[Geomoose-users] Mouseover map area to show pop up or link
Len Kne
lkne at houstoneng.com
Fri Jun 25 14:26:57 EDT 2010
You have to disable the control to make it stop. The trick is getting this included with the internal tools so that as tools are toggled on/off, all other tools in the set toggled on/off. It would take a little custom coding to get the hover implemented as a GeoMOOSE tool. Can you add it to TRAC as a feature request? We should look for funding to do the work to integrate the functionality to GeoMOOSE.
Len
From: Nayna Nayate [mailto:nayna.nayate at gis.leg.mn]
Sent: Friday, June 25, 2010 9:29 AM
To: 'FRANZ OKYERE'; Geomooselist
Subject: Re: [Geomoose-users] Mouseover map area to show pop up or link
I still haven't been able to successfully implement the hover as a tool. It is turned on when I click on identify but it isn't turned off when I select some other tool.
Len, do you have any solutions? You mention implementing your hover code as a tool. Any help would be appreciated.
Thanks
Nayna
From: FRANZ OKYERE [mailto:franzzoa at hotmail.com]
Sent: 23 June 2010 14:33
To: Geomooselist
Nay,
Well that is weird.. But try changing selectable="true" for the tool in your mapbook and lets see. If that does not work your only option will be to write a small function that capitalises on the identify button unchecked property (advanced for me though).
You need to also make sure that your code is not sitting within onLoadMapbook function. Cheers.
Franz
To: franzzoa at hotmail.com; geomoose-users at lists.sourceforge.net
Date: Wed, 23 Jun 2010 10:16:49 -0500
Subject: RE: [Geomoose-users] Mouseover map area to show pop up or link
Thanks Franz! It works. The pop-ups are turned on only when I select the Identify button. But they don't disappear when some other tool is selected.
Any ideas on how to turn off the pop-up hover when the identify button is unselected?
Thanks
Nayna
Sent: 22 June 2010 15:07
To: Geomooselist
Nayate,
I think (I have not tried it out) you first need to go to the mapbook and change the following line
<tool name="identify" title="Identify" type="service" service="identify" cursor="url('cursors/identify2.cur'),auto"/>
to
<tool name="identify" title="Identify" type="javascript" selectable="true">
GeoMOOSE.popIdentify(arguments);
</tool>
Then in compiled.js write the popIdentify function such that it is within the window.Geomoose constructor?
All the best.
Franz
GIS Specialist
Ghana
To: geomoose-users at lists.sourceforge.net
Date: Tue, 22 Jun 2010 13:20:21 -0500
I tried this code out in my geomoose application by inserting the code in the onLoadedMapbook() in complied.js and it works well.
Any hints on how I could be enabled as a tool? I'm trying to get this functionality activated only when I select the identify tool.
Sent: 03 June 2010 09:06
One way would be to use OL Hover handler - see http://openlayers.org/dev/examples/hover-handler.html. Basically it is going to make an ajax call to the identify service when the cursor hovers over a spot for a set time. The script below works in my testing environment... it could be enabled as a tool or in onLoadedMapbook().
Len
// Hover support on WMS and MapServr layers
var popup;
OpenLayers.Control.Hover = OpenLayers.Class(OpenLayers.Control, {
defaultHandlerOptions: {
'delay': 500,
'pixelTolerance': 20,
'stopMove': false
initialize: function(options) {
this.handlerOptions = OpenLayers.Util.extend(
{}, this.defaultHandlerOptions
OpenLayers.Control.prototype.initialize.apply(
this, arguments
this.handler = new OpenLayers.Handler.Hover(
this,
{'pause': this.onPause, 'move': this.onMove},
this.handlerOptions
onPause: function(evt) {
var feature = Map.getLonLatFromPixel(evt.xy);
var url = '/php/identify.php?';
var layersArray = GeoMOOSE.getVisibleLayers();
layers = layersArray.join(':');
var requestOptions = OpenLayers.Request.GET({
url: url,
params: {'shape': 'POINT(' + feature.lon + ' ' + feature.lat + ')',
'layers': layers,
'_moosetime': (new Date()).getTime() },
async: false
if(requestOptions.responseText) {
popup = new OpenLayers.Popup.FramedCloud("wms",
Map.getLonLatFromPixel(evt.xy),
null,
requestOptions.responseText,
null, false);
Map.addPopup(popup);
onMove: function(evt) {
if (popup != null) {
popup.destroy();
popup = null;
// if this control sent an Ajax request (e.g. GetFeatureInfo) when
// the mouse pauses the onMove callback could be used to abort that
// request.
hover = new OpenLayers.Control.Hover();
Map.addControl(hover);
hover.activate();
Sent: Wednesday, June 02, 2010 4:28 PM
To: Geomooselist
Thanks,
But is geomoose not based on open layers? If it is then what we can do in open layers should be possible in geomoose, right? I really need to do this so if you can point me in the right direction and show me which of the javascript files I should be editing that would be nice.
Franz
Date: Wed, 2 Jun 2010 14:29:24 -0500
From: Bob.Basques at ci.stpaul.mn.us<mailto:Bob.Basques at ci.stpaul.mn.us>
To: bfraser at geoanalytic.com<mailto:bfraser at geoanalytic.com>; franzzoa at hotmail.com<mailto:franzzoa at hotmail.com>
CC: geomoose-users at lists.sourceforge.net<mailto:geomoose-users at lists.sourceforge.net>
All,
Not on the feature(s), but the layer name/metadata icon in the side menu.
bobb
>>> Brent Fraser <bfraser at geoanalytic.com<mailto:bfraser at geoanalytic.com>> wrote:
You mean by simply moving the cursor over the feature but not clicking it?
Geomoose no (as far as I know). OpenLayers has a hover handler so we might be
able to use that...
Brent Fraser
FRANZ OKYERE wrote:
> Hello all,
> I am using geomoose 2.2 and wish to do what google maps or bing maps are
> able to do- i.e. mouseover a location on the map and then get the popup
> showing up. Any ideas? Is such a thing possible at all in geomoose?
> Cheers.
> Franz
> GIS Specialist, Ghana.
> Get a free e-mail account with Hotmail. Sign-up now.
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net<mailto:Geomoose-users at lists.sourceforge.net>
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
ThinkGeek and WIRED's GeekDad team up for the Ultimate
GeekDad Father's Day Giveaway. ONE MASSIVE PRIZE to the
lucky parental unit. See the prize list and enter to win:
http://p.sf.net/sfu/thinkgeek-promo
Get a new e-mail account with Hotmail - Free. Sign-up now.<http://clk.atdmt.com/UKM/go/197222280/direct/01/>
Get a free e-mail account with Hotmail. Sign-up now.<http://clk.atdmt.com/UKM/go/197222280/direct/01/>
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100625/17e45a6f/attachment.html
More information about the Geomoose-users
