[Geomoose-users] Highlight projection issue
Brent Fraser
bfraser at geoanalytic.com
Mon Jun 21 12:26:36 EDT 2010
I thought this sounded familiar. I've filed an issue:
http://www.geomoose.org/trac/ticket/96
It seems Jim K., Steve L., and I discussed this problem in April 2009
(http://osgeo-org.1803224.n2.nabble.com/Reprojection-of-shpext-and-mapext-in-templates-td2310145.html#a2310145)
Brent
Johan Forsman wrote:
> I decided to project the source data to the intended webmap projection and just store it that way. Everything is more-or-less in order now and there is a minor performance improvement without the on-the-fly projection.
> Thanks for the pointers.
>> -----Original Message-----
>> From: Len Kne [mailto:lkne at houstoneng.com]
>> Sent: Thursday, June 17, 2010 4:26 PM
>> To: Johan Forsman; geomoose-users at lists.sourceforge.net
>> Subject: Re: [Geomoose-users] Highlight projection issue
>> So it looks like there is some work to be done with GeoMOOSE services to
>> fully support querying layers in projections different than GeoMOOSE...
>> Since you are using PostGIS, you could do the transformation there with
>> st_transform(). The re-projection can also happen on the service-side of
>> the service or on the client-side with a GeoMOOSE user extension. This
>> should work:
>> TransformAndZoomExtension = new OpenLayers.Class(GeoMOOSE.UX.Extension, {
>> srcPrj: new OpenLayers.Projection('EPSG:26915'),
>> load: function() {
>> zoom: function(minx,miny,maxx,maxy) {
>> var bounds = new
>> OpenLayers.Bounds(minx,miny,maxx,maxy).transform(this.srcPrj,Map.projectio
>> n);
>> Map.zoomToExtent(bounds);
>> CLASS_NAME: "TransformAndZoomExtension"
>> GeoMOOSE.UX.register('TransformAndZoomExtension');
>> transformAndZoom = new TransformAndZoomExtension();
>> Look at http://www.geomoose.org/docs/user_extensions.html for details on
>> adding a user extension to GeoMOOSE.
>> Then in your template, you would point to
>> transformAndZoom.zoom([shpminx],[shpminy],[shpmaxx],[shpmaxy]);
>> Len
>> From: Johan Forsman [mailto:Johan.Forsman at LA.GOV]
>> Sent: Thursday, June 17, 2010 2:33 PM
>> To: geomoose-users at lists.sourceforge.net
>> Followup to my own message.
>> I have confirmed that the link returned by the javascript snippet below
>> contains the correct extent IF interpreted as the original EPSG:26915
>> projection.
>> In other words somewhere along the way the bounds are not reprojected.
>> If I use a single water well in my PostGIS (that uses EPSG:26915) as
>> example:
>> Stored coordinates are 748178.83, 333429.45 in NAD83 UTM15N.
>> Mapserver projects those to EPSG:900913 and obtains -10066017.27,
>> 3517260.50 according to my Geomoose interface, which uses 900913. This is
>> the correct location.
>> If I use my Geomoose interface and check the location in Algeria, it is
>> indeed in agreement with the UTM numbers above.
>> To reiterate, all locations plot in the correct location, the highlight is
>> now in the correct location, but the query-generated link appears to use
>> the unprojected EPSG:26915 coordinates, taking me to Algeria.
>> What can I do?
>> Thanks!
>> Johan.
>>> Sent: Thursday, June 17, 2010 11:17 AM
>>> Subject: [Geomoose-users] Highlight projection issue
>>> All:
>>> Focusing on the itemquery/highlight.map projection issue now. I
>>> thought I had it covered, but the plot has thickened.
>>> Making the changes described below indeed fixed the highlight problem,
>>> but there is still an underlying issue.
>>> If I click on the link generated by the
>>> javascript:GeoMOOSE.changeLayerUrl('highlight',...
>>> GeoMOOSE.zoomToExtent(662056.373600,3344506.451400,662056.373600,33445
>>> 06.4
>>> 51400)
>>> function in the template file it zooms to the same spot in Algeria
>>> that the highlight was previously placed.
>>> There is clearly something sinister going on with the source of that
>>> extent.
>>> Where can I look / what info can I provide to help troubleshoot this?
>>> Or am I simply overlooking something embarrassingly simple?
>>> Thanks!
>>> Johan.
>>>> Sent: Thursday, June 17, 2010 8:03 AM
>>>> To: Len Kne; geomoose-users at lists.sourceforge.net
>>>> Subject: Re: [Geomoose-users] query.php configuration confusion
>>>> Ok, I found a solution to the highlight issue.
>>>> Adding the 900913 projection block to the MAP section in
>>>> highlight.map
>>> did
>>>> not by itself change anything. However, if I also added the
>>>> projection that the data is stored as in the LAYER definition in the
>>>> highlight.map files it worked.
