[Geomoose-users] Print Templates
Len Kne lkne at houstoneng.com
Tue Oct 26 13:44:29 EDT 2010
Where you define the cell:
$pdf->Cell(0,.25,$printString,0,0,'R');//R for right, L for left and C for center justification
Try changing the width value (the first zero) to something.  Looks like if there is no width defined, the cell goes all the way to the right margin.  If that doesn't work, you could try setting the margins $pdf->SetMargins(float left, float top [, float right]).
Len
From: Sean Ziniker [mailto:Sean.Ziniker at co.jefferson.or.us]
Sent: Tuesday, October 26, 2010 11:12 AM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] Print Templates
Well I finally got the justification to work on my print template.  There is still one issue I am having but overall it works well.  I wanted a title and subtitle for user inputs.  The title needed to be on the left side of the template and the Subtitle on the right.  The default is left justified so I needed to right justify the subtitle.  The only way I could get it to work is to split them up in the print.php file. I attached the code I worked with at around line 291 where it says "# Render the text fields".  The code between #SZ Start and #SZ End is the code I added.  I basically had to add another "getElementsByTagName" and call it text1.  So anywhere within that chunk of code that referred to "text" I changed it to "text1".  Then at the end of the code I added there is a line that says "$pdf->Cell(0,.25,$printString,0,0,'R');", this is where I defined the justification.  If you look at the original code it does not have the ",0,0,'R'" after "$printString".  The R means right, C would be for center if you wanted the text centered and L for left.
Now all I had to do is go into your letter_landscape.xml template and change text to text1.  Below is what mine looks like:
<text x=".47" y=".29" size="12" content="%title%"/>
<text1 x="0" y=".29" size="10" content="%subtitle%"/>
<text x="9.8" y="7.08" size="8" content="%date%"/>
The one issue I am having though is once I have right justified text1 I cannot move the x position.  So above where it says <text1 x="0", I could have a 0 or 100 in the x= and it wont change the position.  The reason I would like to is that when I right justify my text1 it sits just a little bit outside my border.  I have also added a pdf of my print.
Thanks for your help Len.
Sean Ziniker
GIS Analyst
Jefferson County, Oregon
66 S.E. "D" Street, Suite B
Madras, OR 97741
541.325.5083 Office
541.325.5089 Fax
Sent: Friday, October 22, 2010 1:32 PM
To: Sean Ziniker; geomoose-users at lists.sourceforge.net
Subject: RE: Print Templates
This is possible, but you are going to have to edit print.php.  The library GeoMOOSE uses for printing PDFs is at, http://www.fpdf.org/.  Look for "cell" in the documentation and print.php - you should be able to set the justification.
Len
Sent: Friday, October 22, 2010 3:12 PM
I was just wondering if there is a way to align a subtitle on the right side on my custom print template.  I am using something that looks like this in my .xml:
<text x="-.47" y=".29" size="14" content="%subtitle%"/>
Is there a way to put a right align within the text tag so longer subtitles will not run off the page.
Thanks,
Sean Ziniker
GIS Analyst
Madras, OR 97741
541.325.5083 Office
541.325.5089 Fax
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20101026/d3f4d908/attachment.html
More information about the Geomoose-users mailing list
