[Geomoose-users] Geocode and Identify Errors
Dan Little danlittle at yahoo.com
Fri May 21 09:21:19 EDT 2010
I'd suggest two things:
1) File a bug in Trac.
2) Edit both geocode.php and identify.php files and replace "split" with "explode".  PHP does obnoxiously stupid things with strings and string functions.
>From: Wes Cleland <wcleland at vanburencity.org>
>To: geomoose-users at lists.sourceforge.net
>Sent: Thu, May 20, 2010 4:04:06 PM
>Subject: [Geomoose-users] Geocode and Identify Errors
>First off, I would like to say thanks for the assistance;
>these mailing list are worth their weight in gold when it comes to someone just
>starting out in a program such as myself. I started off using MS4W and GeoMoose
>and after an abundance of use, was authorized to move to a server. Due to
>funding issues Linux was the best route to go. So I am not only learning more
>about GeoMoose, I am learning linux as well. After some configuration and
>permission issues, I finally was able to get GeoMoose to display in a web
>browser using FGS9.5 on linux. I can pan, zoom-in, etc., however, when I
>search, identify, geocode, and print I get an error. Usually along the lines of:
>Deprecated: Function split() is deprecated in /opt/geomoose2/htdocs/php/geocode.php >on line 22
>Warning: Cannot modify header information - headers already sent by
>(output started at /opt/geomoose2/htdocs/php/geocode.php:22) in /opt/geomoose2/htdocs/php/geocode.php >on line 27
>This particular error is specific to geocoding obviously, but they
>all contain the word deprecated and end in cannot modify header information.
>When I attempt to identify, select, buffer I get an unhandled request return
>Unknown error. I am stuck and any assistance would be greatly appreciated.
>Thanks in advance.
>v/r,
>Wes Cleland
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100521/c9df34f8/attachment.html
More information about the Geomoose-users mailing list
