[Geomoose-users] Geocode and Identify Errors
Dan Little
danlittle at yahoo.com
Fri May 21 15:23:50 EDT 2010
Can you forward the specific deprecated error to the list?
>From: Wes Cleland <wcleland at vanburencity.org>
>To: geomoose-users at lists.sourceforge.net
>Sent: Fri, May 21, 2010 2:14:53 PM
>Subject: Re: [Geomoose-users] Geocode and Identify Errors
>I
>made the changes and the geocode service works now. I don’t know if it
>should be placed in Trac or not, the reason is the demo map/mapbook works, but
>when I change the mapbook to one that I altered it does not. It seems as though
>there is another configuration that needs to be changed somewhere. Any
>suggestions? I still get a “deprecated” error when attempting to
>print; however, it still generates the files to print. Thanks for the tip.
>v/r,
>Wesley
>T. Cleland, GISP, CFM
>GIS
>Coordinator
>City
>of Van Buren, Arkansas
>479-471-5025
>“One
>ought never to turn one's back on a threatened danger and try to run away from
>it. If you do that, you will double the danger. But if you meet it promptly and
>without flinching, you will reduce the danger by half. Never run away from
>anything. Never!”
>Winston Churchill
>From:danlittle at yahoo.com
>[mailto:danlittle at yahoo.com]
>Sent: Friday, May 21, 2010 8:21 AM
>To: wcleland at vanburencity.org geomoose-users at lists.sourceforge.net
>I'd suggest two things:
>1) File a bug in Trac.
>2) Edit both geocode.php and
>identify.php files and replace "split" with "explode".
> PHP does obnoxiously stupid things with strings and string functions.
>>From:Wes Cleland
>>Sent: Thu, May 20, 2010 4:04:06 PM
>>Subject: [Geomoose-users] Geocode and Identify Errors
>>First off, I would like to say thanks for the assistance;
>>these mailing list are worth their weight in gold when it comes to someone just
>>starting out in a program such as myself. I started off using MS4W and GeoMoose
>>and after an abundance of use, was authorized to move to a server. Due to
>>funding issues Linux was the best route to go. So I am not only learning more
>>about GeoMoose, I am learning linux as well. After some configuration and
>>permission issues, I finally was able to get GeoMoose to display in a web
>>browser using FGS9.5 on linux. I can pan, zoom-in, etc., however, when I search,
>>identify, geocode, and print I get an error. Usually along the lines of:
>>Deprecated: Function split() is deprecated in /opt/geomoose2/htdocs/php/geocode.php >>on line 22
>>Warning: Cannot modify header information - headers already sent by
>>(output started at /opt/geomoose2/htdocs/php/geocode.php:22) in /opt/geomoose2/htdocs/php/geocode.php >>on line 27
>>This particular error is specific to geocoding obviously, but they
>>all contain the word deprecated and end in cannot modify header information.
>>When I attempt to identify, select, buffer I get an unhandled request return
>>Unknown error. I am stuck and any assistance would be greatly appreciated.
>>Thanks in advance.
>>v/r,
>>Wes Cleland
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20100521/d3b9a9cd/attachment.html
More information about the Geomoose-users