>>>> To summarize, to make the query and select highlighting work, in my
>>> case,
>>>> when the data is stored in a different projection than what is used
>>>> in
>>> the
>>>> final output, the highlight.map files must look similar to this:
>>>> MAP
>>>> PROJECTION
>>>> "init=epsg:900913"
>>>> END
>>>> TRANSPARENT true
>>>> SYMBOL
>>>> NAME 'circle'
>>>> TYPE ellipse
>>>> POINTS
>>>> 1 1
>>>> END
>>>> FILLED true
>>>> END
>>>> LAYER
>>>> PROJECTION
>>>> "init=epsg:26915"
>>>> END
>>>> NAME 'points'
>>>> TYPE POINT
>>>> STATUS DEFAULT
>>>> CLASS
>>>> SYMBOL 'circle'
>>>> COLOR 0 255 255
>>>> SIZE 16
>>>> END
>>>> END
>>>>> Sent: Wednesday, June 16, 2010 3:47 PM
>>>>> Subject: RE: query.php configuration confusion
>>>>> Your parameters look right. How about this - queryitem, query
>>>>> and
>>>> select
>>>>> create a temp shape file with the results and then use a built in
>>>>> map
>>>> file
>>>>> to show the results. Look for highlight.map in
>>>>> htdocs/php/itemquery and/or htdocs/php/select. In the MAP object
>>>>> of the file, add the
>>> 900913
>>>>> projection information. This should re-project the highlight
>>>>> results before returning them to GeoMOOSE.
>>>>> Len
>>>>> Sent: Wednesday, June 16, 2010 3:37 PM
>>>>> Hi Len, thanks for the response.
>>>>> On Issue 1 suspected that was it. I will attempt to craft an
>>>>> expanded section for each layer I wish to query.
>>>>> On Issue 2:
>>>>> Settings.ini contains
>>>>> projection=EPSG:900913
>>>>> Mapbook contains
>>>>> <param name="projection">EPSG:900913</param>
>>>>> Mapfiles contain
>>>>> PROJECTION
>>>>> "init=epsg:900913"
>>>>> END
>>>>> at the top, and
>>>>> PROJECTION
>>>>> "init=epsg:26915"
>>>>> END
>>>>> for each layer.
>>>>> Did I miss something?
>>>>> Thanks!
>>>>> /Johan.
>>>>>> Sent: Wednesday, June 16, 2010 3:22 PM
>>>>>> Hi Johan
>>>>>> Issue 2 - check conf/settings.ini to see what the projection is
>>>>>> set
>>>> to.
>>>>>> Server-based services use this value for the projection, while
>>> client-
>>>>>> based services use the mapbook.
>>>>>> For issue 1, I think you are going to need "fieldnameX" for each
>>> layer
>>>>>> you are querying. As your service is now configured, I would
>>>>>> expect it to only query Layer0 using fieldname0 and value0. I
>>>>>> do not
>>> believe
>>>>>> you will be able to query across multiple layers with one value
>>>>>> without some custom coding of query.php.
>>>>>> Len
>>>>>> Sent: Wednesday, June 16, 2010 2:08 PM
>>>>>> Subject: [Geomoose-users] query.php configuration confusion
>>>>>> All:
>>>>>> Two issues to seek advice on this afternoon.
>>>>>> Platform is GM2.2, using webmaps as base with EPSG:900913 in the
>>>>>> mapbook and settings.ini files. Source data is in EPSG:26915,
>>>>>> being projected on- the-fly by MapServer to EPSG:900913. All
>>>>>> layers I have render very nicely in all the right spots.
>>>>>> Issue 1:
>>>>>> I would like to use the new query.php function to search several
>>>>>> tables in my PostGIS from one dialog. I have looked at the
>>>>>> examples
>>> in
>>>>>> the documentation but it appears I am not fully comprehending
>>>>>> the
>>>>> syntax.
>>>>>> I have 5 layers I wish to search, each has its own table in
>> PostGIS.
>>>>>> 6 of the layers/tables have 2 identical fieldnames I wish to be
>>>>>> able to search on, "pwsid" and "sysname".
>>>>>> The remaining table has two fields I wish to be able to search
>>>>>> on, "regowner" and "newid" (ignore layer4 for now).
>>>>>> I used the "query.php" block from the demo mapbook and
>>> added/replaced
>>>>>> my own layers.
>>>>>> When I test the query layer0 and layer1 are turned on in the
>>>>>> map,
>>> but
>>>>>> results are only returned for layer0.
>>>>>> I have a <input type...layer? for each layer.
>>>>>> I have a <input type...template? for each layer entry, but they
>>>>>> all use value="itemquery" since each layer definition in the
>>>>>> referenced mapfiles have unique templates defined there.
>>>>>> I am suspecting the problem lies somewhere with the "fieldname0"
>>>>>> and "value0" parameters? In fieldname0 I have included all 4 of
>>>>>> the fields, from 5 different tables, I wish to be able to
>>>>>> specify the
>>>> search
>>>>> from.
