[Geomoose-users] Print Templates
Bob Basques Bob.Basques at ci.stpaul.mn.us
Tue Oct 26 12:22:51 EDT 2010
did a negative number have any effect?
bobb
>>> "Sean Ziniker" <Sean.Ziniker at co.jefferson.or.us> wrote:
Well I finally got the justification to work on my print template.
There is still one issue I am having but overall it works well.  I
wanted a title and subtitle for user inputs.  The title needed to be on
the left side of the template and the Subtitle on the right.  The
default is left justified so I needed to right justify the subtitle.
The only way I could get it to work is to split them up in the print.php
file. I attached the code I worked with at around line 291 where it says
“# Render the text fields”.  The code between #SZ Start and #SZ End is
the code I added.  I basically had to add another “getElementsByTagName”
 and call it text1.  So anywhere within that chunk of code that referred
to  “text” I changed it to “text1”.  Then at the end of the code I added
there is a line that says “$pdf->Cell(0,.25,$printString,0,0,'R');”,
this is where I defined the justification.  If you look at the original
code it does not have the “,0,0,’R’” after “$printString”.  The R means
right, C would be for center if you wanted the text centered and L for
left.
Now all I had to do is go into your letter_landscape.xml template and
change text to text1.  Below is what mine looks like:
<text x=".47" y=".29" size="12" content="%title%"/>
<text1 x="0" y=".29" size="10" content="%subtitle%"/>
<text x="9.8" y="7.08" size="8" content="%date%"/>
The one issue I am having though is once I have right justified text1 I
cannot move the x position.  So above where it says <text1 x="0", I
could have a 0 or 100 in the x= and it wont change the position.  The
reason I would like to is that when I right justify my text1 it sits
just a little bit outside my border.  I have also added a pdf of my
print.
Thanks for your help Len.
Sean Ziniker
GIS Analyst
Jefferson County, Oregon
66 S.E. "D" Street, Suite B
Madras, OR97741
541.325.5083 Office
541.325.5089 Fax
Len Kne [mailto:lkne at houstoneng.com]
Sent:
Friday, October 22, 2010 1:32 PM
To:
Sean Ziniker; geomoose-users at lists.sourceforge.net
Subject:
RE: Print Templates
This is possible, but you are going to have to edit print.php.  The
library GeoMOOSE uses for printing PDFs is at, http://www.fpdf.org/.
Look for “cell” in the documentation and print.php – you should be able
to set the justification.
Len
Sean Ziniker [mailto:Sean.Ziniker at co.jefferson.or.us]
Sent:
Friday, October 22, 2010 3:12 PM
To:
Subject:
I was just wondering if there is a way to align a subtitle on the right
side on my custom print template.  I am using something that looks like
this in my .xml:
<text x="-.47" y=".29" size="14" content="%subtitle%"/>
Is there a way to put a right align within the text tag so longer
subtitles will not run off the page.
Thanks,
Sean Ziniker
GIS Analyst
Madras, OR97741
541.325.5083 Office
541.325.5089 Fax
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20101026/e4e8349b/attachment.html
More information about the Geomoose-users mailing list
