[Geomoose-users] Geocode and Identify Errors
Brent Fraser bfraser at geoanalytic.com
Fri May 21 18:05:44 EDT 2010
For the printing errors, it looks like its having problems with the template PDF
file.  Is it the same as with the demo data or did you edit it?
Which version of PHP are you using?
Best Regards,
Brent Fraser
Wes Cleland wrote:
> This is the error when attempting to print:
> *Deprecated*: Assigning the return value of new by reference is
> deprecated in */opt/geomoose2/htdocs/php/fpdi/fpdi.php* on line *88*
> deprecated in */opt/geomoose2/htdocs/php/fpdi/fpdi_pdf_parser.php* on
> line *244*
> deprecated in */opt/geomoose2/htdocs/php/fpdi/pdf_parser.php* on line *102*
> deprecated in */opt/geomoose2/htdocs/php/fpdi/pdf_parser.php* on line *285*
> deprecated in */opt/geomoose2/htdocs/php/fpdi/pdf_parser.php* on line *437*
> *Warning*: Cannot modify header information - headers already sent by
> (output started at /opt/geomoose2/htdocs/php/fpdi/fpdi.php:88) in
> */opt/geomoose2/htdocs/php/print.php* on line *136*
> The identify error is this:
> As previously stated, I can load the default mapbook.xml with the demo
> data and the identify/select/buffer/search works fine, but when I load
> the mapbook created with my data it gives me these errors. I even went
> as far as rebuilding the mapbook ensuring that every little word was
> typed correctly/etc.
> v/r,
> Wesley T. Cleland, GISP, CFM
> GIS Coordinator
> City of Van Buren, Arkansas
> 479-471-5025
> “One ought never to turn one's back on a threatened danger and try to
> run away from it. If you do that, you will double the danger. But if you
> meet it promptly and without flinching, you will reduce the danger by
> half. Never run away from anything. Never!”
> Winston Churchill
> *From:* danlittle at yahoo.com [mailto:danlittle at yahoo.com]
> *Sent:* Friday, May 21, 2010 8:21 AM
> *To:* wcleland at vanburencity.org geomoose-users at lists.sourceforge.net
> *Subject:* Re: [Geomoose-users] Geocode and Identify Errors
> I'd suggest two things:
> 1) File a bug in Trac.
> 2) Edit both geocode.php and identify.php files and replace "split" with
> "explode".  PHP does obnoxiously stupid things with strings and string
> functions.
>     *From:* Wes Cleland <wcleland at vanburencity.org>
>     *To:* geomoose-users at lists.sourceforge.net
>     *Sent:* Thu, May 20, 2010 4:04:06 PM
>     *Subject:* [Geomoose-users] Geocode and Identify Errors
>     First off, I would like to say thanks for the assistance; these
>     mailing list are worth their weight in gold when it comes to someone
>     just starting out in a program such as myself. I started off using
>     MS4W and GeoMoose and after an abundance of use, was authorized to
>     move to a server. Due to funding issues Linux was the best route to
>     go. So I am not only learning more about GeoMoose, I am learning
>     linux as well. After some configuration and permission issues, I
>     finally was able to get GeoMoose to display in a web browser using
>     FGS9.5 on linux. I can pan, zoom-in, etc., however, when I search,
>     identify, geocode, and print I get an error. Usually along the lines of:
>     *Deprecated*: Function split() is deprecated in
>     */opt/geomoose2/htdocs/php/geocode.php* on line *22*
>     by (output started at /opt/geomoose2/htdocs/php/geocode.php:22) in
>     */opt/geomoose2/htdocs/php/geocode.php* on line *27*
>     This particular error is specific to geocoding obviously, but they
>     all contain the word deprecated and end in cannot modify header
>     information. When I attempt to identify, select, buffer I get an
>     unhandled request return Unknown error. I am stuck and any
>     assistance would be greatly appreciated. Thanks in advance.
>     v/r,
>     Wes Cleland
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
