[Geomoose-users] Feature Report
    Mark Volz
    MarkVolz at co.lyon.mn.us
    Wed May 12 16:04:20 EDT 2010
Hello,
I am working on getting a feature report up and running for an additional
site.  However, I have get the following error:
Fatal error: Call to a member function getAttribute() on a non-object in
C:\ms4w\apps\MurrayMOOSE\htdocs\php\print_util.php on line 95.
When I created the second site I copied the identify.html, mapbooks, and the
feature report service.  However I noticed that the calls between the working
site and not working site are slightly different.  The calls to print.php are
almost exactly the same except that the non working site has five %2C
(periods) and the moosetime in the call.
Working example:
http://localhost/geomoose2/php/print.php?layers=%20%7B%22order%22%3A%5B%22Par
celReportLayers%22,%22StandardBackground%22%5D,%22ParcelReportLayers%22%3A%7B
%22layers%22%3A%5B%22all%22%5D,%22params%22%3A%7B%7D,%22opacity%22%3A100,%22u
rl%22%3A%22%2Fcgi-bin%2Fmapserv.exe%22%7D,%22StandardBackground%22%3A%7B%22la
yers%22%3A%5B%22all%22%5D,%22params%22%3A%7B%7D,%22opacity%22%3A100,%22url%22
%3A%22%2Fcgi-bin%2Fmapserv.exe%22%7D%7D&extent=329264.61988304%2C94540.935672
515%2C672735.38011696%2C260459.06432749&mode=feature_report&padding=25&src=Pa
rcelReportLayers%2Fparcels&PARCEL_ID=11-010002-0&title=Map&date=true&template
=parcel&quality=2&scale=No
non-working example:
http://localhost/MurrayMoose/php/print.php?layers=%20%7B%22order%22%3A%5B%22P
arcelReportLayers%22%2C%22StandardBackground%22%5D%2C%22ParcelReportLayers%22
%3A%7B%22layers%22%3A%5B%22all%22%5D%2C%22params%22%3A%7B%7D%2C%22opacity%22%
3A100%2C%22url%22%3A%22%2Fcgi-bin%2Fmapserv.exe%22%7D%2C%22StandardBackground
%22%3A%7B%22layers%22%3A%5B%22all%22%5D%2C%22params%22%3A%7B%7D%2C%22opacity%
22%3A100%2C%22url%22%3A%22%2Fcgi-bin%2Fmapserv.exe%22%7D%7D&extent=316170%2C7
5940%2C682830%2C253060&mode=feature_report&padding=25&src=ParcelReportLayers%
2Fparcels&PID=15.019.002.0&title=Map&date=true&template=parcel&quality=2&scal
e=No&_moosetime=1273691480404
Any help would be appreciated.  Thanks!
Mark Volz
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100512/32518713/attachment.html
More information about the Geomoose-users
