[Geomoose-users] Labeling
Bob Basques Bob.Basques at ci.stpaul.mn.us
Tue Nov 30 15:59:10 EST 2010
Correct, we plotted out to Transparent PNGs in our case, and overlay them in the GISmo (GeoMoose) interface.
Essentially you just add them.  We also went to the trouble of building the PNG's as a tiled pyramid for resolution changes and performance increases for different resolution levels of view in the GeoMoose interface.  I think we have four levels of pyramiding right now for that particular layer (we do this with some other layers too, like the Scanned Qtr-Section sheet layer, which was also generated from AutoCAD).
bobb
>>> "Jacob Rodel" <jacob.rodel at co.todd.mn.us> wrote:
Thanks for the feedback bob!  I see in the plotter manager in AutoCad you can set it up to print to tiff or jpeg.  Is that what you are talking about?  Then just add it as a normal raster file?
Jacob Rodel
GIS Technician
Todd
CountyGIS
& Land Services Dept.
347 Central Ave. Suite 1
Long Prairie, MN56347
(320) 732-4248
Bob Basques [mailto:Bob.Basques at ci.stpaul.mn.us]
Sent:
Tuesday, November 30, 2010 12:37 PM
To:
Jacob Rodel; geomoose-users at lists.sourceforge.net
Subject:
Re: [Geomoose-users] Labeling
Jacob,
Well, we (I mean "I") cheated a little on this one.
While our GeoMoose interface will generate most layersfor the WholeCity, it's best if you zoom in to a spot on the map somewhere to get an idea of the detail our method enabled us to publish.
In this GeoMoose instance:
http://gis.ci.stpaul.mn.us/gis/gismo_public/html/
  under the Geodetic & Control Points  >>  Plat (Property) Lines.
We generated a raster tileset output from AutoCAD to represent our Platted (survey) linework, complete with all labeling and dimensioning.  This allows us to use the CAD (AutoCAD) product to control the cartography elements and not require us to replicate the same cartography in the Web publishing process.  This has worked out for us for more then ten years now.
We generally update the tiles every few months.  But I'm in the middle of building an AutoCAD autoupdate routine for incrmentally updating the tiles on the GeoMoose site as they are edited.  The longer our system is in place, the more features folks start to ask for, and currency of data is become a major user need/desire.
bobb
I know this is more of a mapserver thing but I was just wondering what other people were doing.  We manage all of our parcel dimensions, lot numbers, ect. in AutoCad.  From what I understand in order to get them in my Geomoose application I have to convert to Geodatabase and then label by the textstring field.  Is this similar to what other people are doing or is there a better way?  Thanks!
Jacob Rodel
GIS Technician
Todd
CountyGIS
(320) 732-4248
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20101130/df35f421/attachment.html
More information about the Geomoose-users mailing list