>>>>>> At the bottom of this message I have placed the query.php block
>>>>>> as
>>> it
>>>>>> looks currently. Please ignore the square footage bit; it's
>>> remaining
>>>>>> from the demo, and I don't have an immediate need for the
>>>>>> boolean
>>>>> functions.
>>>>>> I have been unable to stitch together a series of input types
>>>>>> that covers the bases. Does someone on the list have a query
>>>>>> block to
>>> share
>>>>>> that does this that I may model mine after?
>>>>>> Issue 2:
>>>>>> All the layers plot where they should, but the highlights from
>>>>>> the query results plot in Algeria. To emphasise, ONLY the
>>>>>> highlights
>>> plot
>>>>>> in the wrong place. Clearly a projection error, but where? This
>>> also
>>>>>> happens with the old itemquery.php since I switched from using
>>>>>> EPSG:26915 in my mapbook to EPSG:900913.
>>>>>> Thanks for taking the time!
>>>>>> And I do apologize for the rudimentary XML skills that are
>>> apparently
>>>>>> absent in my mapbook.
>>>>>> /Johan.
>>>>>> <service name="search_facilities">
>>>>>> <url>php/query.php</url>
>>>>>> <step type="input">
>>>>>> <input type="hidden" name="highlight"
>>> value="true"/>
>>>>>> <input type="hidden" name="mode"
>> value="search"/>
>>>>>> <input type="hidden" name="layer0"
>>>>>> value="wells/sdwis_wells"/>
>>>>>> <input type="hidden" name="layer1"
>>>>>> value="surfacewater/intakes"/>
>>>>>> <input type="hidden" name="layer2"
>>>>>> value="surfacewater/treatmentplants"/>
>>>>>> <input type="hidden" name="layer3"
>>> value="storage/all"/>
>>>>>> <input type="hidden" name="layer4"
>>>>>> value="wells/swap_wells"/>
>>>>>> <input type="hidden" name="layer5"
>>>>>> value="wells/ldotd_all"/>
>>>>>> <input type="hidden" name="template0"
>>>>>> value="itemquery"/>
>>>>>> <input type="hidden" name="template1"
>>>>>> value="itemquery"/>
>>>>>> <input type="hidden" name="template2"
>>>>>> value="itemquery"/>
>>>>>> <input type="hidden" name="template3"
>>>>>> value="itemquery"/>
>>>>>> <input type="hidden" name="template4"
>>>>>> value="itemquery"/>
>>>>>> <input type="hidden" name="template5"
>>>>>> value="itemquery"/>
>>>>>> <input type="select" name="fieldname0"
>>> title="Search
>>>>> By:">
>>>>>> <option value="sysname">System
>> Name</option>
>>>>>> <option
>> value="pwsid">PWSID</option>
>>>>>> <option
>> value="regowner">Registered
>>> owner</option>
>>>>>> <option value="newid">Well id
>>> number</option>
>>>>>> </input>
>>>>>> <input type="select" name="comparitor0"
>>> title="That: ">
>>>>>> <option value="like-
>> icase">Contains</option>
>>>>>> <option value="right-like-
>> icase">Begins
>>>>> With</option>
>>>>>> <option value="eq-str">Matches
>>> Exactly</option>
>>>>>> </input>
>>>>>> <input type="user" name="value0"
>> title=""/>
>>>>>> <input type="hidden" name="fieldname1"
>>>>>> value="FIN_SQ_FT"/>
>>>>>> <input type="select" name="operator1">
>>>>>> <option value="or">OR</option>
>>>>>> <option value="and">AND</option>
>>>>>> </input>
>>>>>> <input type="select" name="comparitor1"
>>> title="Having
>>>>> Fin. Sq. Ft.
>>>>>> <option value="gt">Greater
>> Than</option>
>>>>>> <option value="eq">Equal
>> To</option>
>>>>>> <option value="lt">Less
>> Than</option>
>>>>>> </input>
>>>>>> <input type="user" name="value1"
>> title=""/>
>>>>>> </step>
>>>>>> </service>
>>>>>> ThinkGeek and WIRED's GeekDad team up for the Ultimate GeekDad
>>>>>> Father's Day Giveaway. ONE MASSIVE PRIZE to the lucky parental
>> unit.
>>>>>> See the prize list and enter to win:
>>>>>> http://p.sf.net/sfu/thinkgeek-promo
>>>>>> _______________________________________________
>>>>>> Geomoose-users mailing list
>>>>>> Geomoose-users at lists.sourceforge.net
>>>>>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
>>>> Father's Day Giveaway. ONE MASSIVE PRIZE to the lucky parental unit.
>> ThinkGeek and WIRED's GeekDad team up for the Ultimate GeekDad Father's
>> Day Giveaway. ONE MASSIVE PRIZE to the lucky parental unit. See the prize
>> GeekDad Father's Day Giveaway. ONE MASSIVE PRIZE to the
>> lucky parental unit. See the prize list and enter to win:
More information about the Geomoose-users
