner">Registered owner</option>
> > <option value="newid">Well id number</option>
> > </input>
> > <input type="select" name="comparitor0" title="That: ">
> > <option value="like-icase">Contains</option>
> > <option value="right-like-icase">Begins
> With</option>
> > <option value="eq-str">Matches Exactly</option>
> > </input>
> > <input type="user" name="value0" title=""/>
> > <input type="hidden" name="fieldname1"
> > value="FIN_SQ_FT"/>
> > <input type="select" name="operator1">
> > <option value="or">OR</option>
> > <option value="and">AND</option>
> > </input>
> > <input type="select" name="comparitor1" title="Having
> Fin. Sq. Ft.
> > <option value="gt">Greater Than</option>
> > <option value="eq">Equal To</option>
> > <option value="lt">Less Than</option>
> > </input>
> > <input type="user" name="value1" title=""/>
> > </step>
> > </service>
> > ThinkGeek and WIRED's GeekDad team up for the Ultimate GeekDad
> > Father's Day Giveaway. ONE MASSIVE PRIZE to the lucky parental unit.
> > See the prize list and enter to win:
> > http://p.sf.net/sfu/thinkgeek-promo
> > Geomoose-users mailing list
> > Geomoose-users at lists.sourceforge.net
> > https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users
